<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Macbook Pro 16&quot; 2023&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Macbook_Pro_16%22_2023?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Macbook Pro 16&quot; 2023&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 19 Jul 2026 21:44:32 -0700</pubDate>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Losing WiFi signal when in clamshell mode]]></title>
<description><![CDATA[<p>I recently bought an M2 Pro 16&quot; MacBook Pro. My router supports WiFi 6 so I'm in a WiFi 6 network. I use my Mac in Clamshell mode most of the time connected to two external monitors. Since yesterday my WiFi signal becomes unusable while the Mac is in clamshell mode, opening the lid instantly fixes the issue. Is this something common or expected? I'm still able to return the unit and get a new one but before doing that I want to make sure that there is indeed something wrong with this particular Mac.</p>
<p>⟐ Answer accepted April 14, 2023 at 11:35 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/780368/Losing+WiFi+signal+when+in+clamshell+mode</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/780368</guid>
<pubDate>Fri, 14 Apr 2023 11:35:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: MBPro 16” (Late 2023) Won’t Power On After macOS Tahoe Update]]></title>
<description><![CDATA[<p>Hello everyone,</p>
<p>I’m hoping someone can help me troubleshoot a serious issue.</p>
<p>About a week ago, I purchased a complete display assembly from iFixit for my 16-inch MacBook Pro (Late 2023) and followed the repair guide to replace the screen. The repair appeared to be successful. The MacBook powered on normally and I used it daily for about a week without any problems.</p>
<p>This morning, I initiated a macOS Tahoe update. During or after the update process, the computer became completely unresponsive.</p>
<p>Current symptoms:</p>
<ul><li>No signs of life at all.</li><li>Screen remains black.</li><li>No startup chime.</li><li>No keyboard backlight.</li><li>No response when opening the lid.</li><li>No response when holding the power button for 10+ seconds.</li><li>No visible indication that the machine is charging.</li></ul>
<p>My biggest concern is that I do <strong>not</strong> have a recent backup of my data.</p>
<p>My questions are:</p>
<ol><li>Has anyone experienced a MacBook Pro becoming completely unresponsive after a macOS Tahoe update?</li><li>Could this be related to the display assembly replacement, even though the computer worked perfectly for a week afterward?</li><li>Are there any recovery steps I should try before opening the machine again?</li><li>Is there a way to revive the system using DFU Restore or DFU Revive, and if so, would that preserve my data?</li><li>If the logic board has failed, what are my options for recovering the data stored on the internal SSD?</li></ol>
<p>Any guidance would be greatly appreciated. I want to avoid making the situation worse and would like to preserve my data if possible.</p>
<p>Thank you.</p>
<p>⟐ Commented June 26, 2026 at 14:22 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/960809/MBPro+16%E2%80%9D+(Late+2023)+Won%E2%80%99t+Power+On+After+macOS+Tahoe+Update</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/960809</guid>
<pubDate>Fri, 26 Jun 2026 14:22:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: MacBook M2 keyboard remplacement]]></title>
<description><![CDATA[<p>Hello, I need to change a few keys on a MacBook Pro M2 model 2780 keyboard. I found replacement keys from sellers, supposedly compatible with the M1 2485 &amp; M2 2780, could you confirm to me that the keys of the 2485 are indeed the same as those of the 2780?</p>
<p>Do the keyboard keys on the M2 2780 unclip as easily as on the M1 Macbook Pros?</p>
<p>Do both keyboards use the same clipping system?</p>
<p>--------------------------------------------------</p>
<p>Bonjour,</p>
<p>j'ai besoin de changer quelques touches sur un clavier de MacBook Pro M2 model 2780. J'ai j'ai trouvé des touches de remplacements chez des vendeurs, des touches compatibles avec les M1 2485 &amp; M2 2780, pourriez-vous me confirmer que les touches du 2485 sont bien les mêmes que celles du 2780?</p>
<p>Si oui, est-ce que les touches du clavier du M2 2780 se déclipsent aussi facilement que sur les Macbook Pro M1 ?</p>
<p>Les deux claviers utilisent-ils le même système de clipsage ?</p>
<p>⟐ Answered January 27, 2024 at 3:18 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/833320/MacBook+M2+keyboard+remplacement</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/833320</guid>
<pubDate>Sat, 27 Jan 2024 03:18:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Replace International Keyboard with US Keyboard]]></title>
<description><![CDATA[<p>I have an international MacBook Pro 16 (2023) and would like to replace the internal keyboard with a US keyboard. Any suggestions on how to go about doing that?</p>
