<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Ridgid Power Drill&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Ridgid_Power_Drill?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Ridgid Power Drill&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 18 Jul 2026 16:29:02 -0700</pubDate>
<item>
<title><![CDATA[RIDGID R84015 X2: Chuck is stuck and will not turn]]></title>
<description><![CDATA[<p>I went to use my drill the other day and when I went to put a bit in the teeth, the chuck would not move.  I could not get the teeth to move at all, and the chuck would not turn.  I thought maybe it was just stuck and thought about putting something in there to loosen things up, but my father-in-law was afraid it might get into the electrical parts.  Any information on how to get this unstuck would be helpful.  Thanks!</p>
<p>⟐ Answered September 17, 2023 at 7:49 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/70031/Chuck+is+stuck+and+will+not+turn</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/70031</guid>
<pubDate>Sun, 17 Sep 2023 07:49:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid R82005: My drill has no torque. what can I do?]]></title>
<description><![CDATA[<p>I bought this drill for my daughter and neither one of us know how to increase the drill’s power. Is there any one who can help me? Help!</p>
<p>⟐ Answer accepted June 19, 2024 at 10:22 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/551709/My+drill+has+no+torque.+what+can+I+do</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/551709</guid>
<pubDate>Wed, 19 Jun 2024 10:22:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid R82005: Battery issues? Wont charge at all]]></title>
<description><![CDATA[<p>I plug the battery into the charger and it reads as fully charged, but when I use it in the drill it has no power at all. Help!</p>
<p>⟐ Commented February 26, 2026 at 15:25 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/551692/Battery+issues+Wont+charge+at+all</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/551692</guid>
<pubDate>Thu, 26 Feb 2026 15:25:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid R82005: Drill is rotating the wrong way! HELP!]]></title>
<description><![CDATA[<p>The drill is not rotating the correct way. All it is doing is unscrewing the screw.</p>
<p>⟐ Commented July 26, 2024 at 22:45 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/551698/Drill+is+rotating+the+wrong+way!+HELP!</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/551698</guid>
<pubDate>Fri, 26 Jul 2024 22:45:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid Brushless Drill Driver R860054: The battery charger for this device is not working.]]></title>
<description><![CDATA[<p>The battery charger was plugged into an outlet that had 240v going through it for a few seconds. Then it failed to light up or charge a battery.</p>
<p>There looks like a resistor or capacitor that burned and failed when I open the charger up. Can you repair this?</p>
<p>⟐ Commented August 01, 2023 at 4:13 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/804777/The+battery+charger+for+this+device+is+not+working.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/804777</guid>
<pubDate>Tue, 01 Aug 2023 04:13:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[RIDGID R84015 X2: Battery no longer holds a charge]]></title>
<description><![CDATA[<p>The 18v batteries for my RIGID tools (drill and reciprocating saw) no longer hold a charge.</p>
<p>The charger even signals that one (I have 2 packs) of the batteries is defective (blinking red &amp; green lights).</p>
<p>Do I have to replace the packs (over $100 each) or can I possibly replace the cells inside the packs?</p>
<p>Thanks in advance,</p>
<p>Paul</p>
<p>⟐ Answer deleted October 20, 2018 at 6:21 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/145512/Battery+no+longer+holds+a+charge</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/145512</guid>
<pubDate>Sat, 20 Oct 2018 06:21:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[RIDGID R84015 X2: Bit won't come out of the chuck.]]></title>
<description><![CDATA[<p>I used my drill today and I went to drill a into a piece of brick and the bit went back into the drill somehow. I can open and close the chuck but the drill bit will not come out. When I push on the end of the chuck it goes into the drill, it has a lot of movement.</p>
<p>I tried everything to try and get the drill bit out, nothing works, I don't understand how it could get stuck in the drill when I can still open and close the teeth to the chuck. Thanks.</p>
<p>Joel</p>
<p>⟐ Answered September 20, 2013 at 7:03 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/46996/Bit+won&#039;t+come+out+of+the+chuck.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/46996</guid>
