<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Marco UP Series Electric Pump&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Marco_UP_Series_Electric_Pump?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Marco UP Series Electric Pump&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 24 May 2026 04:00:01 -0700</pubDate>
<item>
<title><![CDATA[Marco UP Series Electric Pump: The pump keeps turning on every few minutes and runs for 6 seconds]]></title>
<description><![CDATA[<p>The pump turns on every minute and runs for 6 seconds without any draw of water from the system.</p>
<p>⟐ Commented January 08, 2023 at 10:32 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/463022/The+pump+keeps+turning+on+every+few+minutes+and+runs+for+6+seconds</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/463022</guid>
<pubDate>Sun, 08 Jan 2023 10:32:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Can I reduce the pump output water pressure?]]></title>
<description><![CDATA[<p>I would like to reduce the output water pressure to better suit the system in my boat. Can this be done?</p>
<p>⟐ Answered August 03, 2022 at 7:39 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/414764/Can+I+reduce+the+pump+output+water+pressure</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/414764</guid>
<pubDate>Wed, 03 Aug 2022 07:39:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: My UP6/E Marco pump is passing water into the electric motor.]]></title>
<description><![CDATA[<p>Does anyone know how to get replacement part numbers for this water pump?  I have the parts breakdown diagram, but it doesn’t show part numbers.</p>
<p>⟐ Answered June 16, 2021 at 1:04 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/621439/My+UP6-E+Marco+pump+is+passing+water+into+the+electric+motor.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/621439</guid>
<pubDate>Wed, 16 Jun 2021 01:04:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Bleeding the pump every few days?]]></title>
<description><![CDATA[<p>Why do I need to constantly bleed this pump every few days.</p>
<p>⟐ Commented April 24, 2021 at 6:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/684651/Bleeding+the+pump+every+few+days</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/684651</guid>
<pubDate>Sat, 24 Apr 2021 06:43:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Can these pumps be PWM controlled to vary output flow?]]></title>
<description><![CDATA[<p>My question is specific to the UP3 series pumps and whether or not they can be PWM output controlled to vary output flow.  The pressure is low (less than 15psi).  Is there a recommend maximum PWM frequency?  I was thinking 30Hz or less for this type of device.  Also, I noticed on the 12VDC tag it says EMI filter inside..do not use with PWM, but the 24VDC version does not have this same warning.  Can you please clarify?</p>
<p>⟐ Answer edited October 13, 2020 at 6:26 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/563147/Can+these+pumps+be+PWM+controlled+to+vary+output+flow</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/563147</guid>
<pubDate>Tue, 13 Oct 2020 06:26:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: UP6/E output pressure low]]></title>
<description><![CDATA[<p>The output water pressure has become low. I swapped out the drive gears from a same model pump and still low water output.  Any suggestions?</p>
<p>⟐ Commented August 02, 2022 at 9:04 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/742141/UP6-E+output+pressure+low</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/742141</guid>
<pubDate>Tue, 02 Aug 2022 09:04:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: The pump is running but no water]]></title>
<description><![CDATA[<p>The pump is running but there is no water</p>
<p>⟐ Answer edited September 28, 2020 at 22:38 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/599552/The+pump+is+running+but+no+water</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/599552</guid>
<pubDate>Mon, 28 Sep 2020 22:38:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Can UP3/E function on slow speed with SCS?]]></title>
<description><![CDATA[<p>I have installed a Speed Control System together with my UP3/E pump. Normal speed, pump is working perfect. When I select slow speed, the pump is pumping slowly for a while until it stops completely and it will not pump again until I press reset button. LED is steady red as from the moment I select low speed. When pumping the red and blue led blinks alternatively. When I select the high speed again, the pump is working perfect again. My question: Does someone recognize what I wrote down? Is the SCS compatible with the UP3/E or is it maybe not?</p>
<p>⟐ Commented September 09, 2025 at 13:29 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/916247/Can+UP3-E+function+on+slow+speed+with+SCS</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/916247</guid>
<pubDate>Tue, 09 Sep 2025 13:29:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Pump gears are not turning.]]></title>
<description><![CDATA[<p>We’ve installed the pump one year ago on our boat. We left the boat for six months and when coming back today, the pump was not working anymore. It blinks 24 (or 25?) times red and the an orange light. It repeats this for three cycles and then the red led signals overcharge. I guess the gears are not turning. I’ve added water to the chamber, but still the same. Can anyone help?</p>
<p>Thanks!</p>
<p>⟐ Answer edited May 01, 2025 at 7:16 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/898267/Pump+gears+are+not+turning.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/898267</guid>
<pubDate>Thu, 01 May 2025 07:16:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Safe for drinking water?]]></title>
<description><![CDATA[<p>Is the pump safe for drinking water?</p>
<p>⟐ Answered February 24, 2025 at 2:56 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/889015/Safe+for+drinking+water</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/889015</guid>
<pubDate>Mon, 24 Feb 2025 02:56:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Pump in alarm after 40 sec]]></title>
