<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Whirlpool Washing Machine&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Whirlpool_Washing_Machine?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Whirlpool Washing Machine&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 27 Aug 2026 12:15:17 -0700</pubDate>
<item>
<title><![CDATA[Whirlpool Washing Machine: How can I address the F1 error code?]]></title>
<description><![CDATA[<p>My Cabrio washing machine constantly stops during the wash cycle and shows an F1 error code. I hit pause and start at least 50 times over two hours to complete my wash. Is there a part I can replace so that my wash cycle operates properly?</p>
<p>⟐ Commented March 17, 2024 at 6:06 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/193013/How+can+I+address+the+F1+error+code</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/193013</guid>
<pubDate>Sun, 17 Mar 2024 06:06:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Washer fills with water, doesn't agitate but will spin out water?]]></title>
<description><![CDATA[<p>Whirlpool Ultimate Care 2 Model</p>
<p>After the washer fills with water the washer begins to hums loudly. The washer then begins to smell as if something is getting hot. The only function that really works after this point is if the washer is turned to the spin out cycle. The washer can spin out all of the water.</p>
<p>What is wrong and can I fix it? Thank you in advance for any help.</p>
<p>⟐ Commented July 27, 2026 at 1:40 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/154421/Washer+fills+with+water,+doesn&#039;t+agitate+but+will+spin+out+water</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/154421</guid>
<pubDate>Mon, 27 Jul 2026 01:40:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: whirpool top loader won't agitate or spin, does fill and drain]]></title>
<description><![CDATA[<p>Got an older Whirpool top loading washer (direct drive).  Fills and drains as expected, but won't agitate or spin.  The timer goes through the cycles as expected, and I can hear what sounds like a motor turning in there, but it doesn't translate into agitation or spin.</p>
<p>I don't think it's the lid switch as it does make the expected click, and it IIRC this washer will still agitate when the lid is open.</p>
<p>The other symptom is that I cannot turn the agitator with my hand.  Or I can only turn it a little bit.  Usually with the washer off I can turn it pretty well with just hand strength.  Does this indicate a broken coupler or clutch?</p>
<p>Thanks for your help!</p>
<p>⟐ Answered December 09, 2025 at 7:49 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/146662/whirpool+top+loader+won&#039;t+agitate+or+spin,+does+fill+and+drain</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/146662</guid>
<pubDate>Tue, 09 Dec 2025 07:49:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: washer has had the error codes F03 and E01.]]></title>
<description><![CDATA[<p>My whirlpool duet washer has had the error codes F03 and E01. The pressure switch has been replaced 3x’s with no results. Still get that error.</p>
<p>I pointed out that it may be an Air Dome Assembly per service bulletin for this model of washer with the model # WFW95HEDWO.  He, “The Tech” answer, even after I showed him the bulletin was “no I don’t think that the problem”.  How much is that part and how hard is it to replace?  Also, should I pursue this possible fix with Whirlpool?</p>
<p>Thank you,</p>
<p>Pat G.</p>
<p>⟐ Commented October 03, 2025 at 8:10 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/621860/washer+has+had+the+error+codes+F03+and+E01.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/621860</guid>
<pubDate>Fri, 03 Oct 2025 08:10:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool Cabrio Series 5000 Washing Machine stopped spinning at all, stopped draining now too]]></title>
<description><![CDATA[<p>Why did my washer stop draining and spinning?  I tried clearing out the drain, checked, removed and cleaned the drain pump, ran a diaganostic and ran a recalibration.   I am thinking the control actuator or shifter arm is bad but the stupid thing is only a year old.</p>
<div class="clearer"></div><div class="headerContainer"><h2 id="Section_Update" class="header">Update</h2></div>
<p>It WAS the shift actuator.  There were apparently several service bulletins, changes to the part and improvements before they got this problem under control.  I got the newest part available and I'm up and running again today.</p>
<p>⟐ Commented May 14, 2022 at 13:50 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/81543/Whirlpool+Cabrio+Series+5000+Washing+Machine+stopped+spinning+at+all,+stopped+draining+now+too</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/81543</guid>
<pubDate>Sat, 14 May 2022 13:50:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Won't spin loud noise]]></title>
<description><![CDATA[<p>Machine makes a horrendous noise almost like an alarm when running. Fills and drains ok, doesn't spin/agitate.</p>
<p>⟐ Answer edited January 10, 2017 at 4:42 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/143294/Won&#039;t+spin+loud+noise</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/143294</guid>
<pubDate>Tue, 10 Jan 2017 04:42:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: How to fix error code F08 or FOB]]></title>
<description><![CDATA[<p>Washing machine starts up and after 2 seconds it stops and this code came up. Have to reset the washer cause the door locks. Ive tried various different loads and even a empty load but no luck.</p>
