The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
Why won't my Xbox One Controller charge via USB?
My Xbox One controller won't charge.I have an official rechargeable battery and I can't charge it via usb.My controller also won't connect via usb either.
Score 3
4 Comments:
I have this problem too with my 360 controller. The charger won't work and I've bought 3 new ones already. All three worked for the first twenty-four to fourty-eight hours, but then just stopped working. I tried getting a new battery to charge and that didn't work either. There's probably something wrong with the chargers themselves. Like when someone buys a cheap pair of earbuds, and they end up breaking the next week.
by
I have this same issue with a model 1708 Xbox One controller (white). I have several of these controllers, the rest all charge fine and my battery charges when moved to another controller. This one simply won't charge with any USB cable.
by
I have the same issue with my xbox one s controller. When I plug the usb cable in, the controller vibrates but the battery doesn't charge. What I did was get peice of paper/card board cut it to almost the size of the rechargeable battery pack and put it in where the batteries go, then put the battery in...and put the lid back on (if you use to much paper/card board the back of the controller won't fit. After I plugged it in my battery pack was charging again.
by
I have the same problem with the USB cable, when I plug the USB cable I have to push the USB cable back for it to actually vibrate but even then it won’t charge
by
Add a comment
firstly I'm gonna ask if you were charging the controller with a multi charger
if not try updating the controller through the xbox one and windows 10 xbox live app
or a simple reset with a pin at little hole behind the controller
that might fix your problem
cheers
Add a comment
I have found this answer after digging deep.
If the controller works by plugging it in, but as soon as it is disconnected it shows battery low or critical and then disconnects, this might help
Step 1: Make sure the controller is disconnected.
Step 2: The controller will still try to turn on and then proceed to turn off. Keep doing it till the battery is fully depleted. (will take an 30 mins). This is to recalibrate the internal circuitry measuring the battery level inside of the battery itself.
Step 3: Charge, Unplug, and Enjoy
Source: Tried it out a week ago and it worked.
Add a comment
Add your answer
Nathan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 38
All Time: 19,993
