<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Toshiba Satellite Click 2 Pro&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Toshiba_Satellite_Click_2_Pro/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Toshiba Satellite Click 2 Pro&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 19 Aug 2026 03:22:04 -0700</pubDate>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: Can I replace the whole keyboard base?]]></title>
<description><![CDATA[<p>My Ctrl buttons stopped working a while ago. Now my mouse is staring to act up as well. I wanted to know if I can replace the whole keayboard and where to find one. I've tried checking online to no avail</p>
<p>⟐ Answered December 12, 2025 at 16:34 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/367025/Can+I+replace+the+whole+keyboard+base</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/367025</guid>
<pubDate>Fri, 12 Dec 2025 16:34:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: Device won't take a charge]]></title>
<description><![CDATA[<p>I know this is a very long question, but I attempted to be completely thorough about my troubleshooting steps taken and description of symptoms shown by the device so that it can help point whoever helps me fix this thing in the right direction (and with that becomes my new best friend too.)</p>
<p>Okay, So I need help running through this Toshiba Satellite Click (model W35Dt-A3300)</p>
<p>It was brought to me running on AC Adapter, but as soon as it's unplugged, it dies, the other technician replaced the battery in the base, however, this didn't fix the issue, and so it was pawned off on me the &quot;master&quot; technician (really just master researcher).</p>
<p>Okay, so this is what I did, I started with the assumption that the other technician completely flubbed the repair, as even with a new battery in the base, the device shows a red X next to the battery.</p>
<p>I took the tablet side apart and took the battery from the base (assuming this battery is good as it was just purchased - I'm not exactly sure how to test a battery using a multimeter) I swapped the battery in the tablet side with the battery in the base side (the base side was new,  and the tablet side is known bad, however the old base side is unknown whether to be good or bad) and plugged the charger directly into the tablet side.</p>
<p>No power on whatsoever, however, a very faint electrical hum can be heard coming from the mainboard underneath what appears to be the tablet CPU/GPU heatsink.</p>
<p>I use Multimeter to test Continuity throughout the DC Jack (at the plug, and then again at the solder joints the plug connects to) and all tested for continuity.</p>
<p>I plug the charger into the base side, with the bad battery in it, and the device now boots up. the red X is now gone, however, the moment the device is unplugged, the tablet side shuts down once again, and the battery gauge doesn't fill even after several hours of charging.</p>
<p>Obviously the fault lies within the current going from the board to the battery in the tablet side, and obviously the current which I believe IS reaching the mainboard from the DC Jack, is obviously experiencing some sort of ground fault.</p>
<p>My true question falls into the category of this: has anyone else dealt with this type of device and issue? What was your outcome?</p>
<p>Secondary and more important question I believe (teach a man to fish ya know?) How do I go about testing the electrical system to FIND this ground fault location? What settings on my multimeter need to be used to accurately test the individual legs of current flow in the device so I can find what exactly the problem is without just feeling like I totally failed this customer and have to say &quot;I dunno, bad motherboard?&quot; (I hate faulting the Mainboard and having to replace the entire thing.)</p>
<p>⟐ Commented September 28, 2020 at 22:50 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/301147/Device+won&#039;t+take+a+charge</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/301147</guid>
<pubDate>Mon, 28 Sep 2020 22:50:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: expandig the RAM more than 4GB?]]></title>
<description><![CDATA[<p>Can i expand the ram more than 4GB on this device ?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_09_28_Num_2017" class="header">Update (09/28/2017)</h3></div>
<p>SATELLITE CLICK 2 L30W-B-104</p>
<p>This is the device name and you can find all the information in this site</p>
<p><a href="http://www.toshiba.co.il/en/discontinued-products/satellite-click-2-l30w-b-104/" rel="nofollow noopener noreferrer" title="http://www.toshiba.co.il/en/discontinued-products/satellite-click-2-l30w-b-104/">http://www.toshiba.co.il/en/discontinued...</a></p>
<p>.. The company says that the maximum ram is 4 gb is this true...</p>
<p>⟐ Answer deleted November 29, 2018 at 11:55 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/429689/expandig+the+RAM+more+than+4GB</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/429689</guid>
<pubDate>Thu, 29 Nov 2018 11:55:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: What is the port next to the wifi card on the mother board.]]></title>
