A 4-cycle straight shaft string trimmer manufactured by Troy-Bilt. This model is identified by TB675 EC.
starter cord won't retract back
my recoil cord won't retract
Score 2
1 Comment
the pawls are broken. THewy are easy to replace. go to youtube and search "How to replace or repair my tb675ec pawls" https://www.youtube.com/watch?v=V7KduhbV...
bery detailed instruction I did it myself
by
Add a comment
Most Helpful Answer
@Mike, txhunter2 , it sounds like you both may have a broken recoil. The spring has broken on txhunter2 recoil and on Mike's the flywheel engagement tang's have broken. At the link below I believe the whole recoil assy./housing can be replaced for just over $13.00. Good luck. See below links that may help repair/replace the required part. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.troybilt.com/equipment/ARIPar...
https://www.youtube.com/watch?v=2eSWBmhl...
Score 2
Add a comment
Starter cord won't retract
Add a comment
Add your answer
txhunter2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 8,247
