<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Roborock Robotic Vacuum Cleaner&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Roborock_Robotic_Vacuum_Cleaner/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Roborock Robotic Vacuum Cleaner&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 02 Sep 2026 03:41:09 -0700</pubDate>
<item>
<title><![CDATA[Roborock Qrevo S5V: Roborock Qrevo S5V dock power board (CPS036018) IC '21ASP' identification and open-collector configuration]]></title>
<description><![CDATA[<p>Troubleshooting component-level repair on Roborock Qrevo S5V docking station power supply board (PN: CPS036018). The SOT-23-5 IC marked '21ASP' has failed.</p>
<p>Bench measurements and trace analysis:</p>
<p>- Pin 2: GND (Vcc-)</p>
<p>- Pin 5: 10V Vcc+</p>
<p>- Pins 1 &amp; 3: AC line phase monitoring (zero-crossing/heartbeat inputs)</p>
<p>- Pin 4: Output running through a 10k resistor to the anode of a PC817 optocoupler (cathode to GND), sending the power-available heartbeat signal across to the secondary-side processor board.</p>
<p>Because Pin 4 drives an optocoupler LED via a 10k resistor rather than a standard logic trace, an open-collector/open-drain output configuration is actually required (sinking current through the optocoupler). We are looking for an exact cross-reference or identification for the '21ASP' SOT-23-5 IC matching this open-collector comparator or logic function.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969934/Roborock+Qrevo+S5V+dock+power+board+(CPS036018)+IC+&#039;21ASP&#039;+identification+and+open-collector+configuration</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969934</guid>
<pubDate>Thu, 27 Aug 2026 05:50:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Qrevo S5V: Roborock Qrevo S5V dock power board (CPS036018) IC '21ASP' replacement/identification]]></title>
<description><![CDATA[<p>Looking for component-level repair help for a Roborock Qrevo S5V docking station power supply board (PN: CPS036018). The IC marked '21ASP' in a SOT-23-5 package has failed or needs identification. Bench measurements show Pin 2 = GND, Pin 5 = 10V Vcc, Pin 4 = 4.6V, and Pins 1/3 = ~0.1V. Pin 4 is some sort of data line via an optocoupler sending information over to the processor board. Pins 1 and 3 are control or sensor lines.</p>
<p>Since replacement power boards are unavailable, does anyone know the exact cross-reference or functional equivalent for this IC?</p>
<p>⟐ Answered August 27, 2026 at 5:04 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969461/Roborock+Qrevo+S5V+dock+power+board+(CPS036018)+IC+&#039;21ASP&#039;+replacement-identification</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969461</guid>
<pubDate>Thu, 27 Aug 2026 05:04:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S8 MaxV Ultra: flexi arm won't spin]]></title>
<description><![CDATA[<p>any fixes for the flexi arm not spinning?</p>
<p>⟐ Commented August 24, 2026 at 18:09 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/939453/flexi+arm+won&#039;t+spin</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/939453</guid>
<pubDate>Mon, 24 Aug 2026 18:09:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S7 Max Ultra: Roborock S7 Max Ultra won't auto-empty bin after cleaning]]></title>
<description><![CDATA[<p>Hi all,</p>
<p>I'm trying to figure out whether I'm dealing with a hardware fault or a software/firmware bug on my Roborock S7 Max Ultra.</p>
<p><strong>Firmware:</strong> v02.26.80 (currently up to date, per the app)</p>
<p><strong>The problem:</strong> After the robot finishes a cleaning cycle, it does not automatically empty its bin into the dock. This happens regardless of whether the auto-empty setting is on &quot;Smart&quot; or &quot;Max.&quot;</p>
<p><strong>What works fine:</strong></p>
<p>If I manually trigger emptying from the app, it works perfectly every time. Even when the robot's onboard bin is completely packed full (mostly dog hair), the manual empty cycle pulls everything through into the dust bag in the dock with no issues.</p>
<p><strong>What doesn't work:</strong></p>
<ul><li>The automatic emptying after a cleaning run simply never triggers on its own.</li><li>The bin indicator in the app never turns red/full, even when the bin is genuinely packed solid. The robot will happily keep cleaning with an already-full bin instead of stopping or flagging it.</li><li>Eventually I do get an &quot;empty ASAP&quot; notification, but given the above, I suspect that's just timer-based (e.g. &quot;X days since last empty&quot;) rather than tied to an actual full-bin reading.</li></ul>
<p>Has anyone dealt with something similar? Is there a known sensor (e.g., bin-full sensor or dock contact sensor) that could cause this exact symptom, or is this more likely a bug that needs a factory reset or re-pairing to fix?</p>
<p>Any troubleshooting tips or shared experiences would be appreciated.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/963361/Roborock+S7+Max+Ultra+won&#039;t+auto-empty+bin+after+cleaning</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/963361</guid>
<pubDate>Fri, 10 Jul 2026 06:27:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Qrevo S: roborock Qrevo S Robot Lidar error. Check that the turret turns freely]]></title>
<description><![CDATA[<p>Does anyone have a guide on how to disassemble the Qrevo S?</p>
<p>Context:</p>
<p>My robot hasn't hit the year mark and yet he doth betray me with the Lidar error. I tried spinning the lidar with a cotton swab a few (15) times (it turns just fine), cleaning the area with a toothpick and vacuum, moving it, soft resetting it, hard resetting it and now I'm at a loss.</p>
