<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;audio mixer&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/audio_mixer/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;audio mixer&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Tue, 14 Jul 2026 20:31:58 -0700</pubDate>
<item>
<title><![CDATA[Behringer U-Phoria UMC204HD: I need someone to identify this circuit board component.]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/M1qTDKIItFfZJn1v.standard" width="164" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/M1qTDKIItFfZJn1v.full&quot;, '', 'width=1487,height=2046')" /></div>
<p>I'm repairing a Behringer U-Phoria UMC404HD. There was a tiny component that received both the signals of USB data(+) and data(-), before allowing both to proceed towards the XMOS chip. Please take a look at the image above to check out how the component (with arrows pointing at it) and the surrounding area looks in an undamaged UMC404HD.</p>
<p>There has been an attempt, by the former owner, to repair the USB connections, which left this particular component destroyed.</p>
<p>Could someone tell me what is this component and, if possible, the specs it might have, so I can order a suitable replacement?</p>
<p>I don't have much knowledge in parts names and uses, but I can do a good job, when it comes to repairing circuit boards.</p>
<p>⟐ Commented June 04, 2026 at 15:39 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/842992/I+need+someone+to+identify+this+circuit+board+component.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/842992</guid>
<pubDate>Thu, 04 Jun 2026 15:39:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[QU-32: Channels 17 to 24 white noise problem!]]></title>
<description><![CDATA[<p>Has anybody heard of a fix for ny problem, when I boot up the desk I get white noise static of varying amounts on either all of the fader channels from 17 to 24 and then intermittently on the same channels. Nothing connected to the desk, noise stops momentarily when I switch phantom power on but immediately returns, anybody have any suggestions??</p>]]></description>
<link>https://www.ifixit.com/Answers/View/956155/Channels+17+to+24+white+noise+problem!</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/956155</guid>
<pubDate>Thu, 21 May 2026 13:10:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Korg Volca Mix: How to fix the headphone jack?]]></title>
<description><![CDATA[<p>My headphone jack doesn’t work unless I jiggle it, and it’s getting harder and harder to get it to work now. How do I fix it?</p>
<p>⟐ Commented March 25, 2026 at 22:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/946878/How+to+fix+the+headphone+jack</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/946878</guid>
<pubDate>Wed, 25 Mar 2026 22:51:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Allen-Heath GL4 Audio Mixer: Audio mixer not enough phantom power current?]]></title>
<description><![CDATA[<p>When I plug in several dynamic and condenser microphones into my 32-channel 1995 Allen &amp; Heath GL4 mixer, a specific large diaphragm condenser (LDC) microphone drops out and turns into white noise.</p>
<ul><li>The mic in question works fine on modern audio interfaces</li><li>The only solution is to replace it with an small diaphragm condenser (SDC), and I was able to continue my drum recording session.</li></ul>
<p>The particular LDC mic will work on the AH mixer only if it's the only microphone being powered, regardless of which channel the LDC mic is attached. However, when other channels are powered, even without mics attached in the other channels, the prior LDC drops out into white noise.</p>
<p>The Power Supply Unit has been recapped, about 4 large capacitor and 1 medium capacitor, and 2 smaller ones. -- save for some very small capacitors that do not look like they are blown. The problem described was already noted even for the recapping.</p>
<p>Maybe someone has encountered this same problem and knows where to start looking with regards to this mixer?</p>
<p>⟐ Answer edited November 20, 2025 at 2:31 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/925309/Audio+mixer+not+enough+phantom+power+current</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/925309</guid>
<pubDate>Thu, 20 Nov 2025 02:31:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[focusrite scarlett 2i2(2nd Gen): power plug wiggle from fall; won't come on now.]]></title>
<description><![CDATA[<p>The power plug-in took a fall, now the power cord wiggles and it won't come on.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/912980/power+plug+wiggle+from+fall;+won&#039;t+come+on+now.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/912980</guid>
<pubDate>Wed, 20 Aug 2025 02:08:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[audio mixer: Catastrophic failure on Mixing Console PCBs, anyone ever seen this?]]></title>
<description><![CDATA[<p>Hey everyone,</p>
<p>I am working on repairing some PCBs off of a TL Audio VTC Mixing Console. There seem to be multiple points of failure, but I have never seen damage this catastrophic and I am wondering anyone has any ideas about what caused this level of damage.</p>
