The Dell Venue 7 is a 7" HD Android tablet. It was released October 2013.
My tablet wont turn on
my tablet wont turn on and the power botton doesnt wanna work i tried charging it but it still wont turn on
Score 10
3 Comments
dell is worst service ever seen i have am using this tab since 10 mnt and all the time i receive new problem and not yet solved any of the problem
by
my dell tablet not work hard reset
i try power key + volume down but not open reset fectory
by
@faiz alam i plugged my venue in for about 5 minutes and then I saw the Dell logo illuminate onscreen then the battery charge level at 0%. So I just needed to be patient.
by
Add a comment
Chosen Solution
Try a hard boot or hard reset.You can try press the power on button and the volume up button for a count of 5 and release and then press both in again. Hope this helps
Score 6
4 Comments:
This absolutely worked after I remembered tablet had a case on it. After I removed the case then I guess my connection w/buttons was better, & so it worked totally. Thank u Jimfixer.
by
I have the same problem and i believe my battery is drained. Can you help?
by
I only had to hold the power button and volume up for about 5 seconds and the system powered up into a diagnostic and allowed be to continue to boot.
by
my tablet turn off and it wont turn back on i have no case i hold the power button but it wont turn on. can you help me?
by
Add a comment
i have your problem too but i think if u put it in a another charger it will work that happend to me like months ago and it happend again
Score 2
Add a comment
New battery time. If the light just flashes yellow, it is because the lithium battery has dropped below its charging point. You can take it out and manually charge if with a 5 v supply for about 10 minutes, and put it back in. It should take off again. Or, change the battery. $25 on ebay
Score 1
1 Comment:
Thank u friend for this help
by
Add a comment
My delltablet just automatically shutdown and I just struggle to turn it on again.But it won't.Could you help me?
Score 1
Add a comment
i have tablet dell no chraging model to2d001 only give this in batteri that sign(?)
Add a comment
Change the battery. Watch youtube video
https://www.youtube.com/watch?v=U_bi9_rp...
1 Comment:
Dell is really a very bad service giver . I face a lot of problems with ur companies tab the screen gives dark auto .auto shut down .screen fades . Tab do sent start up. And always their is a message unfournately Google has stopped working and other apps too come with the same I press OK but comes again and again
by
Add a comment
Add your answer
Nestor moreno will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 85
All Time: 36,407
