Up to 20% off select tools
The original Macintosh desktop computer, initially released as the "Apple Macintosh" in 1984.
Sad Mac Face & error code 040090
This one got sent into me for repair. I'm getting a Sad Mc face and error code 040090. I don't remember what this code indicates. Anyone have an idea?
Score 4
2 Comments
Thanks to the link Old Turkey sent me the machine is now running with ram replaced then the caps replaced by the same guy after it failed.
MacCaps.com
MACCAPS.COM 
22222 ROETHEL DRIVE
SUITE D
NOVI, MICHIGAN 48375
UNITED STATES
Charles Phillips
248 325 8812
by Share
I had sad face error code 024000?
by Share
Add a comment
Chosen Solution
04XXXX = Memory test - Mod3 test Memory chip failure
Score 4
11 Comments:
That would be ICs on the logic board itself. Do you know if they are removable? If so where would I find replacements?
by Share
mayer, try this first while I keep trying to find out more. Sad Mac codes can also have a less serious causes such as:
A non-system disk in the default drive
A bad boot disk
An incompatible system file on the boot disk
No Finder on the boot disk
A sticky Programmer's switch
by Share
The startup disk could be a possibility. Will dig in the file cabinet of hundreds of floppy disks to see if I can find an original.
by Share
I get this code with no disk installed. Time for a tear down.
by Share
Pulled board, unable to determine any visible damage to soldered in RAM chips. Any idea of where to get replacement chips?
by Share
Show 6 more comments
Add a comment
Mayer
We could have similar problems and may be able to help one another in finding a solution. First, where are you (I'm in Australia)? Second, do you get the sad safe following the "dong", and before a disk is inserted? And third do you understand the other possibilities that Oldturkey03 suggested (nonsystem disk in the default drive etc). As far as I can tell none of these are relevant because the 04 prefix to our errors (mine is 048360) means a RAM chip on the logic board.
Looking forward to your reply.
Barry Richardson
brlund007@gmail.com
Score 2
1 Comment:
I dropped in a 512k board. Machine booted just fine, so Disk is good. Ran initial RAM tests. All good! Ran extended tests for an hour and a half, burned out the power supply :-(
by Share
Add a comment
Replace the RAM Chips..
I hope it works :)
6 Comments:
If you read the question, you'd know it worked.
by Share
How would he know that? I just looked again and even after reading through a bunch of follow up questions I still don't know. Why not say 'yes or did not work' instead of giving people a nasty attitude. You had the help from others , too . SMH
by Share
MY FIRST COMMENT WAS "
Thanks to the link Old Turkey sent me the machine is now running with ram replaced then the caps replaced by the same guy after it failed."
MacCaps.com
MACCAPS.COM 
22222 ROETHEL DRIVE
SUITE D
UNITED STATES
Charles Phillips
248 325 8812
by Share
why do I keep getting told I've heped lots of people when I've done bugger-all?
Barry
by Share
@rhodas007 That happens when you hang around in questions that @oldturkey03 and I are involved with ;-)
by Share
Show 1 more comment
Add a comment
Hi,
my beloved really early 128k comes up with a SadMac code 041004 and some fragments on the screen.
I did a quick video on this issue: https://youtu.be/Cql6E2PxGj0
Any advice would be great - if it's just the RAM (I fear so) where to get them?
Marcus (@marnoweb.de)
2 Comments:
Please read through the discourse on this page. MacCaps can handle this for you.
by Share
THX, but I finally tried it with swapping the DRAMs - with success :D
by Share
Add a comment
Add your answer
mayer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 32
All Time: 2,856
