Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance. Released in 2012
doesn't display anything while sd card is on
After I used reemix 3-in-1 remote controle device on my camera it has stopped displaying any images or any nformation on the screen. but after I remove the sd card it shows my settings but I can't change anything else than shutter speed and apature vaalue.what's wrong withi it?
Add a comment
I have a similar problem. In M mode, when I insert SD card the LCD goes black until I change mode. The most of buttons don't seems to work but they're recognized (all of them wake the camera in standby mode).
Is there a way to change firmware in another than the classic way?
Add a comment
I had the same problem as you. Screen blank while memory card was in.
I had a third party grip/battery holder attached to my D3200 that had a cable that plugged into the camera and the grip to trigger the shutter. The cable was only partially inserted into the camera. When I plugged it in fully the problem went away.
Add a comment
I have the same problem with mine, £80-£140 for Nikon to repair, depending on fault. However I was told they suffer from fema faults, Nikon know about this, and will upgrade for free. Personally think it’s a nasty piece of rubbish made in Thailand with a Nikon badge on in it.
Add a comment
Add your answer
ned will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,195
