<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Xbox One Wireless Controller 1697&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Xbox_One_Wireless_Controller_1697?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Xbox One Wireless Controller 1697&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 28 Aug 2026 17:49:01 -0700</pubDate>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Xbox One Controller is Flashing Slowly and Won't Work.]]></title>
<description><![CDATA[<p>So, last night, I turned off my console for the night and went to bed. This morning, I tried to turn the controller (and the console) back on to play. The console worked fine, and started right up. However, my controller started to blink slowly, and none of the buttons work. I've tried syncing it, changing the batteries, and unplugging the console, but it's still blinking. It only stops after I take a battery out, or leave it alone for a while. But if I press it's power button, it just blinks away (slowly, if that matters). Help?</p>
<p>⟐ Commented August 11, 2026 at 21:13 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/476342/Xbox+One+Controller+is+Flashing+Slowly+and+Won&#039;t+Work.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/476342</guid>
<pubDate>Tue, 11 Aug 2026 21:13:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Is there a fix for directional "wandering" on Xbox one controllers?]]></title>
<description><![CDATA[<p>On all three of my XB1 controllers the arrow, reticle, or avatar will move or wander on its own even when not touching thumbsticks: IS THERE A FIX FOR THIS?? or is this how MS gets an extra $70 out of each Xbox owner every few months? ANYONE??</p>
<p>⟐ Edited January 07, 2021 at 16:48 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/361954/Is+there+a+fix+for+directional+%22wandering%22+on+Xbox+one+controllers</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/361954</guid>
<pubDate>Thu, 07 Jan 2021 16:48:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: My headset sporadically works]]></title>
<description><![CDATA[<p>On my 6 month old xbox one s controller, the headset seldom works. It worked fine for a while then all of the sudden it stops playing audio and recording. Then several days later I thought, &quot;what the heck maybe it was a fluke&quot; and it worked. Then the next day they no longer worked. I know it's not the headset because the work fine when plugged into a phone or computer and the xbox does register that they are connected. I can change the headset volume and all that but still no sound. Is the audio jack bad. If so, how to I fix this short of buying a new controller. Any help would be appreciated.</p>
<p>⟐ Commented December 08, 2020 at 11:40 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/408687/My+headset+sporadically+works</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/408687</guid>
<pubDate>Tue, 08 Dec 2020 11:40:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: I found two small white parts fot the xbox one controller]]></title>
<description><![CDATA[<p>When I was taking my xbox one controller apart to set my new shell and prts on it then i found two small pieces that fell put which idk where they go.</p>
<p>⟐ Commented May 17, 2021 at 22:06 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/334092/I+found+two+small+white+parts+fot+the+xbox+one+controller</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/334092</guid>
<pubDate>Mon, 17 May 2021 22:06:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Can I reverse some of the analog stick drift on my controller?]]></title>
<description><![CDATA[<p>I’ve had this Model 1697 controller for ~27 months (2 years, 7 months) and it’s now beginning to show the typical analog drift defect I’ve personally seen on multiple 1537’s. Admittedly I was never crazy about it because the 1697 is derived from the Model 1537, but I still kept mine around because it has always worked fine.</p>
<p>Part of the reason I’m hesitant to do any significant repairs is I know how unreliable the 1537/1697 controllers tend to be. My experience with both series is that they tend to break a lot more often then the 1708, whis is when they finally got it right. Mine isn't as bad as some we've  seen here before but it's showing early signs of the same  problem I keep seeing crop up. On top of that, the faceplate on mine has a screw hole crack, so it's forever one less screw without a new faceplate. The amount of drift varies by how much the stick moves, so it can be a non issue or impact the controller. However, it is always present to a point.</p>
<p>Since I know what it looks like, I had a suspicion it finally happened. I noticed it in one of the game menus on my PC games because I needed to charge my 1708 controller. Both are about the same age, but I do not have a reliable estimate for the 1708 because I did a total board swap on it due to damaged traces from my first stick only repair.</p>
<p>1697:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/fHICeeGWpBGnrHfR.standard" width="282" height="211" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/fHICeeGWpBGnrHfR.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>1708 (Repaired):</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/xZNoKQuryL1nfKcP.standard" width="282" height="211" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/xZNoKQuryL1nfKcP.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>Is there a way I can improve the situation to get a little more life out of it (reversible with new sticks)? I have 4 extra sticks (pulled from 1537 boards) I can try the stick only again once it fails if I cannot do anything to reduce the problem as well.</p>
<p>⟐ Answer accepted November 07, 2018 at 16:33 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/526906/Can+I+reverse+some+of+the+analog+stick+drift+on+my+controller</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/526906</guid>
<pubDate>Wed, 07 Nov 2018 16:33:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: My controller doesn't work with batteries]]></title>
