<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Vacuum Cleaner&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Vacuum_Cleaner/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Vacuum Cleaner&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 29 Aug 2026 01:00:15 -0700</pubDate>
<item>
<title><![CDATA[Dyson V15 Detect: Why is my laser stop working?..]]></title>
<description><![CDATA[<p>Hello folks! I just wanted to ask an question about Dyson V15 Detect laser head! One random day in 2024 the laser stopped working but the blue and yellow thing roll and suck things good as usual and the vacuum works. And i don't want to see 'put on the switch' bla bla cuz IT dont have the SWITCH AND IT ONLY have 'Fluffly Optic!🥰' and there is no hair in every roller if anyone is smarter like Albert please tell me what is wrong with it.😊</p>
<p>⟐ Edited by author August 27, 2026 at 7:03 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969941/Why+is+my+laser+stop+working..</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969941</guid>
<pubDate>Thu, 27 Aug 2026 07:03:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Qrevo S5V: Roborock Qrevo S5V dock power board (CPS036018) IC '21ASP' identification and open-collector configuration]]></title>
<description><![CDATA[<p>Troubleshooting component-level repair on Roborock Qrevo S5V docking station power supply board (PN: CPS036018). The SOT-23-5 IC marked '21ASP' has failed.</p>
<p>Bench measurements and trace analysis:</p>
<p>- Pin 2: GND (Vcc-)</p>
<p>- Pin 5: 10V Vcc+</p>
<p>- Pins 1 &amp; 3: AC line phase monitoring (zero-crossing/heartbeat inputs)</p>
<p>- Pin 4: Output running through a 10k resistor to the anode of a PC817 optocoupler (cathode to GND), sending the power-available heartbeat signal across to the secondary-side processor board.</p>
<p>Because Pin 4 drives an optocoupler LED via a 10k resistor rather than a standard logic trace, an open-collector/open-drain output configuration is actually required (sinking current through the optocoupler). We are looking for an exact cross-reference or identification for the '21ASP' SOT-23-5 IC matching this open-collector comparator or logic function.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969934/Roborock+Qrevo+S5V+dock+power+board+(CPS036018)+IC+&#039;21ASP&#039;+identification+and+open-collector+configuration</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969934</guid>
<pubDate>Thu, 27 Aug 2026 05:50:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Qrevo S5V: Roborock Qrevo S5V dock power board (CPS036018) IC '21ASP' replacement/identification]]></title>
<description><![CDATA[<p>Looking for component-level repair help for a Roborock Qrevo S5V docking station power supply board (PN: CPS036018). The IC marked '21ASP' in a SOT-23-5 package has failed or needs identification. Bench measurements show Pin 2 = GND, Pin 5 = 10V Vcc, Pin 4 = 4.6V, and Pins 1/3 = ~0.1V. Pin 4 is some sort of data line via an optocoupler sending information over to the processor board. Pins 1 and 3 are control or sensor lines.</p>
<p>Since replacement power boards are unavailable, does anyone know the exact cross-reference or functional equivalent for this IC?</p>
<p>⟐ Answered August 27, 2026 at 5:04 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969461/Roborock+Qrevo+S5V+dock+power+board+(CPS036018)+IC+&#039;21ASP&#039;+replacement-identification</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969461</guid>
<pubDate>Thu, 27 Aug 2026 05:04:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot Roomba 900 Series: error 6 cliff sensor move to new location all the time]]></title>
<description><![CDATA[<p>roomba 980 new  lithium battery, covered cliff sensors and it continues with ERROR 6  rebooted continues as soon as it  starts to leave the docking station it stops and ERROR 6 “move to a new location”  I covered the sensors with aluminum foil so IR should have activated.  Is it a sensor or is it  motherboard issue everything such as charging display all works.  Thank you  Antonio</p>
<p>⟐ Commented August 26, 2026 at 0:33 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/643697/error+6+cliff+sensor+move+to+new+location+all+the+time</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/643697</guid>
<pubDate>Wed, 26 Aug 2026 00:33:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson Small Ball: Replace the belt in Dyson small Ball]]></title>
<description><![CDATA[<p>How to get to the belt that drives the roller brush on a Dyson Small Ball Vacuum Cleaner ?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969730/Replace+the+belt+in+Dyson+small+Ball</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969730</guid>
<pubDate>Tue, 25 Aug 2026 22:42:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S8 MaxV Ultra: flexi arm won't spin]]></title>
<description><![CDATA[<p>any fixes for the flexi arm not spinning?</p>
