<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Ryobi Pressure Washer&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Ryobi_Pressure_Washer?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Ryobi Pressure Washer&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 13 Jul 2026 23:50:27 -0700</pubDate>
<item>
<title><![CDATA[Ryobi Pressure Washer RY14122 2013: Removing hose from spray gun and pump housing]]></title>
<description><![CDATA[<p>How do you remove the spray hose from the spray gun and the pump housing? Rubber gaskets seem to be frozen on place. I don't what to force it and possibly damage something. I'm missing something.</p>
<p>⟐ Answer accepted August 05, 2025 at 2:10 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/885707/Removing+hose+from+spray+gun+and+pump+housing</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/885707</guid>
<pubDate>Tue, 05 Aug 2025 02:10:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda GCV160 Pressure Washer: Where is the fuel filter? What is the replacement unit?]]></title>
<description><![CDATA[<p>Where is the fuel filter?</p>
<p>⟐ Answer edited May 08, 2025 at 0:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/899207/Where+is+the+fuel+filter+What+is+the+replacement+unit</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/899207</guid>
<pubDate>Thu, 08 May 2025 00:05:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi Pressure Washers RY80942 2020: Where can I buy the uploader valve]]></title>
<description><![CDATA[<p>where can i buy the uploader valve</p>
<p>⟐ Commented May 13, 2024 at 16:15 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/849386/Where+can+I+buy+the+uploader+valve</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/849386</guid>
<pubDate>Mon, 13 May 2024 16:15:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda GCV160 Pressure Washer: Pressure washer runs with choke on but stalls when choke off]]></title>
<description><![CDATA[<p>I bought a used pressure washer that had a host of issues and I think I'm close to getting it running right. Here's what's been done so far.</p>
<p>Cleared blockage in Nozzle, cleaned carb (2x), replaced spark plug, fuel cap cleaned, air filter good, fuel lines and filter clear, replaced unloader, had to cut the inlet connector off as it was corroded to the hose and replaced, checked for intake leaks and all looks good.</p>
<p>Im still having an issue where with the choke on, I can hear the engine cycling. The water pressure builds and I can see the unloader move and unload pressure. When pulling the trigger with choke on, constant, albeit lower pressure and cycling stops. When put into run, the engine surges, backfires, and/or stalls out completely. Im not sure what else I can check other than replacing the carburator all together or replacing check valves in the pump. Maybe the unloader isn't set right? Hopefully this is repairable and I can get it running at 100% with your help</p>]]></description>
<link>https://www.ifixit.com/Answers/View/934602/Pressure+washer+runs+with+choke+on+but+stalls+when+choke+off</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/934602</guid>
<pubDate>Tue, 06 Jan 2026 20:21:58 -0700</pubDate>
</item>
</channel>
</rss>
