Repair guides and support for Olympus digital and film cameras.
camera won't turn off while battery is insterted
My camera has decided that it will not turn off as long as I have the battery inserted. This started about 1.5 weeks ago (no dropping or damage happened), and still continues. I have to remove the batter to ensure that it turns off and not to drain the battery. This is the OM-D Mark 5 II model, just 14 months old. 2 months past warrenty which is killing me.
Score 7
1 Comment
I have had this issue as well, anyhow I had still warranty and it was repaired by Olympus service.
by
Add a comment
Chosen Solution
Hi,
Some suggestions to try:
1. Try a power reset -
Remove the battery from the camera
Turn on the camera.
Press and hold the shutter button for a minute or so. (This is to discharge the internal, non user removable back up battery. This battery maintains the settings in your camera when you remove the main battery).
Release the button and switch off the camera.
Re insert the battery and switch on the camera.
Try turning it off and see if it works correctly.
If it does you may have to reset the date and time settings etc., as these will all have defaulted to a factory default setting. Allow the backup battery at least 24 hours to recharge (from the main battery) before removing the main battery again.
2. If that didn't work, have you got the latest firmware installed in the camera? It may be that the firmware has become corrupted. Even if you have the latest firmware version installed try installing it again (I don't know if the camera will allow this or whether it only permits updates) and see if this resolves the problem.
Here is a link to the firmware for your camera.
http://www.olympusamerica.com/cpg_sectio...
Score 6
9 Comments:
The power rest worked for me.
by
It worked for me too, and I didn't even lose the date. Thanks
by
My camera will not turn on without the battery inserted. Once I insert the battery then I can't get it to turn off. TG3
by
This saved the day for me and worked perfectly. So far, it seems to be a one time occurrence.
by
Worked! I love internet friends!
by
Show 4 more comments
Add a comment
Had this problem for about a month and I tried the suggestions here but did not work. Then I tried spraying some isopropyl alcohol into the dial and switch, flicked it back and forth, spray some more and flick around again. Then blow out as much alcohol as possible and leave for a while. Came back, cleaned with dry micro fibre cloth… and it was fixed!!
Score 4
2 Comments:
I've repeated the blow dryer only fix I mentioned above over the last few years. Well, that eventually stopped working for me. Was moments away from sending it to Olympus when I saw your alcohol fix. Fantastic! It worked. Saved me well over $300 in repair and shipping charges. Thanks!
by
I also followed the previous steps...
Few drops of isopropanol a.k.a. isopropyl alcohol with a baby cotton bud to the switch did the magic finally. (You possibly find isopropanol from your home. It is normally used for wound or medical equipment desinfection.)
Greetings from rainy Lapland!
by
Add a comment
I had this happen to me, but none of the above worked. What did work was using a hairdryer on it. (cool setting)
I remembered I had been at a splash park a couple weeks prior and thought maybe some moisture had gotten in.
My fix:
I opened the side rubber flap and took off the PC flash cap.
5 minutes of blowing air (cool) around the switch and into the USB/HDMI ports did the trick.
A week later it did start to act up again, but another few minutes of hairdryer took care of it.
Me thinks that switch isn't as weatherproof as the rest of the camera.
Score 3
2 Comments:
I second this. Exact same issue, and surprisingly the hairdryer treatment on the switch and ports area (maybe headphone socket allows air to reach power switch contacts ?) fixes it, but only for a short time, a couple of days.
I have the same problem but the camera is never near moisture. I do live on the coast but it is rarely humid.
by
yup....hairdryer worked, camera was fine until I was caught out in a deluge...so much for it being weatherproof, bit sad really, was considering an upgrade to em1mk2 but now I'm not so sure !
by
Add a comment
I have a similar problem, just bought this Weochi Video Camera Camcorder 4K 64MP 60FPS Dual Lens Camera with Wireless Mic, and the USB on the camera seems defective, just a little shake and you lose the connection. When this happens, the screen goes and stays black and the there is no way to shut it off, except for removing the battery. But the Problem with that is when you do so you also erase the date and time set and have to reset it all over again. I know this isn't a top end Camera, they presently list it at $99.99, but so far I have not seen very much desirable for this! The Pictures do not even look as good as my old iPhone SE, which might be due to some further adjustments, or having to use the built-in light compensator. But the Camera apparently does not have a backup battery built in to retain the date and time when the removable batter is removed. I don't know if all of these cheap Cameras are like that, or not. Besides my old iPhone, I had been using the VHS styles of Video Camera's for decades and although their pictures are not as high resolution, they were all much easier to use and adjust, plus built a lot sturdier! I haven't been able to find a website for the Weochi brand and the only help and support I can find for it are like on this site. Also, this Camera does not seem to have a way, or buttons to shut the date and time off so you do not have to record your entire video with it showing. I sure miss my old VHS style Video Cameras, all you had to do was press a soft touch button to get them to do whatever you wanted. I could care less about the flip out view screen, that's handy if you want to video, or take pictures of yourself, which is not what I use it for! My old VHS Recorders were not that much bigger than this new cheapy, except for the first one back in the 1980's, it was a two piece, a big camera you held with a separate recorder wired to it that you used a shoulder strap to carry that part around. And even the old VHS ones Zoom function was a lot better than what I have experienced on this so called 21X that is on the new digital camera.
Add a comment
Add your answer
michelle will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 150
All Time: 23,237
