<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;System76 Laptop&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/System76_Laptop?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;System76 Laptop&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 28 Aug 2026 14:28:45 -0700</pubDate>
<item>
<title><![CDATA[System76 Gazelle Professional 9: Looking for a replacement cooling fan for this device.]]></title>
<description><![CDATA[<p>The fan on the right side is failing and needs replacement.  I am looking for help finding one.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/310600/Looking+for+a+replacement+cooling+fan+for+this+device.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/310600</guid>
<pubDate>Tue, 10 May 2016 18:27:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[System76 Oryx Pro: How do you replace the display?]]></title>
<description><![CDATA[<p>The question is in the title. System76 provides only limited repairs, like replacing the memory or replacing the thermal compound on the CPU and GPU. However, they don't provide detailed instructions for a display replacement or the display data (eDP) cable. For such repairs, their customer service claim the repairs are too difficult for the average repair person, and refer to sending the laptop back for display replacement.</p>
<p>I disagree with their claim. I already disassembled the laptop down to the lower bezel. The steps I took are (in order):</p>
<ol><li>removed the bottom  (case);</li><li>removed the battery;</li><li>disconnected the fan connectors;</li><li>removed the heatsink and fans assembly. This exposes the eDP and backlight connectors, and the access to the screen hinges;</li><li>release the hinges friction, then disconnect the top part of the hinges;</li><li>separate the hinge cover. (The hinge cover is kept in place by internal plastic clips. Using a plastic separation tool, like a plastic Jimmy or a blue opening tool), you can separate the two halves of the hinge cover, which also covers the eDP connector, the WI-Fi antennas, and the LCD backlight LEDs connector.</li></ol>
<p>The issue now is the top bezel: it doesn't provide a clue about how it's mounted. The hinge cover is connected to the top bezel through a flexible material (tape? Plastic hinge? I don't know yet.)</p>
<p>Thus, my question: any ideas about how could the top bezel be attached?</p>
<p>If I manage to get to the display, I will make and post a complete guide.</p>
<p>Thank you for your consideration.</p>
<p>⟐ Commented February 19, 2026 at 12:44 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/939995/How+do+you+replace+the+display</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/939995</guid>
<pubDate>Thu, 19 Feb 2026 12:44:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[System76 Laptop: System 76 Pangolin 15 Charging Port Repair]]></title>
<description><![CDATA[<p>While plugging in the charging cord for my System76 Pang15, the charging port came loose and became pushed inside the case. I was able to get it back out, and I glued it in place; however, now it will not charge when plugged in. I have tried multiple chords to no success. How may I go about fixing this?</p>
<p>⟐ Answered June 24, 2025 at 22:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/904799/System+76+Pangolin+15+Charging+Port+Repair</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/904799</guid>
<pubDate>Tue, 24 Jun 2025 22:51:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[System76 Oryx Pro: System76 Oryx Pro ORXP1 Laptop Flashing green and orange lights]]></title>
<description><![CDATA[<p>Laptop Flashing green and orange lights , power button and keyboard flashes on and off.</p>
<p>⟐ Answer accepted October 28, 2024 at 8:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/819269/System76+Oryx+Pro+ORXP1+Laptop+Flashing+green+and+orange+lights</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/819269</guid>
<pubDate>Mon, 28 Oct 2024 08:51:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[System76 Galago Pro: Screen keeps goin black like it’s on standby]]></title>
<description><![CDATA[<p>Screen keeps goin black as if it turns to standby. Have to hit power to make screen come back</p>
<p>⟐ Answered March 18, 2024 at 15:12 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/841354/Screen+keeps+goin+black+like+it%E2%80%99s+on+standby</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/841354</guid>
<pubDate>Mon, 18 Mar 2024 15:12:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[System76 Laptop: Replacement keyborad for Kudo2 sys76 laptop]]></title>
<description><![CDATA[<p>Is it possible to purchase a replacement keypboard for a sys76 Kudo2 17.3” laptop, and get instructions for how to install it?</p>
<p>⟐ Answer accepted September 13, 2019 at 5:19 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/545942/Replacement+keyborad+for+Kudo2+sys76+laptop</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/545942</guid>
<pubDate>Fri, 13 Sep 2019 05:19:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[System76 Oryx Pro: Tools to break down 2018 Oryx Pro (Oryp4)]]></title>
<description><![CDATA[<p>Wondered if you guys had some tools available for working on an Oryp4 laptop.  I just need enough to replace battery and/or SSD install.</p>
<p>⟐ Commented August 19, 2019 at 15:47 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/585060/Tools+to+break+down+2018+Oryx+Pro+(Oryp4)</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/585060</guid>
<pubDate>Mon, 19 Aug 2019 15:47:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[System76  Darter Pro: none of the USB C working]]></title>
<description><![CDATA[<p>Both USB C port suddenly stopped working</p>
<p>⟐ Commented January 20, 2025 at 18:11 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/884570/none+of+the+USB+C+working</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/884570</guid>
<pubDate>Mon, 20 Jan 2025 18:11:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[System76 Laptop: Looking for touchpad replacement for lemp9]]></title>
<description><![CDATA[<p>I have random mouse movement/clicks from the touchpad after some heavy use. The touchpad is for Lemur Pro 9. Is there information on what product this is and where to buy?</p>
<p>Code on the sticker:<br />S201221DAG1277<br />SA464C-1204</p>
<p>Chip: <br />333610-3000<br />1740 8JC17A66</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/xFMgFkUHUgggwt2j.standard" width="282" height="170" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/xFMgFkUHUgggwt2j.huge&quot;, '', 'width=1600,height=961')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/WoLI2VDhYCkRvZH4.standard" width="282" height="178" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/WoLI2VDhYCkRvZH4.huge&quot;, '', 'width=1600,height=1013')" /></div>
<p>⟐ Reopened October 08, 2021 at 8:20 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/708063/Looking+for+touchpad+replacement+for+lemp9</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/708063</guid>
<pubDate>Fri, 08 Oct 2021 08:20:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[System76 Laptop: System76 oryx pro: No start screen]]></title>
<description><![CDATA[<p>Day before yesterday, I was using my laptop just fine. After I was done with it, I  shut it down like normal. But this morning. When I tried to start it up.  I pushed the power button, the light comes on. The light for prong  symbol/ power comes on green at first. Then it goes to yellow blinking  light. for a couple of time then solid yellow before the laptop shuts  down.  So today and yesterday I took out my ram, memory stick, and unplugged then re plugged everything, and the screen still doesn’t come on but there is a quite buzzing sound from my laptop during the whole start up and then shut itself off since day one(if that helps). Asked the team of system76 they are not helpful at this point, literally bought this a year, some change and no warranty, no help. Needing some help, please.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/667758/System76+oryx+pro:+No+start+screen</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/667758</guid>
<pubDate>Tue, 24 Nov 2020 17:04:43 -0700</pubDate>
</item>
</channel>
</rss>
