Why won't my camera turn on?
When I press the power button, nothing happens.
The simplest reason for this problem is an issue with the battery and charging system. Make sure you are using the proper USB charger and cord and they are not malfunctioning or damaged. If everything is working normally there may be an issue with your battery, which you can replace by opening the battery compartment.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 43
All Time: 979
1 Comment
Mine fell down and the lens never eject
by S`busiso mqapheli