<p>⟐ Answered October 15, 2025 at 1:50 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/388224/How+to+fix+error+code+F08+or+FOB</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/388224</guid>
<pubDate>Wed, 15 Oct 2025 01:50:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Why is my whirlpool cabrio washer leaking water on floor]]></title>
<description><![CDATA[<p>Why does my whirlpool Cabrio washer leak water on the floor during first fill</p>
<p>⟐ Answered October 15, 2025 at 1:46 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/522204/Why+is+my+whirlpool+cabrio+washer+leaking+water+on+floor</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/522204</guid>
<pubDate>Wed, 15 Oct 2025 01:46:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool lid lock bypass]]></title>
<description><![CDATA[<p>I have a Whirlpool wtw5000dw1  and I'm trying to bypass the lid lock by cutting the wires. They are res white and blue. Which two should I cut?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_29_Num_2019" class="header">Update (06/29/2019)</h3></div>
<p>*red, white, and blue</p>
<p>⟐ Commented June 20, 2026 at 6:30 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/575981/Whirlpool+lid+lock+bypass</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/575981</guid>
<pubDate>Sat, 20 Jun 2026 06:30:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Why I can't access diagnostic mode]]></title>
<description><![CDATA[<p>I installed a new control board and machine won't go into diagnostic mode. What is next step?</p>
<p>⟐ Commented November 17, 2024 at 11:27 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/501093/Why+I+can&#039;t+access+diagnostic+mode</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/501093</guid>
<pubDate>Sun, 17 Nov 2024 11:27:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Why does my washing machine make noise when not in use?]]></title>
<description><![CDATA[<p>I woke up this morning to a strange noise coming from my laundry room. My washer seemed to be making a noise that sounded like it was slightly running (not agitating or filling with water, just kind of humming). The noise stopped when I unplugged it. But when I tried to turn it on to run a cycle, nothing happened. None of the lights turned on or anything at all. When I plug it back in, the sound starts again after about 5 to 10 seconds.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_10_28_Num_23" class="header">Update (10/28/23)</h3></div>
<p>The noise seems to be coming from the water drainage hose. It is like it's trying to empty water from the machine but it's not turned on.</p>
<p>⟐ Commented February 02, 2026 at 15:03 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/821484/Why+does+my+washing+machine+make+noise+when+not+in+use</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/821484</guid>
<pubDate>Mon, 02 Feb 2026 15:03:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool washer error F25]]></title>
<description><![CDATA[<p>Hi,</p>
<p>A 3-year old Whirlpool washing machine stopped working. At the very beginning of the cycle it turns the drum a tiny bit and stops with the Draining red light blinking. I read error code and got F25.</p>
<p>I did what was was recommended here for similar questions: took off the front, wiggled all connectors on the control panel and what I could reach by hand at the bottom. There is no corrosion, all clean and tight.</p>
<p>Under the drum, I found a plastic part that broke off, see pic attached. I can’t find where it belongs to. Can it cause the issue here?</p>
<p>Other suggestions?</p>
<p>Thank you</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/iFvfyNIba24GCIC3.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/iFvfyNIba24GCIC3.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_10_08_Num_2019" class="header">Update (10/08/2019)</h3></div>
<p>Model WFC7500VW 2</p>
<p>TYPE: 826-02</p>
<p>MOD</p>
<p>Thank you</p>
<p>⟐ Commented July 21, 2022 at 20:44 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/595326/Whirlpool+washer+error+F25</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/595326</guid>
<pubDate>Thu, 21 Jul 2022 20:44:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Error code fo1 and e03]]></title>
<description><![CDATA[<p>What do these code mean an how do you fix them?  Also the door is locked and can not be opened.</p>
<p>⟐ Commented July 29, 2024 at 17:07 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/526960/Error+code+fo1+and+e03</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/526960</guid>
<pubDate>Mon, 29 Jul 2024 17:07:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: How to fix Whirlpool top load washer out of ballance problem]]></title>
<description><![CDATA[<p>Whirlpool /Maytag washer model MTW5840TW0 works great, except on the drain and spin cycle.  The drum starts to spin and the water drains.  Once all the water has drained the drum goes out of balance and hits the cabinet.  What could be the problem?  I’m thinking its the suspension springs, but just by visual inspection they are not broken or rusty.</p>
<p>⟐ Answered April 17, 2021 at 12:06 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/552745/How+to+fix+Whirlpool+top+load+washer+out+of+ballance+problem</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/552745</guid>
<pubDate>Sat, 17 Apr 2021 12:06:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: clothes still wet after spin cycle]]></title>
<description><![CDATA[<p>After spin cycle, clothes are still wet</p>
<p>⟐ Answered May 29, 2020 at 21:07 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/491394/clothes+still+wet+after+spin+cycle</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/491394</guid>
