Released 2013, the DXR-5 baby monitor contains features such as:Video · One Receiver · 150 foot range · 2.4 GHz Digital Signal · Night Vision. Existing part numbers are B0052QYLUM and BBM1.
Why won't my DXR-5 charge?
If you are having trouble charging the DXR-5, the solution is here.
Score 3
Add a comment
1 Answer
Chosen Solution
Using a dry cloth, clean the interior metal plates in the battery slot. Make sure the battery is touching the metal plates (terminals). Ensure that the AC adapter is properly inserted into an outlet. If the device still fails to charge, use the camera adapter to see if the unit charges. If the camera adapter works, then this implies that the AC adapter needs to be replaced. You can contact the manufacture by following this link: http://infantoptics.com/contact.php
or you can check the troubleshooting page at:
Infant Optics DXR-5 Troubleshooting
Add a comment
Add your answer
Dwight Crawford will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 34
All Time: 8,710
