<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Robotic Vacuum Cleaner&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Robotic_Vacuum_Cleaner/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Robotic Vacuum Cleaner&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 30 Aug 2026 02:30:00 -0700</pubDate>
<item>
<title><![CDATA[Roborock Qrevo S5V: Roborock Qrevo S5V dock power board (CPS036018) IC '21ASP' identification and open-collector configuration]]></title>
<description><![CDATA[<p>Troubleshooting component-level repair on Roborock Qrevo S5V docking station power supply board (PN: CPS036018). The SOT-23-5 IC marked '21ASP' has failed.</p>
<p>Bench measurements and trace analysis:</p>
<p>- Pin 2: GND (Vcc-)</p>
<p>- Pin 5: 10V Vcc+</p>
<p>- Pins 1 &amp; 3: AC line phase monitoring (zero-crossing/heartbeat inputs)</p>
<p>- Pin 4: Output running through a 10k resistor to the anode of a PC817 optocoupler (cathode to GND), sending the power-available heartbeat signal across to the secondary-side processor board.</p>
<p>Because Pin 4 drives an optocoupler LED via a 10k resistor rather than a standard logic trace, an open-collector/open-drain output configuration is actually required (sinking current through the optocoupler). We are looking for an exact cross-reference or identification for the '21ASP' SOT-23-5 IC matching this open-collector comparator or logic function.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969934/Roborock+Qrevo+S5V+dock+power+board+(CPS036018)+IC+&#039;21ASP&#039;+identification+and+open-collector+configuration</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969934</guid>
<pubDate>Thu, 27 Aug 2026 05:50:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Qrevo S5V: Roborock Qrevo S5V dock power board (CPS036018) IC '21ASP' replacement/identification]]></title>
<description><![CDATA[<p>Looking for component-level repair help for a Roborock Qrevo S5V docking station power supply board (PN: CPS036018). The IC marked '21ASP' in a SOT-23-5 package has failed or needs identification. Bench measurements show Pin 2 = GND, Pin 5 = 10V Vcc, Pin 4 = 4.6V, and Pins 1/3 = ~0.1V. Pin 4 is some sort of data line via an optocoupler sending information over to the processor board. Pins 1 and 3 are control or sensor lines.</p>
<p>Since replacement power boards are unavailable, does anyone know the exact cross-reference or functional equivalent for this IC?</p>
<p>⟐ Answered August 27, 2026 at 5:04 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969461/Roborock+Qrevo+S5V+dock+power+board+(CPS036018)+IC+&#039;21ASP&#039;+replacement-identification</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969461</guid>
<pubDate>Thu, 27 Aug 2026 05:04:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot Roomba 900 Series: error 6 cliff sensor move to new location all the time]]></title>
<description><![CDATA[<p>roomba 980 new  lithium battery, covered cliff sensors and it continues with ERROR 6  rebooted continues as soon as it  starts to leave the docking station it stops and ERROR 6 “move to a new location”  I covered the sensors with aluminum foil so IR should have activated.  Is it a sensor or is it  motherboard issue everything such as charging display all works.  Thank you  Antonio</p>
<p>⟐ Commented August 26, 2026 at 0:33 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/643697/error+6+cliff+sensor+move+to+new+location+all+the+time</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/643697</guid>
<pubDate>Wed, 26 Aug 2026 00:33:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S8 MaxV Ultra: flexi arm won't spin]]></title>
<description><![CDATA[<p>any fixes for the flexi arm not spinning?</p>
<p>⟐ Commented August 24, 2026 at 18:09 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/939453/flexi+arm+won&#039;t+spin</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/939453</guid>
<pubDate>Mon, 24 Aug 2026 18:09:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[ZCWA BR151: BR151 Stuck in Docking Loop]]></title>
<description><![CDATA[<p>When you turn the unit on, and tell it to go home, it will find the base and align with it, center up, go up the ramp, then bump against the back wall of the charging base to only turn around and do it all over again. I have noticed that just as it contacts the back wall of the charging base, the plug light on top of the unit will go from green to red for just a second, then back to green. It will do this dance indefinitely. I wondered if the battery could be bad, but they ain't cheap and I don't want to buy a new one without knowing if this will solve the problem. Contacts were cleaned. Censors cleaned. Battery was pulled from unit for 30+ minutes. Anybody solved this problem?</p>
<p>Edited to add: I checked the voltage on the docking station and it is getting voltage. The feet on the docking station are springy so they are not stuck. Everything has been cleaned with rubbing alcohol.<br /><br />Edited again 8-24-2026:<br /><br />Changed the battery out, but the behavior persists. Suspect it is probably the charging board. Firmware update requires installing an app that wants far too much information for the purpose it fills. No way am I going to turn loose a robot from Shenzhen, China on my WiFi network that is all ready having issues with a ton of personal info. I don't see any other external ports to plug the robot in via usb either. Will put this in the junk pile. Maybe some other parts will find their way here someday and I can cannibalize those pieces into one working machine.</p>
<p>⟐ Edited by author August 24, 2026 at 17:39 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/967094/BR151+Stuck+in+Docking+Loop</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/967094</guid>
<pubDate>Mon, 24 Aug 2026 17:39:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot Roomba J7 Plus: Cannot Factory Reset / No Sound]]></title>
