Why won't my phone turn on?
I just tried to turn my G3 Vigor on and nothing happened. What should I do if it won't turn on?
Make sure that the phone is charged. It won't turn on when the battery is uncharged, so you need to plug the phone and charge it and see what would happen.
Loose the phone,
Heat the board with solding paste( flux)
Let it get cool and jail the phone back.
Good luck..
Hi Jared,
Check out this troubleshooting page for the LG G3 Vigor. If you're still having trouble with your phone, comment back with some more details about your issue ( Age of your phone, what solutions you've already tried, ect. ) and we'll continue to try and help. Good Luck!
1. Check the battery
2. Check the battery sensors
3. Make sure the power switch has water or other deposits
4- Activate the device using the material of the frying and heating a light at 350%
The reason for the sudden shutdown of the phone during use and battery is charged 100% without any external cause
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 513
