<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;iPhone 7 Plus&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/iPhone_7_Plus/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;iPhone 7 Plus&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Tue, 18 Aug 2026 03:00:52 -0700</pubDate>
<item>
<title><![CDATA[iPhone 7 Plus: My phone fell into the water and the screen is not displaying again]]></title>
<description><![CDATA[<p>Phone screen won't display when it fell inside water</p>
<p>⟐ Commented August 09, 2026 at 19:00 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/967444/My+phone+fell+into+the+water+and+the+screen+is+not+displaying+again</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/967444</guid>
<pubDate>Sun, 09 Aug 2026 19:00:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: Why iPhone 7 Plus won’t charge after replacing charging port]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/yeQPFufKgWRLZZob.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/yeQPFufKgWRLZZob.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/OirFnotgGq1RHgZ1.standard" width="127" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/OirFnotgGq1RHgZ1.full&quot;, '', 'width=750,height=1334')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/jFOb3TWrnVwN6eRX.standard" width="127" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/jFOb3TWrnVwN6eRX.full&quot;, '', 'width=750,height=1334')" /></div>
<p>Hi techs and DIYers, I was trying to repair an iPhone 7 Plus that would not turn on. I replaced the battery and the device would turn on but it would not charge; when the phone was off and I connected it to the charger the phone would turn on but it would not receive a charge, so I tried cleaning the charging port and using a different charging cable and charging block to see if that would resolve the issue. The charging blocks and cables I have work on my other iPhone SE 2022 but not this iPhone 7 Plus, so I’m confident that the charging cables and blocks are not the issue. I ordered a replacement charging port on eBay; the listing is shown in the photos attached to this post. I wanted to test the charging port to make sure it works before removing the backing film covering the adhesive, so I put it into the phone with the adhesive covering film and connected it to the logic board and the touch screen. I did not reconnect the speaker and Taptic Engine. After that I plugged the charging cable into the phone and the battery logo appeared (keep in mind that the new battery had lost its power 3 days before I tested the charging port). Every couple of minutes I pressed the power button once and the battery logo appeared, so after a while I left the phone alone and waited for about 10-15 minutes. When I noticed that the phone had not turned on yet, I pressed the power button again and the battery logo did not appear. I tried disconnecting and reconnecting all the cables of the touchscreen and rear facing camera and logic board but it still would not charge. The film covering the adhesive of the charging port flex cable has not been removed yet. Does anyone know what the issue could be?</p>
<p>⟐ Edited by author August 08, 2026 at 18:38 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/966957/Why+iPhone+7+Plus+won%E2%80%99t+charge+after+replacing+charging+port</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/966957</guid>
<pubDate>Sat, 08 Aug 2026 18:38:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: WIFI not working after replacing lightening connector]]></title>
<description><![CDATA[<p>I replaced the lightening connector assembly and everything seemed to go back together just fine, but after starting up the phone again, the wifi is not working.  Specifically, the wifi cannot be enabled, the switch in settings is off, and cannot be turned on.</p>
<p>⟐ Answer edited August 06, 2026 at 10:07 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/623877/WIFI+not+working+after+replacing+lightening+connector</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/623877</guid>
<pubDate>Thu, 06 Aug 2026 10:07:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: Lightning port too loose?]]></title>
<description><![CDATA[<p>Looking for suggestions or similar symptoms to diagnose.</p>
<p>Lightning cables will just not stay in this phone if either is even shifted to the slightest. Unscientific measure; I used to be able to pick up the dropped phone by the cord alone without disconnect. Now ANY pull or pressure and the cord comes out. I don't see any debris in port, but my eyes aren't perfect. I can't tell if there are pressure levers or contacts that I see inside on left and right, and maybe one is bad?</p>
<p>YES, it still connects to laptop.</p>
<p>YES, it still charges fine.</p>
<p>YES, i tried original cable.</p>
<p>YES, i tried a NEW original cable.</p>
<p>YES, the cables 'pop' in/ fully seat.</p>
<p>NO, there is no case.</p>
<p>YES, i tried with a passthrough case.</p>
