Up to 20% off select tools
Repair guides and support for Samsung digital cameras.
lens open & close same time
My samsung camera DV 150F as soon as i press the power button LENS opens & close same time and follow message appears on screenTHE ZOOM DIDNT OPERATE NORMALLY INSERT THE BATTERY AGAIN AND TURN THE CAMERA ON IF NOT WORK CONTACT THE SERVICE CENTRE.
Score 17
Add a comment
Chosen Solution
Raza, first of course you want to follow the instructions given to you regarding the battery. If that does not work, it sounds like you are having issues with your lens not properly extending. You could try and clean it, check to see if it looks center when retracted. Check on here for more information.
Score 3
Add a comment
I tried the paper shim going around between two lenses and body and lens, compressed air, allowing small amount of alcohol on q-tip on gap - and nothing would get my lens to open. Then I held in flat between my two hands and "gently" gave it a very light twisting diagonally, once in each direction. Hit the power button and it works fine now. As my gaffer used to say, "Don't force it! Get a bigger hammer!"
Score 2
Add a comment
Try removing the battery exactly as the lens comes out.. it worked for me while all the other solutions failed.
Score 1
1 Comment:
You saved my life, thanks a lot :)
by Share
Add a comment
Add your answer
Raza will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 36
All Time: 12,200