<pubDate>Fri, 20 Sep 2013 07:03:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid DrillDriver R860054 2020: How do I get the chuck assembly apart?]]></title>
<description><![CDATA[<p>The drill stopped working. I'm told take apart the chuck assembly. When I attempt to do this i encounter an odd-sized torx bolt (somewhere between T40 &amp; T45) holding the assembly together. How do I loosen this?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/bQwKd5qcr5WVbCpl.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/bQwKd5qcr5WVbCpl.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Answered October 19, 2024 at 10:37 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/848749/How+do+I+get+the+chuck+assembly+apart</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/848749</guid>
<pubDate>Sat, 19 Oct 2024 10:37:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid R82005: How do you replace the carbon brushes on this unit?]]></title>
<description><![CDATA[<p>How do you replace the carbon brushes on this unit?</p>
<p>⟐ Commented September 01, 2023 at 20:50 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/811462/How+do+you+replace+the+carbon+brushes+on+this+unit</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/811462</guid>
<pubDate>Fri, 01 Sep 2023 20:50:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid Drill R86006 2013: I have a stuck drillbit in it and it won’t come out. It’s easy going b]]></title>
<description><![CDATA[<p>I have a stuck bit in it and it’s easy move both ways. What do I do?</p>
<p>⟐ Commented November 09, 2025 at 21:18 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/925303/I+have+a+stuck+drillbit+in+it+and+it+won%E2%80%99t+come+out.+It%E2%80%99s+easy+going+b</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/925303</guid>
<pubDate>Sun, 09 Nov 2025 21:18:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid R7111: Taking drill bit head off]]></title>
<description><![CDATA[<p>How to take the drill head off to replace the gripping teeth?</p>
<p>⟐ Answered April 19, 2026 at 13:10 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/951029/Taking+drill+bit+head+off</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/951029</guid>
<pubDate>Sun, 19 Apr 2026 13:10:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[RIDGID R860052: How do I remove the chuck for replacement]]></title>
<description><![CDATA[<p>I have removed the Phillips head screw, but all the instruction I find online, call for a torx head screw once the phillips head screw is removed.  My model does not have that.  is the chuck screwed on with internal threads or is it a press fit?  Any help would be appreciated.</p>
<p>⟐ Answered January 28, 2026 at 22:44 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/937545/How+do+I+remove+the+chuck+for+replacement</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/937545</guid>
<pubDate>Wed, 28 Jan 2026 22:44:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid Spade Handle Drill R7122 2012: replace cord on drill how do I get handle apart to replace cord]]></title>
<description><![CDATA[<p>How do i get the cord off of drill, i can’t get the handle apart to replace cord.</p>
<p>⟐ Answered March 08, 2025 at 16:40 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/890533/replace+cord+on+drill+how+do+I+get+handle+apart+to+replace+cord</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/890533</guid>
<pubDate>Sat, 08 Mar 2025 16:40:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid R7111: Rigiid R5010 Corded Hammer Drill -- CHUCK STUCK]]></title>
<description><![CDATA[<p>Lent drill (Rigid R5010 corded hammer drill to neighbor -- big mistake - returned it and did not tell me that he had to force the bit out.. now chuck is jammed) .  Would appreciate advise on how to unstick chuck or process to replace it and recommendations for a  KEYED type check replacement...</p>
<p>Thanks.</p>
<p>⟐ Answer accepted June 19, 2024 at 10:24 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/737882/Rigiid+R5010+Corded+Hammer+Drill+--+CHUCK+STUCK</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/737882</guid>
<pubDate>Wed, 19 Jun 2024 10:24:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ridgid R82005: I dropped it and it wont run. Trigger light works, battery okay]]></title>
<description><![CDATA[<p>I dropped my Ridgid R82005.  It will not run, battery is okay. Trigger light comes on.</p>
<link>https://www.ifixit.com/Answers/View/713949/I+dropped+it+and+it+wont+run.+Trigger+light+works,+battery+okay</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/713949</guid>
<pubDate>Wed, 19 Jun 2024 10:22:39 -0700</pubDate>
</item>
</channel>
</rss>