<p>⟐ Commented August 24, 2026 at 18:09 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/939453/flexi+arm+won&#039;t+spin</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/939453</guid>
<pubDate>Mon, 24 Aug 2026 18:09:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[ZCWA BR151: BR151 Stuck in Docking Loop]]></title>
<description><![CDATA[<p>When you turn the unit on, and tell it to go home, it will find the base and align with it, center up, go up the ramp, then bump against the back wall of the charging base to only turn around and do it all over again. I have noticed that just as it contacts the back wall of the charging base, the plug light on top of the unit will go from green to red for just a second, then back to green. It will do this dance indefinitely. I wondered if the battery could be bad, but they ain't cheap and I don't want to buy a new one without knowing if this will solve the problem. Contacts were cleaned. Censors cleaned. Battery was pulled from unit for 30+ minutes. Anybody solved this problem?</p>
<p>Edited to add: I checked the voltage on the docking station and it is getting voltage. The feet on the docking station are springy so they are not stuck. Everything has been cleaned with rubbing alcohol.<br /><br />Edited again 8-24-2026:<br /><br />Changed the battery out, but the behavior persists. Suspect it is probably the charging board. Firmware update requires installing an app that wants far too much information for the purpose it fills. No way am I going to turn loose a robot from Shenzhen, China on my WiFi network that is all ready having issues with a ton of personal info. I don't see any other external ports to plug the robot in via usb either. Will put this in the junk pile. Maybe some other parts will find their way here someday and I can cannibalize those pieces into one working machine.</p>
<p>⟐ Edited by author August 24, 2026 at 17:39 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/967094/BR151+Stuck+in+Docking+Loop</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/967094</guid>
<pubDate>Mon, 24 Aug 2026 17:39:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Simple Way Pet Grooming Vacuum V10 XWLMQ01: How do I replace the trimming guards for the blade attachment]]></title>
<description><![CDATA[<p>I lost the blade attachments for the shaving part of the vacuum and I need to replace them.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969529/How+do+I+replace+the+trimming+guards+for+the+blade+attachment</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969529</guid>
<pubDate>Mon, 24 Aug 2026 11:04:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot Roomba J7 Plus: Cannot Factory Reset / No Sound]]></title>
<description><![CDATA[<p>Gifted a J7+ that was refurb from manufacturer. Replaced the battery and still having issues.</p>
<p>When attempting to register, it says device needs factory reset. After performing factory reset, it says it failed and to try again. I also do not hear any tones or sound. Any recommendations? I've tried numerous solutions but nothing seems to work.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969468/Cannot+Factory+Reset+-+No+Sound</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969468</guid>
<pubDate>Mon, 24 Aug 2026 05:09:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Black and Decker CHV1410 Dustbuster: What can I do to stop my vacuum from turning off every 10 seconds?]]></title>
<description><![CDATA[<p>The vacuum worked fine the first few times I used it, but it now turns off every couple seconds even when the battery level says it has charge.</p>
<p>⟐ Commented August 23, 2026 at 15:52 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/612375/What+can+I+do+to+stop+my+vacuum+from+turning+off+every+10+seconds</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/612375</guid>
<pubDate>Sun, 23 Aug 2026 15:52:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Black and Decker CHV1410 Dustbuster: Can I change my dust buster battery and if so where do I get it?]]></title>
<description><![CDATA[<p>Black and Decker dust buster CHV1410L built in rechargeable battery has died. Can I purchase a new battery? If so where?</p>
<p>⟐ Commented August 23, 2026 at 15:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/534648/Can+I+change+my+dust+buster+battery+and+if+so+where+do+I+get+it</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/534648</guid>
<pubDate>Sun, 23 Aug 2026 15:43:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Eufy RoboVac 30C: Replacement Rubber strip for the brush guard for Eufy 30c]]></title>
<description><![CDATA[<p>Help— to reduce wastage . have a Eufy 30c . Looking for replacement for the rubber strip in the brush guard rather than buying a new brush guard for Eufy 30c.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969339/Replacement+Rubber+strip+for+the+brush+guard+for+Eufy+30c</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969339</guid>