<description><![CDATA[<p>This weekend the pump was installed and it appears that after 40 seconds the pump goes into alarm? We have checked everything carefully, water supply OK, venting OK?</p>
<p>When the pump goes into alarm, the yellow and blue light flashes, which alarm is that ???</p>
<p>⟐ Answer accepted October 31, 2024 at 9:46 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/658446/Pump+in+alarm+after+40+sec</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/658446</guid>
<pubDate>Thu, 31 Oct 2024 09:46:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: UP10 -XA Power Supply Voltage Range]]></title>
<description><![CDATA[<p>What is the 24V UP10-XA Pumps operating voltage range</p>
<p>will it work at 16V</p>
<p>⟐ Answer accepted October 01, 2024 at 6:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/665395/UP10+-XA+Power+Supply+Voltage+Range</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/665395</guid>
<pubDate>Tue, 01 Oct 2024 06:43:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Any special measures required to start a brand new pu ichmp?]]></title>
<description><![CDATA[<p>I just installed a brand new UP3/E. When I switch on power, nothing happens at all. No LED shows any light, no sound from the pump. It is definetely filled with water, except the upper half of the inlet filter. When I loose the front plate, water pours out. Same with the bleed screw. The cabling is correct, as my old pump ist working fine on the very same connections. Is it dead on arrival, or what may I need to do to start the pump for the first time?</p>
<p>BTW, the manual mentions situations where a reset may be required, but seems not to explain how to perfom one. So how does it work?</p>
<p>⟐ Commented June 13, 2023 at 5:55 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/796510/Any+special+measures+required+to+start+a+brand+new+pu+ichmp</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/796510</guid>
<pubDate>Tue, 13 Jun 2023 05:55:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Are these UP pumps reversable?]]></title>
<description><![CDATA[<p>Can I reverse the flow on the pump?  If yes is this done by reversing the polarity?</p>
<p>⟐ Answer accepted December 19, 2022 at 14:49 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/760282/Are+these+UP+pumps+reversable</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/760282</guid>
<pubDate>Mon, 19 Dec 2022 14:49:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: UP3/E electric pump filter size please]]></title>
<description><![CDATA[<p>i have a UP3/E electric pump with a leaking filter which I cannot seem to seal, I require a replacement, you have 3 on your web site, which one do I need and where can I get one please.</p>
<p>⟐ Answer edited October 09, 2022 at 21:21 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/750856/UP3-E+electric+pump+filter+size+please</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/750856</guid>
<pubDate>Sun, 09 Oct 2022 21:21:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: What is the thread size for the inlet and outlet ports?]]></title>
<description><![CDATA[<p>What is the thread size, or designation,  in the inlet and outlet ports??  I can’t find it anywhere.</p>
<p>Update 4-20-2021</p>
<p>I believe the model is GCF Marco UP3-R</p>
<p>⟐ Answer accepted September 24, 2022 at 20:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/689035/What+is+the+thread+size+for+the+inlet+and+outlet+ports</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/689035</guid>
<pubDate>Sat, 24 Sep 2022 20:51:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Marco pump up2/e and the Red light is flashing slow.]]></title>
<description><![CDATA[<p>I have a new Marco pump up2/e and the Red light is flashing slow. It is trying to reset itself 3 times, after that the red light remains solid. I have tried everything, including checking the brushes and fuses. Everything seems to be fine. I am wondering what this problem could be. Does anyone know a solution?</p>
<p>⟐ Answer edited August 28, 2022 at 0:10 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/745378/Marco+pump+up2-e+and+the+Red+light+is+flashing+slow.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/745378</guid>
<pubDate>Sun, 28 Aug 2022 00:10:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: UP12/E-LOBR for ATF oil coolig system?]]></title>
<description><![CDATA[<p>Hello,</p>
<p>I,ve question is good option to built ATF oil cooling system for cooling electric motor with this pomp ? how long can this pomp work, and can i control flow parameter by the SCS or by simple valve ?</p>
<p>⟐ Answered February 10, 2022 at 3:18 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/721362/UP12-E-LOBR+for+ATF+oil+coolig+system</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/721362</guid>
<pubDate>Thu, 10 Feb 2022 03:18:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Automatic air drain on air vent]]></title>
<description><![CDATA[<p>My pump is installed on a sailboat for fresh water. Fresh water tanks are flexible and there is often air passing into water hose. I must unscrew the air vent cap to remove air and prime the pump. I wonder if I can install an automatic air drain, like on radiators at home. I don’t find the characteristics of the air vent cap screw. Could you help me fixing this? I assume many people have this problem with flexible tanks. Thank you</p>
<p>⟐ Commented August 17, 2021 at 5:49 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/702216/Automatic+air+drain+on+air+vent</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/702216</guid>
<pubDate>Tue, 17 Aug 2021 05:49:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Marco UP Series Electric Pump: Motor runs. No flow.]]></title>
<description><![CDATA[<p>UP6/A. 6.213.  Pump runs but there is no flow.   <br /></p>
<p>use.  Yacht sea water flush.  <br /></p>
<p>Q.  Is this a serviceable repair.  . ?</p>
<p>⟐ Answered May 31, 2021 at 2:29 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/694109/Motor+runs.+No+flow.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/694109</guid>
<pubDate>Mon, 31 May 2021 02:29:33 -0700</pubDate>
</item>
</channel>
</rss>