<p>I followed this guide initially, but unfortunately it doesn't get me all the way to the turret motor in my model: <ins><a href="https://www.reddit.com/r/Roborock/comments/1bzfmlo/q5_disassembly_to_access_parts_for_repair_images/" rel="nofollow noopener noreferrer" title="https://www.reddit.com/r/Roborock/comments/1bzfmlo/q5_disassembly_to_access_parts_for_repair_images/" target="_blank">https://www.reddit.com/r/Roborock/commen...</a></ins></p>
<p>I have tried YouTube, google and am a hair's breadth away setting fire to my poor tool kit.</p>
<p>Any help or advice would be really appreciated.</p>
<p>⟐ Answer accepted June 23, 2026 at 13:40 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/945195/roborock+Qrevo+S+Robot+Lidar+error.+Check+that+the+turret+turns+freely</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/945195</guid>
<pubDate>Tue, 23 Jun 2026 13:40:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S7: Water is not coming out due water pump fail]]></title>
<description><![CDATA[<p>I need to replace the Built in water pump on my Roborock S7, is there any further instructions about it?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/956448/Water+is+not+coming+out+due+water+pump+fail</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/956448</guid>
<pubDate>Sun, 24 May 2026 00:50:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S8 MaxV Ultra: Resetting the S8 Max V Ultra]]></title>
<description><![CDATA[<p>How do I reset the vacuum? The method described in the manual (press reset button while holding the power button ) doesn’t work.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/940092/Resetting+the+S8+Max+V+Ultra</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/940092</guid>
<pubDate>Tue, 10 Feb 2026 06:33:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[S7 MaxV Ultra: The Vibra-mop isn't working after replacement. Did I miss a step.]]></title>
<description><![CDATA[<p>My S7 MaxV Ultra was giving a Error 27, Vibra-Mop Jammed.  It was mopping, but I don't think it was raising the mop when it wasn't mopping.  I found the replacement part on AliExpress.  The part came in and seemed Identical to the old part.  I found a youtube video on taking the robot apart.  I replaced the part.  Now when I run the robot it doesn't ever activate the mop.  It washes the mop at the start of the session, but doesn't after finishing.  I also don't see it lowering the mop and the floors aren't wet when it is running.  I asked Roborock support but they just want me to send it in.  Is there a process to get it to reset or calibrate the new module.  Thanks for any responses.</p>
<p>⟐ Answered February 09, 2026 at 20:06 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/893297/The+Vibra-mop+isn&#039;t+working+after+replacement.+Did+I+miss+a+step.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/893297</guid>
<pubDate>Mon, 09 Feb 2026 20:06:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S7 MaxV Plus: Is there a guide for this?]]></title>
<description><![CDATA[<p>No guide on the link I can see</p>]]></description>
<link>https://www.ifixit.com/Answers/View/940029/Is+there+a+guide+for+this</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/940029</guid>
<pubDate>Mon, 09 Feb 2026 20:03:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Qrevo Pro: Roborock qrevo not washing mop]]></title>
<description><![CDATA[<p>My roborock qrevo not washing mop, no water coming from fresh water tank, pump motor is working mops are spinning, all water supply lines tubes are clean</p>]]></description>
<link>https://www.ifixit.com/Answers/View/939174/Roborock+qrevo+not+washing+mop</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/939174</guid>
<pubDate>Tue, 03 Feb 2026 19:26:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S7: Two plastic parts are leftovers but where from?]]></title>
<description><![CDATA[<p>I teared my vacuum cleaner (Roborock S7 later model) down (have to change the vibrating module) and in some point I turned it (vacuum cleaner) upside down these parts dropped out on the table. The size of the fallen out rectangular black plastic part is about 13x4x5 mm including some kind of similar notches on it's each end. There are two pieces not exactly the same looking parts but the sizes are the same. I might remember they falled out after removing the main brush module and then when I turned vacuum cleaner upside down there parts falled out. The model is the later one and European (Roborock S7) . Anyone who might know these parts locations in vacuum cleaner would you please tell me?</p>
<p>⟐ Commented November 28, 2025 at 11:16 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/925350/Two+plastic+parts+are+leftovers+but+where+from</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/925350</guid>
<pubDate>Fri, 28 Nov 2025 11:16:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S5: Clif Sensors error because of dust]]></title>
<description><![CDATA[<p>How i can remove the clif sensors to clean them from the inside they have dust inside which i cannot clean<br />i tried to open the vaccum but i cant find how i can remove them to clean them</p>
<p>⟐ Answer edited November 20, 2025 at 18:39 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/921342/Clif+Sensors+error+because+of+dust</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/921342</guid>
<pubDate>Thu, 20 Nov 2025 18:39:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Robotic Vacuum Cleaner: Why can't my vacuum find it dock I did all of the things it said to do]]></title>
<description><![CDATA[<p>My roborock can't find its dock.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/916888/Why+can&#039;t+my+vacuum+find+it+dock+I+did+all+of+the+things+it+said+to+do</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/916888</guid>
