Up to 20% off select tools
Acer Iconia A3 is a 10.1" Android 4.2 Jelly Bean tablet powered by a quad-core Mediatek processor.
Tablet doesn't turn on
Acer iconia tablet a3-a10 doesn't turn on just a light flicker tried soft and hard reboots and no response
Score 2
5 Comments:
How many amps does it draw from the usb charger? Check with a multimeter by splitting either +power or -power and put the probes on the resulting 2 ends of wire.
by Share
Ethan can you tell me about the solution to that problem? i have the same problem, and I need resolve it soon, Thank you
by Share
Yea, as @David said check all the connections and reseat them. Does it get recognized by a PC?
by Share
Hi guys same problem any way to fix it
by Share
hi cliff
my tablet appears to be fully charged , but will not start up
I had to press hard, then harder still, It would now appear that the power switch has failed, is it difficult to replace it
Scott C
by Share
Add a comment
might be a LCD cable not plugged in all the way.
Add a comment
'''it's too easy Guys .
-If you are unable to start the process for your tablet does not answer the Preloader mode, you need to remove the back cover and disconnect the battery and start the tutorial battery disconnected.
Once the tutorial finished, reconnect the battery. put in charge 10 min and then attempt to restart.
1- remove the back cover.
2- disconnect the battery.
3- reconnect the battery.
4- put in charge 10 min.
5- attempt to restart.
GOOD LUCK
[RYAN KHENNOUCI]
Add a comment
Add your answer
Cliff Booth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 2,149