<description><![CDATA[<p>I was wondering if anybody knew what the port is next to the wifi card towards the battery on the mother board. It looks like the same thing as the wifi card spot except its a little bit larger and it does not have the plastic female connector on the motherboard like where the wifi card attaches to on the motherboard. I figure it might have been an option in the design to be able to upgrade to a better graphics card or additional ram or something along those lines. I fear I may only get the answer from a Toshiba Engineer or somebody that is extremely well versed in modern day laptop circuit board design. So if anybody could help it would be greatly appreciated, the curiosity is killing me.</p>
<p>⟐ Answered October 27, 2017 at 2:17 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/436548/What+is+the+port+next+to+the+wifi+card+on+the+mother+board.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/436548</guid>
<pubDate>Fri, 27 Oct 2017 02:17:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: Why can’t I push down certain keys on my laptop?]]></title>
<description><![CDATA[<p>I don’t know why, but certain keys don't push down whenever I type. What can the problem be?</p>
<p>⟐ Answer edited July 07, 2017 at 8:14 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/303582/Why+can%E2%80%99t+I+push+down+certain+keys+on+my+laptop</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/303582</guid>
<pubDate>Fri, 07 Jul 2017 08:14:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: How to replace my screen]]></title>
<description><![CDATA[<p>do i have to completely tear down my p35w-b3226 to replace the screen?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/368544/How+to+replace+my+screen</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/368544</guid>
<pubDate>Mon, 16 Jan 2017 11:04:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: CTRL buttons not working]]></title>
<description><![CDATA[<p>My CTRL buttons don't work anymore. I contacted a repair shop and they say they may have tor eplace the whole keyboard, which means the whole base of the laptop. Which defies the whole purpose of taking it to them. I guess I can just buy one myself. My question is is it possible to get just the keyboard on the market?</p>
<p>Also is it possible to fix the buttons without having to change the whole base?</p>
<p>⟐ Commented October 26, 2016 at 10:41 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/347545/CTRL+buttons+not+working</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/347545</guid>
<pubDate>Wed, 26 Oct 2016 10:41:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: Keyboard Dock . Click Mechanism broken]]></title>
<description><![CDATA[<p>I think the hinge(s) are broken in the Key Dock ,so I can't clip it in correctly and move it back</p>
<p>I can only use it as a tablet right now , which is pretty anoying .</p>
<p>Question :   How can I open the cover of the hinges ( Key Dock ) and where can I get new ones ?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/326904/Keyboard+Dock+.+Click+Mechanism+broken</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/326904</guid>
<pubDate>Thu, 28 Jul 2016 14:47:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: My computer is overheating a lot and I don’t know why]]></title>
<description><![CDATA[<p>I have been using my laptop a lot lately and I noticed that it is getting really hot on my lap. It will occasionally shut down if it gets too hot. Is there any quick fixes to the issue?</p>
<p>⟐ Commented June 25, 2016 at 5:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/303576/My+computer+is+overheating+a+lot+and+I+don%E2%80%99t+know+why</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/303576</guid>
<pubDate>Sat, 25 Jun 2016 05:51:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: Why isn’t my computer holding a charge]]></title>
<description><![CDATA[<p>My computer works when the charger is plugged in but every time I disconnect the charger the laptop dies.</p>
<p>⟐ Edited April 07, 2016 at 12:50 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/303570/Why+isn%E2%80%99t+my+computer+holding+a+charge</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/303570</guid>
<pubDate>Thu, 07 Apr 2016 12:50:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: How can I fix my LED keyboard?]]></title>
<description><![CDATA[<p>My keyboard works perfectly well but the strip that supports the tablet is stuck/jam in one place. It can no longer properly close nor align straight as it used to. The two supporting metal guards that hold the tablet broke off but the middle supporting chip that interacts with the tablet is fully functional and working properly, Besides the keyboard still lights up and all the ports are working properly.</p>
<p>Please let me know if it can be fixed. Thanks</p>]]></description>
<link>https://www.ifixit.com/Answers/View/271503/How+can+I+fix+my+LED+keyboard</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/271503</guid>
<pubDate>Wed, 18 Nov 2015 19:22:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: Can I install it the 2nd ssd]]></title>
<description><![CDATA[<p>is it possible to install the 2nd ssd  in the dock. thanks</p>
<p>⟐ Answered October 22, 2015 at 2:42 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/264928/Can+I+install+it+the+2nd+ssd</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/264928</guid>
<pubDate>Thu, 22 Oct 2015 02:42:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Toshiba Satellite Click 2 Pro: as changing the ssd]]></title>
<description><![CDATA[<p>I bought this machine and wine with ssd damaged and need replacing</p>]]></description>
<link>https://www.ifixit.com/Answers/View/227196/as+changing+the+ssd</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/227196</guid>
<pubDate>Thu, 30 Apr 2015 15:54:25 -0700</pubDate>
</item>
</channel>
</rss>
