<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Makita Angle Grinder&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Makita_Angle_Grinder?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Makita Angle Grinder&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 20 Jul 2026 21:32:58 -0700</pubDate>
<item>
<title><![CDATA[Makita GA4030K: Which grease to use on Makita machines]]></title>
<description><![CDATA[<p>All Makita technical manuals mention a &quot;Makita grease SG No. 0&quot; for lubrication but where to find it? What kind of grease is that? Is there a brand and type like Molycote, Castrol or other to replace it? What to use?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/252974/Which+grease+to+use+on+Makita+machines</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/252974</guid>
<pubDate>Wed, 02 Sep 2015 21:18:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita GA4030K: Angle grinder is getting very hot when I use it.]]></title>
<description><![CDATA[<p>I have had my angle grinder for quite some time and while using it today I noticed that the body of the tool was becoming quite hot. I turned it off and unplugged it as this has never happened before and I was quite concerned. Can someone please tell me what might have happened to cause this and how I can go about fixing it?</p>
<p>⟐ Answer edited February 02, 2021 at 3:22 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/226905/Angle+grinder+is+getting+very+hot+when+I+use+it.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/226905</guid>
<pubDate>Tue, 02 Feb 2021 03:22:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita GA4030K: Angle grinder won't turn on after I dropped it.]]></title>
<description><![CDATA[<p>I was using my angle grinder to work on a small project the other evening when I was startled and dropped the grinder off of my work bench. Now, when I try to use it, the grinder won’t turn on at all. I tried plugging it into several different outlets throughout my house and that doesn't seem to be the problem so I think it must be the grinder itself. Is there any way to fix this?</p>
<p>⟐ Commented June 13, 2020 at 14:45 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/226904/Angle+grinder+won&#039;t+turn+on+after+I+dropped+it.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/226904</guid>
<pubDate>Sat, 13 Jun 2020 14:45:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita GA4030K: What is causing my angle grinder to make so much noise?]]></title>
<description><![CDATA[<p>For the past several days I have been using my Makita GA4030 to work on an extensive project for many hours at a time. As I was using it this afternoon I noticed that the grinder started making a funny noise that it has never made before. What’s going on? Is this something worth fixing or should I just go buy a new one?</p>
<p>⟐ Answer edited May 26, 2015 at 7:11 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/226977/What+is+causing+my+angle+grinder+to+make+so+much+noise</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/226977</guid>
<pubDate>Tue, 26 May 2015 07:11:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Angle Grinder GA7011C 2017: Switch push button repair]]></title>
<description><![CDATA[<p>I have opened the push button and now don't know how to repair it</p>
<p>⟐ Answer edited January 15, 2025 at 16:01 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/883861/Switch+push+button+repair</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/883861</guid>
<pubDate>Wed, 15 Jan 2025 16:01:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Die Grinder 9554NB 2010: no function and overheating]]></title>
<description><![CDATA[<p>my ginder is not functioning and overheating, how to fix this?</p>
<p>⟐ Answer edited January 04, 2026 at 9:02 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/933846/no+function+and+overheating</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/933846</guid>
<pubDate>Sun, 04 Jan 2026 09:02:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Die Grinder 9524NB 2010: How to change carbon]]></title>
<description><![CDATA[<p>How to change carbon</p>
<p>⟐ Answered November 09, 2025 at 19:24 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/925561/How+to+change+carbon</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/925561</guid>
<pubDate>Sun, 09 Nov 2025 19:24:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Mini Grinder 9564PC: Why is the roter winding sparking with brushes on the lamellas]]></title>
<description><![CDATA[<p>I cleaned the space between the lamella and it sparks nonstop when energized.</p>
<p>⟐ Answer edited July 28, 2025 at 6:24 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/909392/Why+is+the+roter+winding+sparking+with+brushes+on+the+lamellas</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/909392</guid>
<pubDate>Mon, 28 Jul 2025 06:24:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Die Grinder 9501B 2010: Makita 4" Corded Angle Grinder 9501B - Removing Back Cover for Service]]></title>
<description><![CDATA[<p>I cannot get the plastic rear cover off the main body.</p>
<p>I have removed the ON/OFF switch button so the switch lever can move freely.</p>
<p>Something else seems to prevent the cover from coming off.</p>
<p>Does anyone know how to get it off?</p>
<p>⟐ Commented February 25, 2025 at 20:53 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/887721/Makita+4%22+Corded+Angle+Grinder+9501B+-+Removing+Back+Cover+for+Service</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/887721</guid>
<pubDate>Tue, 25 Feb 2025 20:53:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Angle Grinder: Grip holder right side vs left]]></title>
<description><![CDATA[<p>I have a Makita dish grinder model 9501B and would like to know if I can get a grip holder for the right side versus the left side?</p>
<p>⟐ Edited December 22, 2025 at 9:47 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/849745/Grip+holder+right+side+vs+left</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/849745</guid>
<pubDate>Mon, 22 Dec 2025 09:47:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Angle Grinder GA4030K 2008: do you do repairs for these grinders]]></title>
<description><![CDATA[<p>I would like to know, prices and the period of time you need to fix.</p>
<p>⟐ Answered March 14, 2024 at 18:21 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/840889/do+you+do+repairs+for+these+grinders</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/840889</guid>
<pubDate>Thu, 14 Mar 2024 18:21:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Die Grinder 9067L 2010: Why does my angle grinder doesnot work after chaincing the brushes]]></title>
<description><![CDATA[<p>Why does my angle grinder doesnot work after chaincing the brushes</p>
<p>⟐ Commented March 05, 2026 at 16:48 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/943398/Why+does+my+angle+grinder+doesnot+work+after+chaincing+the+brushes</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/943398</guid>
<pubDate>Thu, 05 Mar 2026 16:48:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Makita Angle Grinder: Why dose my battery red lights come on when I trigger the switch]]></title>
<description><![CDATA[<p>18 volt makita grinder</p>
<p>⟐ Edited December 22, 2025 at 9:40 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/666949/Why+dose+my+battery+red+lights+come+on+when+I+trigger+the+switch</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/666949</guid>
<pubDate>Mon, 22 Dec 2025 09:40:41 -0700</pubDate>
</item>
</channel>
</rss>