<description><![CDATA[<p>My controller works but only with the USB cable plugged in. It will not work/turn on with batteries in. I have tried new batteries, clean metal conact in controller, updated via usb but still wont work with batteries just cable.</p>
<p>Does anyone have any ideas?</p>
<p>⟐ Answered January 07, 2021 at 8:57 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/369957/My+controller+doesn&#039;t+work+with+batteries</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/369957</guid>
<pubDate>Thu, 07 Jan 2021 08:57:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: How to fix my dpad?]]></title>
<description><![CDATA[<p>all dpad directions seemed to work fine, until the down button stopped working (left,right and up are fine)</p>
<p>⟐ Answered February 16, 2024 at 8:50 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/469133/How+to+fix+my+dpad</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/469133</guid>
<pubDate>Fri, 16 Feb 2024 08:50:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Why is my right trigger always activated even when i'm not pressing it]]></title>
<description><![CDATA[<p>My right trigger has been like this for a year now i am going to open it up once i get the tools and i am wondering if anyone knows what is wrong and how to fix it.</p>
<p>Thanks</p>
<p>⟐ Commented March 01, 2023 at 17:19 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/509258/Why+is+my+right+trigger+always+activated+even+when+i&#039;m+not+pressing+it</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/509258</guid>
<pubDate>Wed, 01 Mar 2023 17:19:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: My right analog stick on my Xbox One controller is not responding]]></title>
<description><![CDATA[<p>So, today I logged onto my Xbox to play some War Thunder. However, when I push the right analog stuck to the right, it does not receive the action I'm inputting. It is only for pushing it right, up, down and left work just fine. Can someone please explain to me what is happening, and what steps I can take to resolve the issue?</p>
<p>⟐ Answer edited December 02, 2020 at 13:22 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/579521/My+right+analog+stick+on+my+Xbox+One+controller+is+not+responding</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/579521</guid>
<pubDate>Wed, 02 Dec 2020 13:22:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: 3.5mm mic not working but can hear others.]]></title>
<description><![CDATA[<p>I can hear other people but they can't hear me, when I blow or talk into the mic my ring around my profile lights up like I'm talking. I've tested the mic on other devices and works. I've tried other mics but same thing happens. It's a turtle beach headset.</p>
<p>⟐ Answered December 04, 2020 at 19:33 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/405415/3.5mm+mic+not+working+but+can+hear+others.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/405415</guid>
<pubDate>Fri, 04 Dec 2020 19:33:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Does anyone make a MicroUSB cable that works well with this controller]]></title>
<description><![CDATA[<p>I've had this controller for 15 months and for the time I have owned it, I've never used the wireless because the Model 1697 controller only supports IR and USB connectivity. Because I don't own the wireless receiver and these controllers get terrible alkaline battery life, I've always used mine over MicroUSB to avoid having to buy batteries on a regular basis.</p>
<p>While this method works, I've been having a hard time finding a good MicroUSB cable that works well with this controller and doesn't wear out quickly.</p>
<p>The problem with these controllers is the connection is smaller then other MicroUSB connections. I have posted a picture of the connector in the controller for reference: (The Model 1697 controller is a minor refresh from the 1537, and the connector is the same)</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/HaGKDMXFJlFG4CkV.standard" width="282" height="211" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/HaGKDMXFJlFG4CkV.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>Are there any good cable options I should look for that work well with this controller, or is it more or less impossible to find a good one that's 3rd party? The official cable from the Play and Charge kit doesn't work without the battery and doesn't work as a wired cable on the PC. It blocks 5V with the battery or 3.3V without the battery. The PCB in the cable is designed so it only works on the Xbox One console with the battery installed.</p>
<p>⟐ Answer accepted February 07, 2018 at 21:37 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/459161/Does+anyone+make+a+MicroUSB+cable+that+works+well+with+this+controller</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/459161</guid>
<pubDate>Wed, 07 Feb 2018 21:37:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: USB c port is jammed]]></title>
<description><![CDATA[<p>i droped my controller on the floor with the cable in the usb c port and since then my controller is no longer detected by my computer and if won’t lock in the port. ( the cable still work, i have try with another cables )</p>
<p>how can i change/fix the usb-c port on my controller ?</p>
<p>⟐ Answered July 13, 2021 at 11:57 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/699004/USB+c+port+is+jammed</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/699004</guid>
<pubDate>Tue, 13 Jul 2021 11:57:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: How can I Replace the LB spring?]]></title>
<description><![CDATA[<p>My LB on my controller is broken. I know i need to replace the bumper itself but when you press on it you can still use the button but it does not come back up. What other part would i need to have replaced?</p>
<p>⟐ Answered March 01, 2019 at 12:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/551677/How+can+I+Replace+the+LB+spring</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/551677</guid>
