Why doesn't camera recognise a memory card is inserted
Camera is not writing files to the cf memory card and is saying a card is not inserted.
maybe contacts are greasy. try to degrease it, any white spirit/alcohol will do. also, you might need to format/reformat the memory card using camera...
I've also discovered that this happens because of a bent pin in the camera where the CompactFlash card plugs into the camera. Mine has been the two pins closest to the eject button.
This can also be caused by a defective/broken CF door switch
Could it be for any other situations, as I have done all checks and keep the problem.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 2,890