<pubDate>Fri, 12 Sep 2025 10:27:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S8 Pro Ultra: No dustbin or filter in the robot]]></title>
<description><![CDATA[<p>I'm getting the classic error of no dustbin or filter in the robot which obviously there is I'm using original dust bin and filter from roborock, I've checked to see if the magnet is still in place on the dustbin which it is but still having this error any help would be great thanks!</p>]]></description>
<link>https://www.ifixit.com/Answers/View/916657/No+dustbin+or+filter+in+the+robot</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/916657</guid>
<pubDate>Thu, 11 Sep 2025 02:39:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S8 MaxV Ultra: Dustbin empty cycle stuck]]></title>
<description><![CDATA[<p>I’m having a persistent issue with my <strong>Roborock S8 MaxV Ultra</strong> and hoping someone here has run into the same thing or has a fix.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section__Problem_Summary" class="header"><strong>Problem Summary:</strong></h3></div>
<p>Whenever the robot returns to the dock to auto-empty the dustbin, it gets <strong>stuck in the emptying cycle</strong>. Physically, I can hear the dock vacuum start and stop, but in the <strong>Roborock app</strong>, the emptying process never finishes. This causes two major problems:</p>
<ul><li>The robot <strong>won’t start charging</strong>.</li><li>If it returns mid-cleaning, it <strong>won’t resume cleaning</strong> after docking.</li></ul>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section__What_I_ve_Tried_Layman_internet_suggestions" class="header"><strong>What I’ve Tried:</strong>(Layman internet suggestions)</h3></div>
<ul><li>Unplugged the dock and plugged it back in.</li><li>Cleaned all filters and checked for obstructions.</li><li>Power-cycled the robot.</li><li>Verified the dustbin cover is properly installed.</li><li>Checked for blockages in the dock and suction path.</li><li>Ensured the robot isn’t in <strong>Do Not Disturb (DND)</strong> mode, and verified every setting in the app.</li></ul>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section__Additional_Notes" class="header"><strong>Additional Notes:</strong></h3></div>
<ul><li>I can manually stop the emptying process via the app, but doing so <strong>resets the cleaning cycle</strong>, meaning it won’t resume where it left off.</li><li>The dock’s <strong>status light doesn’t show any errors</strong>, and the vacuum seems to dock correctly.</li><li>I suspect the issue might be with the <strong>signal or sensor</strong> that tells the robot the emptying process is complete. It seems like the robot never gets that confirmation.</li></ul>]]></description>
<link>https://www.ifixit.com/Answers/View/916250/Dustbin+empty+cycle+stuck</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/916250</guid>
<pubDate>Tue, 09 Sep 2025 08:28:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Q5 Max Plus: How to inspect lidar]]></title>
<description><![CDATA[<p>How do I inspect the lidar system after receiving the lidar error?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/914396/How+to+inspect+lidar</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/914396</guid>
<pubDate>Thu, 28 Aug 2025 21:21:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Q Revo: Side brush not functioning]]></title>
<description><![CDATA[<p>My brush got wrapped around a robe tie. Afterwards I heard “internal error” only once did it state error 17- I then noticed the brush was no longer spinning</p>
<p>The vacuum works fine otherwise- periodically it will say “internal error” but functions fine- except for the side brush. I bought motor online and replaced it but no luck. Any suggestions? Thanks for your time</p>]]></description>
<link>https://www.ifixit.com/Answers/View/912022/Side+brush+not+functioning</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/912022</guid>
<pubDate>Thu, 14 Aug 2025 15:30:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S7: My Roborock S7 not washing!]]></title>
<description><![CDATA[<p>I have a problem with my Roborock S7 not washing. I fill the tank with water and it doesn't actually reach the mop. I assume there is some kind of blockage. How can I fix this? I tried cleaning the out from the water tank and also the out to the mop with needle but it didn't help.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/907564/My+Roborock+S7+not+washing!</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/907564</guid>
<pubDate>Tue, 15 Jul 2025 12:06:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[S7 MaxV Ultra: Maintenance brush keeps getting stuck on left side. Error 42]]></title>
<description><![CDATA[<p>I’m disassembled and clean the entire unit replaced the maintenance brush. I don’t know why it keeps kicking this error, any ideas?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/907444/Maintenance+brush+keeps+getting+stuck+on+left+side.+Error+42</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/907444</guid>
<pubDate>Mon, 14 Jul 2025 17:53:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Q7 Max: Where is the dirt bin sensor]]></title>
<description><![CDATA[<p>i see a sensor for this model , it is an Hall sensor. i have to bypass the sensor but i can not find , magneet on the dirtbin . Does anybody know where it is ?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/900928/Where+is+the+dirt+bin+sensor</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/900928</guid>
<pubDate>Wed, 21 May 2025 11:05:04 -0700</pubDate>
</item>
</channel>
</rss>