<p>⟐ Answer edited July 07, 2023 at 16:14 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/799647/Replace+International+Keyboard+with+US+Keyboard</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/799647</guid>
<pubDate>Fri, 07 Jul 2023 16:14:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: USB-C ports and 2x2]]></title>
<description><![CDATA[<p>Do the new MacBook Pro’s USB-C ports, support USB-C 2x2 (20Gb)?</p>
<p>⟐ Answered June 19, 2023 at 9:15 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/771796/USB-C+ports+and+2x2</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/771796</guid>
<pubDate>Mon, 19 Jun 2023 09:15:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Broken keyboard hinge on the down arrow]]></title>
<description><![CDATA[<p>After one month of usage the keyboard hinge broke for the down arrow. Has anyone else here had the same problem?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/GGlA1pGiF6W2rmFi.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/GGlA1pGiF6W2rmFi.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/1crKQh4MUJJcIUT1.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/1crKQh4MUJJcIUT1.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_01_Num_23" class="header">Update (06/01/23)</h3></div>
<p>I recived The parts from <a href="https://www.thebookyard.com/" rel="nofollow noopener noreferrer" target="_blank">TheBookYard</a> and I got the computer fixed.</p>
<p>I used parts from a 2021 Macbook Pro, they were compatible with the 2023 model.</p>
<p>I Ordered:</p>
<ul><li>1 x Up/down MacBook Pro/Air (Type-R) : Grade-A</li><li>1 x Scissor Clip - Arrow Keys (Type-R) : Recycled</li></ul>
<p>Final Result:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/wtEWobQAigqOTMhr.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/wtEWobQAigqOTMhr.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>The customer suport at <a href="https://www.thebookyard.com/" rel="nofollow noopener noreferrer" target="_blank">TheBookYard</a> was great! thanks <a class="user-mention-link notranslate" href="/User/408812/DanJ">@danj</a> fo the sugestion!</p>
<p>⟐ Commented June 02, 2023 at 8:26 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/780555/Broken+keyboard+hinge+on+the+down+arrow</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/780555</guid>
<pubDate>Fri, 02 Jun 2023 08:26:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Horizontal lines and flickering display issue]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/WvxYcr5OHESNMTfd.standard" width="282" height="128" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/WvxYcr5OHESNMTfd.full&quot;, '', 'width=1439,height=657')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/5XexTShIt5IBxUnL.standard" width="127" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/5XexTShIt5IBxUnL.full&quot;, '', 'width=1440,height=2558')" /></div>
<p>About a week ago these visual issues have started, which I have assumed were linked to the flex cable that goes into the display assembly itself, making it impossible to fix.</p>
<p>The issue is triggered either by pressing the plastic bottom bezel at the left corner, or by moving the orientation of the screen.</p>
<p>I put my laptop for sale on a local marketplace, and someone called today saying the same happened to his 16&quot; M1 Pro. He told me a repair shop has successfully repaired it by replacing a ribbon cable hidden behind the said plastic bezel strip, and the repair cost him very little money.</p>
<p>Does anyone have any idea about what exactly could've went bad so I can explain it to technicians that would attempt a repair for the laptop?</p>
<p>So far, I've just been quoted a full display assembly replacement costing from 800 to 1000€, which isn't an option. Thanks</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/NEky2UTYpqOjd3dL.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/NEky2UTYpqOjd3dL.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/aAJ6T4ZJANhAuq4v.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/aAJ6T4ZJANhAuq4v.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/pbmWEOKCahi4xKxJ.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/pbmWEOKCahi4xKxJ.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/JyJRguHTPNmwXiJA.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/JyJRguHTPNmwXiJA.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>- Hard to see on camera, but that region of the chin bezel &gt; display seems to have kind of a bloated/warping effect.</p>
<p>⟐ Answer accepted July 06, 2026 at 15:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/962649/Horizontal+lines+and+flickering+display+issue</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/962649</guid>
<pubDate>Mon, 06 Jul 2026 15:05:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Will not turn on]]></title>