<pubDate>Fri, 01 Mar 2019 12:51:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: My mic won't work with this]]></title>
<description><![CDATA[<p>I have a RIG100HX mic and whenever I plug it in to my Xbox One controller I have to rotate the mic wire in the controller until it works.  But after a while completely stopped working.</p>
<p>⟐ Answered June 11, 2018 at 21:39 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/492707/My+mic+won&#039;t+work+with+this</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/492707</guid>
<pubDate>Mon, 11 Jun 2018 21:39:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Left bumper stays stucks until I click the right bumper]]></title>
<description><![CDATA[<p>I recently bought a preowned Xbox One controller. Yesterday, I discovered that when I clicked the left bumper, it would stay down, as if were caught on something that wouldn’t let it click back into place. It only releases when I click the right bumper.</p>
<p>⟐ Answered May 17, 2018 at 6:58 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/486268/Left+bumper+stays+stucks+until+I+click+the+right+bumper</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/486268</guid>
<pubDate>Thu, 17 May 2018 06:58:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Is it possible to unpair the new controllers?]]></title>
<description><![CDATA[<p>I recently worked on two controllers for someone. In this deal, I got to keep the newer controller that had an issue with a bad RB button (which has been temporarily fixed) in exchange for recovering the firmware on a Model 1537.</p>
<p>On the 1537, there is a hardware flaw that allows unpairing if done correctly. I've detailed it in the previous post, found here: <a href="/Answers/View/347582/Is+it+possible+to+unpair+these+controllers">Is it possible to unpair these controllers?</a>. This didn't work, so I tried a similar, but different way of doing it on the new controllers:</p>
<ul><li>Plug it into a PC over USB (this is to get it to try to connect over Wireless)</li><li>Unplug the cable (this makes it try wireless)</li><li>Pair it away from the console, ensuring it can't get a signal</li></ul>
<p>The idea behind this was the pairing would &quot;erase&quot; because it gets invalidated and is considered unusable. This would work because the controller could not fetch clean pairing data.</p>
<p>The new controllers are not working with this method so this was clearly a (very useful) flaw in the hardware on the old controllers. It has since been fixed since the pairing is now persistent enough this no longer works or shows signs of working.</p>
<p>Is there a similar hardware flaw in these new controllers to do this like I did on the 1537's, or is this procedure not an option anymore and I can't get rid of it like I did on my old controller without the PC receiver?</p>
<p>⟐ Marked as duplicate October 10, 2017 at 14:18 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/399920/Is+it+possible+to+unpair+the+new+controllers</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/399920</guid>
<pubDate>Tue, 10 Oct 2017 14:18:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Will different parts from different model's work on this one?]]></title>
<description><![CDATA[<p>I heard that the 1697 model could fit button’s made for the xbox one elite controller is that true?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/546627/Will+different+parts+from+different+model&#039;s+work+on+this+one</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/546627</guid>
<pubDate>Fri, 01 Feb 2019 19:27:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: My controller has battery's I plugged it in it won't work]]></title>
<description><![CDATA[<p>My xbox controller fell of the bed witch is not that big of a fall nor it won't turn on anymore please help</p>
<p>⟐ Commented December 22, 2018 at 12:55 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/417273/My+controller+has+battery&#039;s+I+plugged+it+in+it+won&#039;t+work</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/417273</guid>
<pubDate>Sat, 22 Dec 2018 12:55:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: X-axis on left analog stick not properly responding + stick drift]]></title>
<description><![CDATA[<p>Hello,</p>
<p>As the title says, it seems my x-axis on my XB1 controller is inconsistent when it comes to responding. I'd say about 40% of the time, no input is detected by the controller when going left or right. This is also accompanied by stick drift when moving in the right direction for more than a few seconds.</p>
<p>Is this just a matter of replacing the joystick? Or does the actual module have to be replaced in order to fix this?</p>
<p>Also, my X, Home and B (although not as much) buttons are sticking. I've tried to fix this with isopropyl alcohol but that seems to only temporarily ease the problem. Should I replace those as well or could I clean them off if I disassemble the controller?</p>
<p>Thank you.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/473725/X-axis+on+left+analog+stick+not+properly+responding+++stick+drift</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/473725</guid>
<pubDate>Sun, 01 Apr 2018 22:23:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: How to remove the trigger pins holding the bracket?]]></title>
<description><![CDATA[<p>Hi, first time posting.</p>
<p>My Xbox one trigger has broken. I've found the root cause of my problem. The Trigger bracket (not the piece you unscrew), has snapped on one side. I need to remove the metal pin/rod that holds it and the spring in place.</p>
<p>However, I don't know how this pin is in place or how to pull it out. There's literally nothing on the internet about these pieces.</p>
<p>Help is appreciated</p>
<p>Regards</p>
<p>Jonathan</p>
<p>⟐ Commented March 07, 2024 at 21:49 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/461155/How+to+remove+the+trigger+pins+holding+the+bracket</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/461155</guid>
<pubDate>Thu, 07 Mar 2024 21:49:07 -0700</pubDate>
</item>
</channel>
</rss>
