Released in March of 2014, can be identified by the model number KX-TGE233 on the bottom of the main docking station.
Why can't I make calls?
The device is powered on and appears to be functioning, but when I try to make a call, it doesn't go through.
Score 4
1 Comment
my phone is model kx-tg6591
by
Add a comment
1 Answer
Most Helpful Answer
In its operation instruction, the one of problems is stated as:
"This product is unable to make calls when:
– the handset batteries need recharging or have failed.
– there is a power failure."
Since the problem is not about the power, it may follow this condition:
"If you cannot make calls, change this setting
according to your telephone line service. The
default setting is “Tone”.
“Tone”: For tone dial service.
“Pulse”: For rotary/pulse dial service.
1 [MENU]#120
2 Select the desired setting.
3 [SAVE] and [OFF]"
Score 1
1 Comment:
i can't access menu. when i press menu *120 won't go through
by
Add a comment
Add your answer
Nico Cruz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 36
All Time: 1,707
