<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Nest Learning Thermostat 2nd Generation&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Nest_Learning_Thermostat_2nd_Generation/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Nest Learning Thermostat 2nd Generation&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 19 Jul 2026 19:27:08 -0700</pubDate>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Where can I purchase parts for the nest 2nd generation thermostat?]]></title>
<description><![CDATA[<p>Does anyone know where can I get the base motherboard for a Nest 2nd generation?</p>
<p>⟐ Commented May 07, 2025 at 12:28 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/350525/Where+can+I+purchase+parts+for+the+nest+2nd+generation+thermostat</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/350525</guid>
<pubDate>Wed, 07 May 2025 12:28:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: nest won't connect to the heatlink]]></title>
<description><![CDATA[<p>Hi Folks, my nest wouldn’t connect to the heatlink. I’d been on to nest support and they said the system needs to be replaced. Apart from checking version numbers there was no “nest magic” suggested by the support rep,  over and above what I’d already tried.</p>
<p>⟐ Commented November 16, 2024 at 7:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/594071/nest+won&#039;t+connect+to+the+heatlink</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/594071</guid>
<pubDate>Sat, 16 Nov 2024 07:05:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Nest Gen 2 Battery won't change low lin]]></title>
<description><![CDATA[<p>I bought a second hand Nest Thermostat and the battery will not charge. The info has a low lin reading of only 8. I know the unit is defective because I bought a brand new one and wired it the same and it works great with a lin reading of 200. Is the defective unit in need of a new battery? Or is it possible there is something wrong with the base?</p>
<p>Thanks!</p>
<p>⟐ Commented April 15, 2024 at 16:22 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/467936/Nest+Gen+2+Battery+won&#039;t+change+low+lin</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/467936</guid>
<pubDate>Mon, 15 Apr 2024 16:22:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: What if my Wi-Fi network goes offline?]]></title>
<description><![CDATA[<p>If my Wi-Fi network goes offline, will the thermostat still operate as programmed?</p>
<p>⟐ Answered November 25, 2023 at 15:22 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/199380/What+if+my+Wi-Fi+network+goes+offline</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/199380</guid>
<pubDate>Sat, 25 Nov 2023 15:22:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Why does it keep turning on and off? Red light is blinking]]></title>
<description><![CDATA[<p>Why does the red light keep blinking?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/808132/Why+does+it+keep+turning+on+and+off+Red+light+is+blinking</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/808132</guid>
<pubDate>Thu, 17 Aug 2023 00:15:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Source for replacement battery for the Nest Thermostat v2.0]]></title>
<description><![CDATA[<p>Battery as detailed in this iFixit teardown.</p>
<p><a href="/Teardown/Nest+Learning+Thermostat+2nd+Generation+Teardown/13818">Teardown URL</a></p>
<p><a href="http://d3nevzfk7ii3be.cloudfront.net/igi/yUO3H1YWLFa4XgEM.huge" rel="nofollow noopener noreferrer">Picture of battery</a></p>
<p>⟐ Commented May 18, 2022 at 0:54 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/152923/Source+for+replacement+battery+for+the+Nest+Thermostat+v2.0</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/152923</guid>
<pubDate>Wed, 18 May 2022 00:54:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Where can I purchase Wire Base For nest 2nd generation thermostat?]]></title>
<description><![CDATA[<p>Where can I purchase Wire Base For nest 2nd generation thermostat?</p>
<p>⟐ Answered April 22, 2022 at 4:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/445626/Where+can+I+purchase+Wire+Base+For+nest+2nd+generation+thermostat</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/445626</guid>
<pubDate>Fri, 22 Apr 2022 04:43:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Why is the new battery not powering the device?]]></title>
<description><![CDATA[<p>I received my new battery for my nest 2nd gen thermostat from I fix it.  After I installed it, I charged it with a USB charger.  After several hours of charging, the Nest device won’t turn on.  When I plug it into the wall, I get a red blinking light at the top.  I know I’m installing the battery correctly because, I was able to install the old one and get it to work.  Is there a problem with the device or the battery?  Thanks!</p>
<p>⟐ Answered May 04, 2021 at 6:06 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/690946/Why+is+the+new+battery+not+powering+the+device</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/690946</guid>
<pubDate>Tue, 04 May 2021 06:06:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: I need to replace the outer ring, where can I find that part?]]></title>
<description><![CDATA[<p>Kids knocked thermostat off the wall and the ring is dented. Now it won’t stay attached very well. I need to replace the ring. Any help here?</p>
<p>⟐ Answer accepted December 11, 2020 at 16:45 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/594849/I+need+to+replace+the+outer+ring,+where+can+I+find+that+part</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/594849</guid>
<pubDate>Fri, 11 Dec 2020 16:45:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: nest app will not connect to the internet]]></title>
