The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
phone won't power on.
My phone keeps blinking on and off. And it won't go to the home screen keeps repeating Galaxy Note 4 repeatedly.
Score 3
Add a comment
1 Answer
Chosen Solution
Have you tried another battery?
That is sometimes a software issue either one of these should work. If you don't want to lose data flash downloaded samsung firmware from sammobile with the matching model number of your phone located in the battery compartment on a label.
Use Odin with the phone booted into download mode and plugged in. Instructions on how to use Odin and flash firmware on to phone are on every download page of firmware from sammobile.
If you don't need to backup data use Samsung kies with firmware upgrade and initialization OR turn the phone off by taking out the battery for a few seconds and putting it back in.
Then hold the power, volume up and home buttons until the white Samsung splash text pops up and immediately stop holding the power button and keep holding volume up and home.
Then it will boot into the recovery menu. And you can use the power button to select and vol up and down to select in the menu. Select wipe data factory reset and reboot phone from recovery mode.
Score 2
1 Comment:
Hi I tried all the solutions to turn back on my samsung note 4. The only one that workec was one where you press down the buttons while putting back in the battery, but I can,t find the post on how to do this and I have same problem again
by
Add a comment
Add your answer
Robert Marsh will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 5,548