<p>The first damaged item was an LM339N OP-AMP, which ended up actually destroying the pad connected to pin 12, which is GND. Of all the pins, why would GND be burnt up? This device is part of the VU-Meter circuit was is essentially a peak detector circuit for the volume level.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Mys6OViiGcUcUjJ2.standard" width="253" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Mys6OViiGcUcUjJ2.huge&quot;, '', 'width=1348,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/2O4NqjKmar2aTATP.standard" width="269" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/2O4NqjKmar2aTATP.full&quot;, '', 'width=1077,height=901')" /></div>
<p>The next failure point was on another PCB in the same console, located nowhere near the previous one. This seems to have melted on both sides somehow. There was also a ribbon cable underneath the board which melted.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/EuIpYEoOeDIiH1qR.standard" width="282" height="137" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/EuIpYEoOeDIiH1qR.full&quot;, '', 'width=1822,height=881')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/j26knFExcRnVEpeH.standard" width="282" height="141" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/j26knFExcRnVEpeH.full&quot;, '', 'width=1822,height=913')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/JfyfLADSE6fGYHL1.standard" width="238" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/JfyfLADSE6fGYHL1.full&quot;, '', 'width=1366,height=1295')" /></div>
<p>I actually managed to find the schematic for the second board, and it seems to be part of a switching circuit for the Pre-Fade-Listen audio signals. It seems like this IC was responsible for the left channel, because the IC2 is actually responsible for the right channel and it is completely fine.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/hYuvWUZgK6vB5UxR.standard" width="282" height="127" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/hYuvWUZgK6vB5UxR.full&quot;, '', 'width=2532,height=1144')" /></div>
<p>Strangely enough, the analog switch ICs are fine, it is just the OP-AMPs that are destroyed...</p>
<p>If anyone has seen anything like this before it would be really helpful!</p>]]></description>
<link>https://www.ifixit.com/Answers/View/903287/Catastrophic+failure+on+Mixing+Console+PCBs,+anyone+ever+seen+this</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/903287</guid>
<pubDate>Tue, 10 Jun 2025 14:24:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[QU-32: Why is my console is not turning on]]></title>
<description><![CDATA[<p>my console is not turing on. when i try to switch it on its just shows QU -32 And Allen &amp; Heath branding. no keys are working its frenzied</p>
<p>⟐ Answered February 01, 2025 at 7:36 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/879874/Why+is+my+console+is+not+turning+on</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/879874</guid>
<pubDate>Sat, 01 Feb 2025 07:36:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[QU-32: No sound at all the outputs of Qu-32 audio mixer]]></title>
<description><![CDATA[<p>My Allen and Heath Qu-32 audio mixer had all of its outputs abruptly ceased producing sound. On the meters, input signals could be observed, but there was no sound coming from the outputs. How can I fix this issue?</p>
<p>⟐ Answered February 01, 2025 at 7:35 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/747872/No+sound+at+all+the+outputs+of+Qu-32+audio+mixer</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/747872</guid>
<pubDate>Sat, 01 Feb 2025 07:35:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Behringer U-Phoria UMC204HD: My interface doesn't wanna connect on my computer]]></title>
<description><![CDATA[<p>Interface program</p>
<p>⟐ Commented November 13, 2024 at 20:50 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/876981/My+interface+doesn&#039;t+wanna+connect+on+my+computer</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/876981</guid>
<pubDate>Wed, 13 Nov 2024 20:50:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[focusrite scarlett solo: How come my recording software doesn’t pick up audio from my guitar]]></title>
<description><![CDATA[<p>When I plug my guitar into the Scarlett solo I can hear the guitar through my head phones (headphone also have white noise for some reason) but my recording software doesn’t pick it up.</p>
<p>⟐ Answered September 21, 2024 at 2:23 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/830123/How+come+my+recording+software+doesn%E2%80%99t+pick+up+audio+from+my+guitar</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/830123</guid>
<pubDate>Sat, 21 Sep 2024 02:23:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[AH ZED-10FX: Exeses noise in live sound system]]></title>
<description><![CDATA[<p>Exeses noise</p>]]></description>
<link>https://www.ifixit.com/Answers/View/856793/Exeses+noise+in+live+sound+system</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/856793</guid>
<pubDate>Thu, 27 Jun 2024 02:27:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Behringer PMP2000D: Why is it not turning on?]]></title>
