<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Xiaomi Robotic Vacuum Cleaner&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Xiaomi_Robotic_Vacuum_Cleaner?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Xiaomi Robotic Vacuum Cleaner&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 09 Jul 2026 00:12:35 -0700</pubDate>
<item>
<title><![CDATA[Xiaomi Docking Station CDZ02RR: Roborock S5 not charging - Error 13]]></title>
<description><![CDATA[<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Xiaomi_Roborock" class="header">Xiaomi Roborock</h3></div>
<p>Hi !</p>
<p>I have the problem Error 13 . In the robot changed the P185 fuse.</p>
<p>I have 2 charger. In same chaerger changed the condensator . Not some cheap, im using Nichicon 450v 68uF.</p>
<p>One charger working good, all ok, but the another not.</p>
<p>On the bad charger measuring 4,2v , if charged 20v.</p>
<p>Sometimes the robot starts charging, but after a few days it doesn't. Then I put the charger aside and after a few it's good again for a while.</p>
<p>In the bad charger changed again another <strong>Nichicon</strong> <strong>condenstor</strong> --- not working</p>
<p>Changed the <strong>ISA07N65A</strong> Mosfet ---- not working</p>
<p>what can i do? Have any idea ? Thanks</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_11_14_Num_23" class="header">Update (11/14/23)</h3></div>
<p>Hi <a class="user-mention-link notranslate" href="/User/4288385/hainzy">@hainzy</a> !</p>
<p>My question its moved so, i try answear here.</p>
<p>&quot;the Parts your replaced where faulty, or did you replace them without checking?</p>
<p>when you are already replacing parts you could also try to replace these:</p>
<p>- Mosfet B09N03 (EMB09N03H) or B09A03 (EMB09A03HP) - depending on the version</p>
<p>- Controller MAX8731A (MAX8731AETI+) or BQ24773 (ref BQ24773RUYT) - depending on the version</p>
<p>or you replace the whole board of the Robot, or the charger.</p>
<p>That would probably be easier...</p>
<p>But you did already check the battery, right? &quot;</p>
<p>The capacitator its fault , the mosfet i think not, but i have one new so i chang it.</p>
<p>The battery its good, with another charger allworking ok.</p>
<p>If i can buy, i will try change the Mosfet B09N03 and the Controller MAX8731A. Thanks,</p>
<p>⟐ Commented January 30, 2024 at 10:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/823675/Roborock+S5+not+charging+-+Error+13</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/823675</guid>
<pubDate>Tue, 30 Jan 2024 10:05:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xiaomi SDJQR02RR: How to clean dust from inside of sensors]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/NEdOaVmghgyUYvlr.standard" width="102" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/NEdOaVmghgyUYvlr.huge&quot;, '', 'width=540,height=1200')" /></div>
<p>Dust gets traped in sensors After a long while and prevents from working well.</p>
<p>How can this dust be removed?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/OUmwXms2NLg3en5S.standard" width="102" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/OUmwXms2NLg3en5S.huge&quot;, '', 'width=540,height=1200')" /></div>
<p>⟐ Edited by author January 02, 2026 at 7:08 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/933327/How+to+clean+dust+from+inside+of+sensors</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/933327</guid>
<pubDate>Fri, 02 Jan 2026 07:08:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xiaomi Robotic Vacuum Cleaner: Roidmi EVE CC can not read any map]]></title>
<description><![CDATA[<p>i have Roidmi EVE CC about a year and suddenly it seems like it cannot read any map not even the doc location. We didn't change the doc location. I deleted the map and create again but the same things.. it goes 2 meters away the doc making circles and after long time it says it will go back to the doc and never finds it. please help me</p>]]></description>
<link>https://www.ifixit.com/Answers/View/916621/Roidmi+EVE+CC+can+not+read+any+map</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/916621</guid>
<pubDate>Wed, 10 Sep 2025 21:20:28 -0700</pubDate>
</item>
</channel>
</rss>