<description><![CDATA[<p>Gifted a J7+ that was refurb from manufacturer. Replaced the battery and still having issues.</p>
<p>When attempting to register, it says device needs factory reset. After performing factory reset, it says it failed and to try again. I also do not hear any tones or sound. Any recommendations? I've tried numerous solutions but nothing seems to work.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969468/Cannot+Factory+Reset+-+No+Sound</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969468</guid>
<pubDate>Mon, 24 Aug 2026 05:09:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Eufy RoboVac 30C: Replacement Rubber strip for the brush guard for Eufy 30c]]></title>
<description><![CDATA[<p>Help— to reduce wastage . have a Eufy 30c . Looking for replacement for the rubber strip in the brush guard rather than buying a new brush guard for Eufy 30c.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969339/Replacement+Rubber+strip+for+the+brush+guard+for+Eufy+30c</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969339</guid>
<pubDate>Sun, 23 Aug 2026 07:16:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[ZACO V5s pro robotic vacuum cleaner: All lights flash So what?]]></title>
<description><![CDATA[<p>Zaco V5s Pro's manual  indicates in case of  &quot;All lights flash&quot;: when robot in error.</p>
<p>I switched off both the loader and the robot. Then I switched on both the loader and the robot and got an undefined signal: upper lights on, middle and under lihgts flash.</p>
<p>So what can I do?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969105/All+lights+flash+So+what</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969105</guid>
<pubDate>Fri, 21 Aug 2026 10:14:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Irobot roomba combo: How to open up/deassemble the device? (video if possible)]]></title>
<description><![CDATA[<p>How to open up/deassemble the device? (video if possible)</p>
<p>R1138 model</p>
<p>⟐ Commented August 18, 2026 at 2:31 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/811667/How+to+open+up-deassemble+the+device+(video+if+possible)</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/811667</guid>
<pubDate>Tue, 18 Aug 2026 02:31:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot: My iRobot keeps saying error 26]]></title>
<description><![CDATA[<p>Hi I changed the filter, bag , and brush also checked if anything is stuck any where. I reset it but it does the same thing . Comes out of the charging station maybe about a foot or two out then stops and says error 26</p>
<p>⟐ Answered August 13, 2026 at 11:01 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/831253/My+iRobot+keeps+saying+error+26</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/831253</guid>
<pubDate>Thu, 13 Aug 2026 11:01:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot Roomba 600 Series: I can't hear the vacuum motor running. Less suction]]></title>
<description><![CDATA[<p>After I changed the rubber on the wheels. The vacuum seems far quieter as dosen't appear to be sucking as well as before</p>]]></description>
<link>https://www.ifixit.com/Answers/View/967931/I+can&#039;t+hear+the+vacuum+motor+running.+Less+suction</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/967931</guid>
<pubDate>Wed, 12 Aug 2026 20:03:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Shark Matrix RV2310: How to replace the side brush motor]]></title>
<description><![CDATA[<p>Side brush motor has stopped working. It spins freely by hand. Need to replace the motor.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/967219/How+to+replace+the+side+brush+motor</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/967219</guid>
<pubDate>Fri, 07 Aug 2026 14:04:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot VR9000: C13 error displayed on screen]]></title>
<description><![CDATA[<p>What is the C13 error ? Displayed on the screen ?</p>
<p>⟐ Commented July 30, 2026 at 0:09 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/876598/C13+error+displayed+on+screen</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/876598</guid>
<pubDate>Thu, 30 Jul 2026 00:09:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Robotic Vacuum Cleaner: im going crazy help requested]]></title>
<description><![CDATA[<p>i bought this vacuum <ins><a href="https://www.amazon.com/dp/B0DR8NJMCJ?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_5&amp;tag=ifixitam-20" rel="nofollow noopener noreferrer" title="https://www.amazon.com/dp/B0DR8NJMCJ?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_5" target="_blank">https://www.amazon.com/dp/B0DR8NJMCJ?ref...</a></ins> ECOVACS DEEBOT X8 PRO OMNI Robot Vacuum 1 year ago.</p>
<p>recently the main brush motor stopped spinning so i opened it up to replace the motor. i have now bought 3 different replacement motors that say they are for the T8 or 8x. but none of them fit correctly. i have searched like crazy but can not for the life of my find my motor anywhere online. (pictures below) am i crazy? are these no longer in production? is one of the other motors supposed to fit even though the L shape is wrong? your wisdom is appreciated.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/CYJb4DOtRwNjlns4.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/CYJb4DOtRwNjlns4.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/rZadmigDWZZeMQiR.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/rZadmigDWZZeMQiR.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_18_Num_26" class="header">Update (06/18/26)</h3></div>
<p>ok so with some inspiration from oldturkey03 i think im close. im going to walk through what i did if anyone else is ballzie enough to try this.</p>
<p>so i decided i was going to transfer the old L drive shaft to the new motor. i started by unclipping the snaps around the perimeter (picture1).</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/dZupmUgNNRyxs3RF.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/dZupmUgNNRyxs3RF.full&quot;, '', 'width=718,height=957')" /></div>
