Amana Refrigerators are manufactured by Whirlpool Corp group, in Amana Iowa.
Amana Fridge Model ABB1924DEW won't cool?
I have an Amana Fridge Model ABB1924DEW with single door up top and a freezer drawer on bottom. My fridge will not cool, even on coolest temperature setting. Air flow vents on floor of fridge not blowing any cool air at all. I removed the rear door panel of fridge and cleaned all dust around compressor, cooling grates underneath fridge, etc. Fridge still not working. Noticed the fan was running ok within rear panel. The freezer is working fine though maintaining a good temperature.
Score 1
1 Comment
I have replaced the control board, the starter relay and the unit is still not getting cool top or bottom
by
Add a comment
Chosen Solution
Cause 1
The Evaporator Coils are Frosted Over
The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Parts
Evaporator Fan Motor for your Amana Refrigerator
RepairClinic Item #1480832
Motor, freezer (evaporator) fan
$39.25
Quantity:
Out of Stock
Click for Expected Ship Date ›
365-Day Return PolicyReturn any item for any reason within 365 days of placing your order.Find out more »
Total: $39.25
ADD TO CART
Cause 3
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Parts
Damper Control Assembly for your Amana Refrigerator
RepairClinic Item #1057232
Air damper control assembly *Please call with model and serial number to verify correct part.
$52.04
Quantity:
In Stock ›
Same Day ShippingOrder by 8:00 PM ET, this part ships TODAY!
Total: $52.04
ADD TO CART
https://www.repairclinic.com/RepairHelp/...
Score 1
Add a comment
You need to look in those vents that go from the fridge to the freezer. After time they get clogged up with ice. Just knock the ice out and you're good to go.
Add a comment
Add your answer
Al Emm will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 26
All Time: 3,299