<description><![CDATA[<p>Yesterday I turned on the phantom power and forgot to turn it off and now it is not starting.why?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/849698/Why+is+it+not+turning+on</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/849698</guid>
<pubDate>Thu, 16 May 2024 03:23:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[audio mixer: Yamaha DM3D disassembly]]></title>
<description><![CDATA[<p>I purchased a DM3D and I want to put an air tag into it to track it as it will be a rental unit.</p>
<p>I’m taking it apart now but I’d love a guide to do this fast and efficiently.</p>
<p>I’ll document it but if anyone else has one and can advise on best practices, I’m all ears.</p>
<p>⟐ Edited May 05, 2024 at 14:58 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/848362/Yamaha+DM3D+disassembly</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/848362</guid>
<pubDate>Sun, 05 May 2024 14:58:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[audio mixer: Mixer dont have a power]]></title>
<description><![CDATA[<p>When i switch on the mixer..mixer cannot switch on..</p>
<p>⟐ Commented November 01, 2023 at 4:37 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/821928/Mixer+dont+have+a+power</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/821928</guid>
<pubDate>Wed, 01 Nov 2023 04:37:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Focusrite Scarlett 2i4 (2nd Gen): Why is phantom power on there is noise...?]]></title>
<description><![CDATA[<p>my sound card is Scarlett 2i2 2nd generation and when i start record and i turned on 48v there is noise how can i solve</p>]]></description>
<link>https://www.ifixit.com/Answers/View/821580/Why+is+phantom+power+on+there+is+noise...</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/821580</guid>
<pubDate>Sun, 29 Oct 2023 05:16:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[focusrite scarlett solo: Has anyone opened a case for a Focusrite iTrack Dock?]]></title>
<description><![CDATA[<p>I have removed the washers and knobs.  I have never worked on an item like this.  How do you open &quot;clamshell&quot; cases on electronics.  And what is this type of case called?  I can post a picture if needed.</p>
<p>⟐ Commented July 29, 2023 at 16:08 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/804145/Has+anyone+opened+a+case+for+a+Focusrite+iTrack+Dock</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/804145</guid>
<pubDate>Sat, 29 Jul 2023 16:08:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[audio mixer: Ahuja 912 mixer amplifier one side problem.left side not working?]]></title>
<description><![CDATA[<p>Ahuja 912 mixer amplifier left side not working.But the right side is fine. All components are showing fine in multimeter.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/803450/Ahuja+912+mixer+amplifier+one+side+problem.left+side+not+working</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/803450</guid>
<pubDate>Mon, 24 Jul 2023 08:03:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[AH ZED-10FX: FX Loop Creating Excessive Noise]]></title>
<description><![CDATA[<p>The mixer works great, except for if I have any of the FX on. It appears the FX board is creating static or other crackling, <em>even when</em> the volumes of all FX are <em>turned off.</em> I've yet to open the case and test the effects board.</p>
<p>Any advice regarding troubleshooting? I'm not sure if there's a replacement board for this unit, but that may be where I end up.</p>
<p>⟐ Answered June 17, 2023 at 13:39 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/796916/FX+Loop+Creating+Excessive+Noise</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/796916</guid>
<pubDate>Sat, 17 Jun 2023 13:39:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Behringer U-Phoria UMC204HD: Volume knob making noise when pushing up or down]]></title>
<description><![CDATA[<p>It's was firstly was in headphone knob but it is now also in monitor knob</p>
<p>It doesn't make any issue in recording but it is really annoying</p>
<p>⟐ Answered September 03, 2022 at 18:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/730893/Volume+knob+making+noise+when+pushing+up+or+down</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/730893</guid>
<pubDate>Sat, 03 Sep 2022 18:43:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[focusrite scarlett solo: Why does my microphone volume keep cutting?]]></title>
<description><![CDATA[<p>My rode nt1 is plugged into a scarlett solo with phantom power on. It used to work fine but now when I plug the interface the mic works for a little then immediately goes extremely low. It sometimes comes back when I leave it for a while but it goes off when I start using it again. Another way I got it to start working is if I put it in front of a standing fan (as in a lot of wind blows on it). But immediately I move it away, it cuts again.</p>
<p>⟐ Answered October 19, 2021 at 13:41 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/689057/Why+does+my+microphone+volume+keep+cutting</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/689057</guid>
<pubDate>Tue, 19 Oct 2021 13:41:26 -0700</pubDate>
</item>
</channel>
</rss>