<pubDate>Fri, 29 May 2020 21:07:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool Duet Washer, No water Dispensing for Bleach area?]]></title>
<description><![CDATA[<p>Whirlpool Duet:  YWFW9151YW00<br /></p>
<p><br /></p>
<p>Hi there i have a Whirlpool Washer Front load, water dispenses properly for Detergent and Fabric softener, but NOT the bleach area, no water being dispensed so the Siphon will not activate itself.</p>
<p>Tray is fine tested in sink and works properly.</p>
<p>Any ideas what can be the problem.</p>
<p>⟐ Answer deleted August 12, 2019 at 21:20 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/572236/Whirlpool+Duet+Washer,+No+water+Dispensing+for+Bleach+area</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/572236</guid>
<pubDate>Mon, 12 Aug 2019 21:20:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Washing machine is off balance and will not use cold water]]></title>
<description><![CDATA[<p>Whirlpool Estate Heavy Duty Super Capacity. Model number <strong>ETW4400WQ0</strong></p>
<p>Just did a search on google and found this.  I made a mistake and washed a rug that apparently was too heavy and threw my washing machine off balance.</p>
<p>Now I cannot get the cold water to come into the machine. The hot water will come in but shuts back off after a minute and the only way I can get it filled is to turn it around and start it up again.</p>
<p>Over and over until it fills. If there is a easy repair without calling for a serviceman I would be eternally grateful.</p>
<p>⟐ Commented July 09, 2023 at 19:21 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/779339/Washing+machine+is+off+balance+and+will+not+use+cold+water</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/779339</guid>
<pubDate>Sun, 09 Jul 2023 19:21:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlppol Washer not spinning]]></title>
<description><![CDATA[<p>Whirlpool top loader washer model number WTW4800BQ1 will not spin or agitate.  After it fills with water the motor will kick on and it it will agitate for like one second and stop.  After sitting for a minute it will do the same thing again and then stops.  It never proceeds to wash and eventually will drain.  I have already replaced the lid switch thinking that was the issue.  I went through the diagnostic test mode and it showed F7-E5 and F7-E6 errors.  These coordinate to a shifter fault and a motor fault.  Since the motor turns I’m guessing shifter issue.  Thoughts…</p>
<p>⟐ Commented October 24, 2018 at 17:14 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/523614/Whirlppol+Washer+not+spinning</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/523614</guid>
<pubDate>Wed, 24 Oct 2018 17:14:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool Duet, model WFW9151YW00, won't go through spin cycle]]></title>
<description><![CDATA[<p>Whirlpool Duet front load washer, model WFW9151YW00, won't go through spin cycle but does agitate. It will drain most of the water no problem but then after the drum turns back and forth a few times, it pretty much just stops moving but the pump sounds like it's still trying to pump water out for a long time. But the little bit of water left seems like it's being pumped back and forth in the line. I can see the drain line that goes to the wall drain moving around like the machine is trying to get the water out but it appears the water is just going back and forth in the line. This goes on for several minutes until finally the machine just stops. It's a pretty loud pumping noise like a cycling back and forth sound. The pump has been replaced, the two control boards (front panel board and control board next to it) have been replaced but hasn't changed. Tried to run diagnostic test and was able to get it into diagnostic mode with the 123, 123, 123 pressing of 3 buttons but couldn't seem to get any error codes. I couldn't really figure out how to test things once in diagnostic mode. It did spin a bit, but pretty weakly in diagnostic mode at one point.  It also did a real weak spin when I ran a test wash. Left the towel I threw in totally wet.</p>
<p>Any ideas? There is another circuit board attached to the motor and it looked ok visually. I checked the wires coming out of the motor (3 wires) and got continuity between each one and nothing to ground so it appears the windings are not shorted. The machine seems to fill, agitate and drain the bulk of the water without any problem.</p>
<p>Thanks for any insights on this!</p>
<p>⟐ Commented August 19, 2025 at 19:34 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/440583/Whirlpool+Duet,+model+WFW9151YW00,+won&#039;t+go+through+spin+cycle</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/440583</guid>
<pubDate>Tue, 19 Aug 2025 19:34:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Why is my washer getting stuck on the rinse cycle?]]></title>
<description><![CDATA[<p>I have a Whirlpool washer model number WTW4816FW and when I try to do a cycle it will wash, but when it finishes the rinse cycle it starts rinsing all over again. I have been canceling my current wash and then restarting with a rinse and spin and it works fine. How do I fix it to where it will rinse in a normal wash without getting stuck on repeat?</p>
<p>⟐ Commented February 21, 2025 at 20:58 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/513069/Why+is+my+washer+getting+stuck+on+the+rinse+cycle</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/513069</guid>
<pubDate>Fri, 21 Feb 2025 20:58:46 -0700</pubDate>
</item>
</channel>
</rss>