<p>help?</p>
<p>⟐ Commented June 10, 2026 at 11:53 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/472532/Lightning+port+too+loose</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/472532</guid>
<pubDate>Wed, 10 Jun 2026 11:53:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: How to open an unvaluable iPhone 7plus]]></title>
<description><![CDATA[<p>How to open an unvaluable iPhone 7plus</p>
<p>⟐ Answered May 19, 2026 at 5:58 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/955822/How+to+open+an+unvaluable+iPhone+7plus</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/955822</guid>
<pubDate>Tue, 19 May 2026 05:58:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: iPhone 7 plus Camera not working after screen replacement]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I've just replaced screen iPhone 7 plus for a customer, after that she checked and both front and back camera are not working(I don't know if she broke before or I did it). I have tried to reseat front camera but no help. I  replaced aftermaket front camera and it won't work too(I heard aftermarket camera won't work on ios 11???). I haven't tried original camera yet. PLease let me know what happen?</p>
<p>Thank you very much!</p>
<p>⟐ Commented May 04, 2026 at 10:31 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/438244/iPhone+7+plus+Camera+not+working+after+screen+replacement</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/438244</guid>
<pubDate>Mon, 04 May 2026 10:31:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: How do I fix a loose charging port without replacement?]]></title>
<description><![CDATA[<p>The charging cable was pulled at an angle and it wasn't removed properly. Now when a charging cable is inserted, it goes in but there is no audible click and is loosely fitting. Is there a way to fix this without a port replacement? Is there a way to bend something in the connector so it grips the lightning plug more?</p>
<p>I think it's the wings inside of the lighting plug that are loose but is there a way to bend it inward without a device disassembly? I have a photo of what I am referring to below.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/1kTChyC3wnN3smFG.standard" width="282" height="211" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/1kTChyC3wnN3smFG.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Answered March 10, 2026 at 23:23 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/742746/How+do+I+fix+a+loose+charging+port+without+replacement</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/742746</guid>
<pubDate>Tue, 10 Mar 2026 23:23:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: I suddenly unplug cable while flashing by 3uTools then can't start]]></title>
<description><![CDATA[<p>Hi guys, my iphone 7 plus using an alternative lcd screen, i want to flashing it to make the os clean before jailbreak, but while flashing using 3utools, i suddenly unplug my usb cable so that the phone which was in dfu mode and progress bar shut down, then i cant open it despite of any button combination, i tried to re-plug but 3uTools cant determine my iphone any more</p>]]></description>
<link>https://www.ifixit.com/Answers/View/942027/I+suddenly+unplug+cable+while+flashing+by+3uTools+then+can&#039;t+start</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/942027</guid>
<pubDate>Tue, 24 Feb 2026 07:31:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: It doesn’t come off]]></title>
<description><![CDATA[<p>I tried to change the battery and those adhesive stripes ripped off midway, Now the battery doesn’t come off!</p>
<p>⟐ Answer edited February 04, 2026 at 11:15 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/939085/It+doesn%E2%80%99t+come+off</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/939085</guid>
<pubDate>Wed, 04 Feb 2026 11:15:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: When the phone is cold, small lines appear below the third of the scre]]></title>
<description><![CDATA[<p>IPhone 7+</p>
<p>تظهر خطوط أفقية صغيرة في اسفل الشاشة عند تشغيل ثم تختفي بعد فترة ليعمل الجهاز جيداالال</p>
<p>⟐ Answer accepted January 29, 2026 at 5:41 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/937399/When+the+phone+is+cold,+small+lines+appear+below+the+third+of+the+scre</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/937399</guid>
<pubDate>Thu, 29 Jan 2026 05:41:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: iPhone 7 Plus Boot Loop]]></title>
<description><![CDATA[<p>Hi. My iPhone 7 Plus Keeps rebooting. Boot loop. It Turns on to white apple logo and then shuts off and then turns back on. Keeps doing that repeatedly. I've already tried a restore from my computer and it resets and shows the reset bar but then comes back to  the reboot screen. Please Help. Thanks in advance.</p>
<p>⟐ Answered January 25, 2026 at 8:19 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/416771/iPhone+7+Plus+Boot+Loop</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/416771</guid>
