The Linksys WRT54G (and variants WRT54GS, WRT54GL, and WRTSL54GS) is a Wi-Fi capable residential gateway from Linksys.
impossible to get connection with Ethernet network
How to set the hardware factory settings router Linksys model VTR54GL v 1 . 1
Score -1
Add a comment
Chosen Solution
Here's the Linksys support page for your unit WRT54GL Wireless-G Router It has all you should need to answer your questions.
Add a comment
Most Helpful Answer
You must connect to the router via Ethernet cable for setup/upgrade. If you pooched the upgrade buy a new router... software fixes/hacks are not really our thing here.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
This answer was originally to another question.
Try by resetting your router and re-configure it again. Please note that your all saved setting shall gone once you have done hard reset so i would suggest if your using ADSL then get your PPPoE account setting from your ISP first and then do this.
Add a comment
Add your answer
Oghi Boev will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 281