<pubDate>Sun, 23 Aug 2026 07:16:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[McCulloch MC-1275 Heavy Duty Steam Cleaner: Troubleshooting heats but not working]]></title>
<description><![CDATA[<p>When the button is pressed steam is not coming out.  I know that the machine is correctly heating to temperature and setam seeps in order to not over pressurize but not sure how to fix the problem</p>
<p>⟐ Commented August 21, 2026 at 22:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/390786/Troubleshooting+heats+but+not+working</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/390786</guid>
<pubDate>Fri, 21 Aug 2026 22:43:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[ZACO V5s pro robotic vacuum cleaner: All lights flash So what?]]></title>
<description><![CDATA[<p>Zaco V5s Pro's manual  indicates in case of  &quot;All lights flash&quot;: when robot in error.</p>
<p>I switched off both the loader and the robot. Then I switched on both the loader and the robot and got an undefined signal: upper lights on, middle and under lihgts flash.</p>
<p>So what can I do?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969105/All+lights+flash+So+what</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969105</guid>
<pubDate>Fri, 21 Aug 2026 10:14:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson DC58: The power keeps cutting out after a few seconds]]></title>
<description><![CDATA[<p>The battery is fully charged.</p>
<p>We press the trigger button and the the hoover works for a few seconds and then stops. It does this consistently</p>
<p>⟐ Commented August 19, 2026 at 21:08 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/463259/The+power+keeps+cutting+out+after+a+few+seconds</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/463259</guid>
<pubDate>Wed, 19 Aug 2026 21:08:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Irobot roomba combo: How to open up/deassemble the device? (video if possible)]]></title>
<description><![CDATA[<p>How to open up/deassemble the device? (video if possible)</p>
<p>R1138 model</p>
<p>⟐ Commented August 18, 2026 at 2:31 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/811667/How+to+open+up-deassemble+the+device+(video+if+possible)</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/811667</guid>
<pubDate>Tue, 18 Aug 2026 02:31:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson V6 Motorhead: Why is my Dyson going on an off when I'm holding the on button?]]></title>
<description><![CDATA[<p>Why is my Dyson going on an off when I'm holding the on button?</p>
<p>First let me say, the battery charges just fine and I’ve totally cleaned out the collection bin. I push the button to turn on the vacuum and it works, but then turns off and on over and over again while I’m still holding the button down.</p>
<p>I looked this up online and someone said the filter needed to be cleaned. So I took out the filter rinsed it as the online instructions said, let it dry, then put it back in. This did not solve the problem.</p>
<p>Any other suggestions?</p>
<p>⟐ Commented August 13, 2026 at 20:31 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/526482/Why+is+my+Dyson+going+on+an+off+when+I&#039;m+holding+the+on+button</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/526482</guid>
<pubDate>Thu, 13 Aug 2026 20:31:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot: My iRobot keeps saying error 26]]></title>
<description><![CDATA[<p>Hi I changed the filter, bag , and brush also checked if anything is stuck any where. I reset it but it does the same thing . Comes out of the charging station maybe about a foot or two out then stops and says error 26</p>
<p>⟐ Answered August 13, 2026 at 11:01 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/831253/My+iRobot+keeps+saying+error+26</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/831253</guid>
<pubDate>Thu, 13 Aug 2026 11:01:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Shark Rocket HV301: Brush Roll Not Turning On]]></title>
<description><![CDATA[<p>The brush roll will not turn on at all anymore. There seems to be no power getting to it. If I take the stick part off and attach it directly to the canister, it works. Do I need to buy a new stick? Where can I get one?</p>
<p>⟐ Commented August 13, 2026 at 8:10 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/389588/Brush+Roll+Not+Turning+On</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/389588</guid>
<pubDate>Thu, 13 Aug 2026 08:10:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot Roomba 600 Series: I can't hear the vacuum motor running. Less suction]]></title>
<description><![CDATA[<p>After I changed the rubber on the wheels. The vacuum seems far quieter as dosen't appear to be sucking as well as before</p>]]></description>
<link>https://www.ifixit.com/Answers/View/967931/I+can&#039;t+hear+the+vacuum+motor+running.+Less+suction</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/967931</guid>
<pubDate>Wed, 12 Aug 2026 20:03:57 -0700</pubDate>
</item>
</channel>
</rss>
