The HP ProOne 600 G1 AiO Business PC uses Intel Core i3-4160 processor and is identified by product number K1K72UT#ABA.
Why won't my computer turn on?
I press the power button on my PC, but nothing happens.
Score 1
Add a comment
Make sure your computer is plugged into a functioning outlet. If no power is going to the desktop, it cannot function. This PC has no battery. If there is still no response, you may want to try accessing more RAM. Other solutions to this issue can be found on the troubleshooting page.
Add a comment
Have you checked if the power cable is plugged in and the switch next to the power cable port is switched to on?
RAM has nothing to do with this btw.
Add a comment
Add a comment
After 6checking the power cord is plugged into a working outlet and securely seated in the back of the PC at least in our one time case pressing. Control- alt-delete seems to have enabled it to be turned on when the power button on the keyboard was not responding.
Add a comment
Add your answer
Maxwell Snook will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 4,165
