The Polaroid Cube is a splash-resistant, shockproof, and mountable camera that takes 6 megapixel pictures and shoots videos in 720p or 1080p HD.
Why isn't my computer detecting the Cube?
My computer is not recognizing my Cube when I plug it in with the USB.
Score 2
Add a comment
Chosen Solution
Make sure there is an SD card installed in your Cube. The Cube will not work or be able to be detected without an SD card. Also make sure that your SD card is at least Class 10. Lower Class cards will cause performance issues. Check out the Troubleshooting Page for more information pertaining to your device.
Score 4
Add a comment
FYI, Make sure you are using a USB Data Cable and not just a USB Charging cable.
Score 2
1 Comment:
Thanks! That did the trick!
by
Add a comment
Add your answer
heath lamkin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 49
All Time: 7,898