<description><![CDATA[<p>I had my MagSafe 3 power cable attached, but one day I realized there was no charging light.</p>
<p>I bought a new MagSafe 3 charger and the amber light immediately came on.</p>
<p>24 hours later, even long-press doesn’t work.</p>
<p>My theory is the original MagSafe 3 cable failed and the battery went completely flat before I noticed.</p>
<p>I’m no expert but I recall the Clamshell batteries had a suicide switch to prevent lithium fires.</p>
<p>Do I have to replace my entire top shell?</p>
<p>⟐ Answer edited September 13, 2025 at 5:36 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/916898/Will+not+turn+on</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/916898</guid>
<pubDate>Sat, 13 Sep 2025 05:36:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Replacing M2 Screen: Pro Lid Angle Sensor and True Tone]]></title>
<description><![CDATA[<p>Hi, thanks in advance.</p>
<p>I’ve been reading online, but I’m still not sure about one thing:</p>
<p>When replacing the screen on an M2 MacBook, do you also need to replace the <strong>Lid Angle Sensor</strong>, or is there a way to <strong>calibrate it</strong> instead?</p>
<p>Also, is <strong>True Tone</strong> completely unrecoverable after a screen replacement?</p>
<p>Thanks again!</p>
<p>⟐ Commented July 23, 2025 at 17:45 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/896313/Replacing+M2+Screen:+Pro+Lid+Angle+Sensor+and+True+Tone</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/896313</guid>
<pubDate>Wed, 23 Jul 2025 17:45:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Replacement space grey screws for bottom case]]></title>
<description><![CDATA[<p>Anyone know where you can buy replacement screws for the 2023 16&quot; model that are colour matched?</p>
<p>I'm in the UK</p>
<p>Mine came loose I tightened it (stripping the paint) and then realised I probably voided the warranty with that. I've seen places refuse to service devices that have been opened so figured I should probably replace my screws.</p>
<p>⟐ Answered March 18, 2024 at 23:55 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/816215/Replacement+space+grey+screws+for+bottom+case</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/816215</guid>
<pubDate>Mon, 18 Mar 2024 23:55:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Can the storage be upgraded?]]></title>
<description><![CDATA[<p>My MacBook Pro is out of memory (storage space)! Short of going to the store and buying the next tier up, Is it possible to upgrade the drive in my MacBook Pro M2?</p>
<p>If yes, what drives can I use, and how do I do it?</p>
<p>⟐ Answer accepted March 06, 2024 at 16:59 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/839874/Can+the+storage+be+upgraded</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/839874</guid>
<pubDate>Wed, 06 Mar 2024 16:59:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Liquid got on the Motherboard of MacBook Pro (16-inch, 2023)]]></title>
<description><![CDATA[<p>Liquid got on the Motherboard of MacBook Pro (16-inch, 2023)</p>
<p>The computer worked for one day and stopped turning on.</p>
<p>The charge indicator does not light up when the charging cable is connected.</p>
<p>What if it is possible to revive him after this?</p>
<p>There was some liquid and traces of electrolysis on the motherboard:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/q45QZuWLYpw3HFBc.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/q45QZuWLYpw3HFBc.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/tGBojH6yoGEKYIW3.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/tGBojH6yoGEKYIW3.full&quot;, '', 'width=1200,height=1600')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ScKmCMYCiPaYB34e.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ScKmCMYCiPaYB34e.full&quot;, '', 'width=1200,height=1600')" /></div>
<p>Everything was dry under the lid and on the back side:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/qdg4KGOJrNGANqdR.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/qdg4KGOJrNGANqdR.full&quot;, '', 'width=1200,height=1600')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/JejdlFCFFmvf1L3J.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/JejdlFCFFmvf1L3J.full&quot;, '', 'width=1200,height=1600')" /></div>
<p>After cleaning:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/SlZNHtYKd64TMLXB.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/SlZNHtYKd64TMLXB.full&quot;, '', 'width=1200,height=1600')" /></div>
<p>Please tell me what can be done with this motherboard to revive the computer, if at all there is a chance?</p>
<p>------------------------------------</p>
<p>I checked the battery today and it is completely discharged. And when connected it does not charge. It turns out that the computer turned off when the battery ran out.</p>