<description><![CDATA[<p>My nest app will not connect to the internet</p>
<p>⟐ Commented March 27, 2020 at 22:26 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/624585/nest+app+will+not+connect+to+the+internet</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/624585</guid>
<pubDate>Fri, 27 Mar 2020 22:26:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Where do I get parts?]]></title>
<description><![CDATA[<p>I have a Nest 2nd Generation thermostat that no longer works in heat mode. It thinks it is turning on the furnace, but the signal doesn't reach the furnace. It works fine in cool mode. There are guides to replacing the parts on this site, but no way of diagnosing the correct part to replace or of buying a part or finding where to get parts.</p>
<p>⟐ Answer accepted September 24, 2017 at 7:17 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/365107/Where+do+I+get+parts</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/365107</guid>
<pubDate>Sun, 24 Sep 2017 07:17:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Why does my T/S read Updating Software for two days now]]></title>
<description><![CDATA[<p>T/S reads updating software for two days now and keeps the A/C running over time</p>
<p>⟐ Answered August 26, 2017 at 20:21 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/421712/Why+does+my+T-S+read+Updating+Software+for+two+days+now</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/421712</guid>
<pubDate>Sat, 26 Aug 2017 20:21:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Does iFixit carry replacement parts for the Nest thermostat?]]></title>
<description><![CDATA[<p>Hey everyone,</p>
<p>I see that there are several guides for replacing parts for the Nest Learning Thermostat, and I'm just curious where I can purchase them if something were to go wrong with mine in the future. Thanks in advance!</p>
<p>⟐ Commented December 08, 2016 at 16:20 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/198653/Does+iFixit+carry+replacement+parts+for+the+Nest+thermostat</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/198653</guid>
<pubDate>Thu, 08 Dec 2016 16:20:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Why does my Nest keep showing updating software for hours?]]></title>
<description><![CDATA[<p>Why does my Nest Thermostat keep showing Updating Software? How long does it usually last?</p>
<p>⟐ Answered May 31, 2016 at 16:40 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/314746/Why+does+my+Nest+keep+showing+updating+software+for+hours</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/314746</guid>
<pubDate>Tue, 31 May 2016 16:40:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Location of the thermostat housing]]></title>
<description><![CDATA[<p>Where is the thermostat location for the 1994 corolla/ efi 16 valves</p>]]></description>
<link>https://www.ifixit.com/Answers/View/300896/Location+of+the+thermostat+housing</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/300896</guid>
<pubDate>Mon, 28 Mar 2016 11:30:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: nest stand lost screws]]></title>
<description><![CDATA[<p>Missing screws for nest stand</p>]]></description>
<link>https://www.ifixit.com/Answers/View/276420/nest+stand+lost+screws</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/276420</guid>
<pubDate>Fri, 11 Dec 2015 04:57:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: up date software what does this mean]]></title>
<description><![CDATA[<p>up date software   what does this mean been like this all day and last night</p>
<p>⟐ Answer accepted September 28, 2015 at 18:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/246348/up+date+software+what+does+this+mean</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/246348</guid>
<pubDate>Mon, 28 Sep 2015 18:05:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Does my Nest need a new display?]]></title>
<description><![CDATA[<p>My 1st Gen NEST (eBay) arrived in a box (&quot;mangled&quot; like it was run over by a truck) in a USPS plastic bag denoted: RECEIVED UNSEALED and RECEIVED DAMAGED. Connecting it to either my furnace/AC or USB gives the same B&amp;W image like shards of glass (one section in white resembles Egypt). Does this mean the display is destroyed? Any hope to fix it (new display?, where?). Thanks</p>
<p>Photos of NEST mutilated package &amp; display via USB (same for furnace/AC) at:</p>
<p><a href="http://tinyurl.com/olafwork/NEST" rel="nofollow noopener noreferrer">http://tinyurl.com/olafwork/NEST</a></p>
<p>⟐ Commented August 16, 2015 at 12:54 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/240604/Does+my+Nest+need+a+new+display</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/240604</guid>
<pubDate>Sun, 16 Aug 2015 12:54:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Where to buy NEST2 Base Plate?]]></title>
<description><![CDATA[<p>Where can I buy a NEST2  base plate to connect wires?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/249115/Where+to+buy+NEST2+Base+Plate</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/249115</guid>
<pubDate>Sun, 16 Aug 2015 06:46:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Nest Learning Thermostat 2nd Generation: Daylight Savings Time adjustment?]]></title>
<description><![CDATA[<p>I didn't see it listed in the Troubleshooting pages, so how do I adjust the thermostat to account for Daylight Savings Time?</p>
<p>⟐ Commented November 04, 2014 at 10:58 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/199382/Daylight+Savings+Time+adjustment</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/199382</guid>
<pubDate>Tue, 04 Nov 2014 10:58:21 -0700</pubDate>
</item>
</channel>
</rss>
