The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
It won't start or turn on
Washer will not start
Kenmore 110
Score 9
Add a comment
Most Helpful Answer
If your Kenmore 110 Series Washing Machine refuses to turn on, see the Kenmore 110 Series Washing Machine Won’t Turn On problem page for possible causes and solutions.
Check and make sure circuit feeding washer is live try plugging a working lamp into the plug with the washer to check
Update
If the lamp doese’t work go to the inside breaker panel and look for tripped breaker normally it will be a 15amp or 20 amp depending on how the circuit is run
Score 1
Add a comment
Unplug the machine for 5 minutes to allow it to reset.
Score 1
1 Comment:
Mine worked by resetting
by
Add a comment
Add your answer
gene4unot will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 34
All Time: 8,345