<pubDate>Sun, 25 Jan 2026 08:19:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: Why my phone does not have a good network]]></title>
<description><![CDATA[<p>Network problem</p>
<p>⟐ Answered January 22, 2026 at 9:29 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/937207/Why+my+phone+does+not+have+a+good+network</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/937207</guid>
<pubDate>Thu, 22 Jan 2026 09:29:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: Tôi bị quênmaatj khẩu icloud muốn xoá hết như lúc đầu]]></title>
<description><![CDATA[<p>Cách khắc phục khi quên mật khẩu icloud</p>
<p>Translation Vietnamese - English</p>
<p>I forgot my iCloud password and want to delete everything as it was originally</p>
<p>How to fix when you forget your iCloud password</p>
<p>⟐ Edited January 09, 2026 at 18:48 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/935127/T%C3%B4i+b%E1%BB%8B+qu%C3%AAnmaatj+kh%E1%BA%A9u+icloud+mu%E1%BB%91n+xo%C3%A1+h%E1%BA%BFt+nh%C6%B0+l%C3%BAc+%C4%91%E1%BA%A7u</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/935127</guid>
<pubDate>Fri, 09 Jan 2026 18:48:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: How to force logout my iCloud]]></title>
<description><![CDATA[<p>how t force logout my iCloud on iPhone 7plus</p>
<p>⟐ Answered January 09, 2026 at 2:56 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/935030/How+to+force+logout+my+iCloud</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/935030</guid>
<pubDate>Fri, 09 Jan 2026 02:56:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: WhatsApp Verification Stuck After Phone Change]]></title>
<description><![CDATA[<p>Hi, I recently bought a new Mi Ultra 11 Android phone and installed WhatsApp. When I logged in, I expected my chats to transfer automatically from my IPhone 7plus. After several login attempts, I tried to log back in on my iPhone, but I keep receiving the message: “We couldn’t send you an SMS, please wait 1 hour.” I waited more than one hour, but the same issue continues. Call verification is also not working. Could you please help me resolve this issue and regain access to my account?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/932778/WhatsApp+Verification+Stuck+After+Phone+Change</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/932778</guid>
<pubDate>Mon, 29 Dec 2025 04:14:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: Screen wont go dark]]></title>
<description><![CDATA[<p>I replaced the screen.  Everything works fine touch color etc. But when i am on calls the screen doesn't go dark like sleep mode and i keep accidentally ending calls while on the phone. I do not know why please help?</p>
<p>⟐ Answered December 11, 2025 at 5:55 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/497293/Screen+wont+go+dark</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/497293</guid>
<pubDate>Thu, 11 Dec 2025 05:55:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: iPhone 7 plus sound problem]]></title>
<description><![CDATA[<p>My iphone will not record sound although I gave microphone access to all necessary apps , it blurs out the sound button on videos captured using the phone however other videos that were not recorded using this phone produce sound.</p>
<p>⟐ Answered December 03, 2025 at 19:38 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/929006/iPhone+7+plus+sound+problem</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/929006</guid>
<pubDate>Wed, 03 Dec 2025 19:38:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: How can I remove my icloud]]></title>
<description><![CDATA[<p>How can i remove icloud</p>
<p>⟐ Commented November 18, 2025 at 4:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/824830/How+can+I+remove+my+icloud</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/824830</guid>
<pubDate>Tue, 18 Nov 2025 04:51:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: My power button , volume up and down button,ringer&silent not working.]]></title>
<description><![CDATA[<p>I noticed my buttons are not working including the flashlight.  I’ve restarted the phone multiple time.  Still the same</p>
<p>⟐ Answer accepted November 09, 2025 at 18:54 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/765487/My+power+button+,+volume+up+and+down+button,ringer&amp;silent+not+working.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/765487</guid>
<pubDate>Sun, 09 Nov 2025 18:54:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 7 Plus: Why is my phone saying not secure network]]></title>
<description><![CDATA[<p>Why in my web browser is am getting ssl certificate error messages</p>
<p>⟐ Answered October 23, 2025 at 7:27 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/923062/Why+is+my+phone+saying+not+secure+network</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/923062</guid>
<pubDate>Thu, 23 Oct 2025 07:27:28 -0700</pubDate>
</item>
</channel>
</rss>