<p>once inside i cleaned all the gears as they were very full of dirty grease (picture2).</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/NLeEkIZIwqNiCPDH.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/NLeEkIZIwqNiCPDH.full&quot;, '', 'width=718,height=957')" /></div>
<p>i then removed the two screws on the left side of the image (picture3) (this is where the motor attaches) and screwed in the new motor.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/taSlOHAQePjFx425.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/taSlOHAQePjFx425.full&quot;, '', 'width=718,height=957')" /></div>
<p>but as i put it back together i realized that the gear attached to the new motor was beveled to the left but all the old gears were beveled to the right! so i pried the motor gear off of the old motor and transferred it to the new one. (be careful when prying off it toke a lot of force and mine ended up half way across the room in my white shag carpet. much cussing ensued.)</p>
<p>ive got all the pieces together and clean now i guess the last thing i need is to figure out what kind of lubricant to use on the gears. any ideas?</p>
<p>⟐ Commented July 26, 2026 at 12:09 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/959813/im+going+crazy+help+requested</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/959813</guid>
<pubDate>Sun, 26 Jul 2026 12:09:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ecovacs DEEBOT T30S: How to fix mop function?]]></title>
<description><![CDATA[<p>Appears water isn't coming out of the vacuum to soak the mopping pads. I don't think water is getting into the storage compartment of the vacuum itself. How to troubleshoot and fix?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/965100/How+to+fix+mop+function</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/965100</guid>
<pubDate>Thu, 23 Jul 2026 13:54:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Shark Matrix RV2310: My side brush keeps coming off.]]></title>
<description><![CDATA[<p>Side brush keeps falling off</p>
<p>⟐ Commented July 21, 2026 at 14:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/896324/My+side+brush+keeps+coming+off.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/896324</guid>
<pubDate>Tue, 21 Jul 2026 14:43:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ecovacs DEEBOT DN622.11: How do I put my dee bot back together again]]></title>
<description><![CDATA[<p>I got this deebot for cheep and disassembled it a few years ago I still have all the hardware I just need help putting it back together as I never reassembled it any help would be appreciated</p>
<p>⟐ Commented July 15, 2026 at 18:28 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/964002/How+do+I+put+my+dee+bot+back+together+again</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/964002</guid>
<pubDate>Wed, 15 Jul 2026 18:28:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot Roomba i7: I bought a baterie compatible with roombai7]]></title>
<description><![CDATA[<p>hi</p>
<p>i bought a batrie to my roombai7 that you said that was compatible but my roomba said that not ricognize</p>]]></description>
<link>https://www.ifixit.com/Answers/View/963780/I+bought+a+baterie+compatible+with+roombai7</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/963780</guid>
<pubDate>Mon, 13 Jul 2026 09:20:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xiaomi Mi Vacuum-Mop Essential: Can I purchase replacement parts?]]></title>
<description><![CDATA[<p>Are replacement parts available for purchase such as filter, mop etc?</p>
<p>⟐ Answered July 11, 2026 at 18:48 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/963545/Can+I+purchase+replacement+parts</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/963545</guid>
<pubDate>Sat, 11 Jul 2026 18:48:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S7 Max Ultra: Roborock S7 Max Ultra won't auto-empty bin after cleaning]]></title>
<description><![CDATA[<p>Hi all,</p>
<p>I'm trying to figure out whether I'm dealing with a hardware fault or a software/firmware bug on my Roborock S7 Max Ultra.</p>
<p><strong>Firmware:</strong> v02.26.80 (currently up to date, per the app)</p>
<p><strong>The problem:</strong> After the robot finishes a cleaning cycle, it does not automatically empty its bin into the dock. This happens regardless of whether the auto-empty setting is on &quot;Smart&quot; or &quot;Max.&quot;</p>
<p><strong>What works fine:</strong></p>
<p>If I manually trigger emptying from the app, it works perfectly every time. Even when the robot's onboard bin is completely packed full (mostly dog hair), the manual empty cycle pulls everything through into the dust bag in the dock with no issues.</p>
<p><strong>What doesn't work:</strong></p>
<ul><li>The automatic emptying after a cleaning run simply never triggers on its own.</li><li>The bin indicator in the app never turns red/full, even when the bin is genuinely packed solid. The robot will happily keep cleaning with an already-full bin instead of stopping or flagging it.</li><li>Eventually I do get an &quot;empty ASAP&quot; notification, but given the above, I suspect that's just timer-based (e.g. &quot;X days since last empty&quot;) rather than tied to an actual full-bin reading.</li></ul>
<p>Has anyone dealt with something similar? Is there a known sensor (e.g., bin-full sensor or dock contact sensor) that could cause this exact symptom, or is this more likely a bug that needs a factory reset or re-pairing to fix?</p>
<p>Any troubleshooting tips or shared experiences would be appreciated.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/963361/Roborock+S7+Max+Ultra+won&#039;t+auto-empty+bin+after+cleaning</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/963361</guid>
<pubDate>Fri, 10 Jul 2026 06:27:20 -0700</pubDate>
</item>
</channel>
</rss>