<p>There is 0 volt on these contacts (MagSafe). Shouldn't it be 3v by default and 16,5 under load?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/PIplHHHDSwAmV3Iw.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/PIplHHHDSwAmV3Iw.full&quot;, '', 'width=1200,height=1600')" /></div>
<p>The charging unit is working, I tested it on an old MacBook Pro 2019.</p>
<p>Need I  try to buy a new charging cable?</p>
<p>Or try to charge the battery directly from the charging unit and check the functionality of the board on a charged battery?</p>
<p>⟐ Commented January 24, 2024 at 17:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/833572/Liquid+got+on+the+Motherboard+of+MacBook+Pro+(16-inch,+2023)</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/833572</guid>
<pubDate>Wed, 24 Jan 2024 17:43:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Spilled water - used heater to dry - back panel cracking sound]]></title>
<description><![CDATA[<p>I wanted to ask maybe you guys have an idea of what's going on.</p>
<p>I accidentally spilled less than a cups worth of sparkling water onto my computer, immediately turned it off, put it upside down and dryed it. For a bit less than an hour, I pointed a heater towards the keyboard, I put the temperature to more or less imitate the chassis getting hot under a huge load, or working outside in a hot environment.</p>
<p><br />The laptop still works fine, diag showed no errors, hopefully no corrosion, but after this, the sound appeared when pressing the left side bottom. It's driving my OCD, so I was wondering, Could the heater have caused it? I should probably have it checked out? I looked at the teardowns, and there doesn't seem to be anything that might be impacted.<br /></p>
<p><br />Opinion appreciated, thank you!</p>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="s5FojUKDOwGajrnr" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/RqPU4bDg5Yssm3Aj.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/s5FojUKDOwGajrnr_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_01_14_Num_24" class="header">Update (01/14/24)</h3></div>
<p><a class="user-mention-link notranslate" href="/User/408812/DanJ">@danj</a></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/V2afyWrXMYBWwuKm.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/V2afyWrXMYBWwuKm.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/EruVmDuDZ4GYJVOF.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/EruVmDuDZ4GYJVOF.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/R3ArjboKbiHObcRI.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/R3ArjboKbiHObcRI.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_01_14_Num_24_1" class="header">Update (01/14/24)</h3></div>
<p><a href="https://www.ifixit.com/User/408812/Dan" target="_blank">@danj</a></p>
<p>Ok thanks, is it better now? Took pics from all sides</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/6IQAXHJKLDI5sxAF.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/6IQAXHJKLDI5sxAF.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ITUSimWQPTl3CF6y.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ITUSimWQPTl3CF6y.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/AQjuFyWeAZjtkyJj.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/AQjuFyWeAZjtkyJj.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/abvdwJyIi3jKuPK3.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/abvdwJyIi3jKuPK3.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Answer accepted January 23, 2024 at 2:03 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/832137/Spilled+water+-+used+heater+to+dry+-+back+panel+cracking+sound</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/832137</guid>
<pubDate>Tue, 23 Jan 2024 02:03:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Can I replace the keyboard on my 2023 16" MacBook Pro?]]></title>
<description><![CDATA[<p>Hi Folks -</p>
<p>I spilled soda on my MacBook keyboard several months ago and the keys are still sticky.  They get worse when I run high compute functions such as rendering or Final Cut Pro, probably due to heat.  Apple wants $1,500 to fix it because they require a full liquid-damage assessment to ensure it didn't damage other internal components.  I'm willing to pay but not that much.</p>
<p>I'm not seeing a keyboard for this model on iFixit, anybody know if the keyboard in this model can be replaced or where I can find the parts?</p>
<p>Thanks,</p>
<p>John</p>
<p>⟐ Answer edited December 28, 2023 at 10:46 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/829905/Can+I+replace+the+keyboard+on+my+2023+16%22+MacBook+Pro</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/829905</guid>
<pubDate>Thu, 28 Dec 2023 10:46:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: What about chip swap for Screen Replacement]]></title>
<description><![CDATA[<p>Hello, I’m faced with having to replace the display assembly on a 2023 MacBook Pro 16-inch a2780 M2 Max (VH60WXG703).</p>
<p>I’ve done plenty of Mac screen replacements, but this one I hear has a chip that I need to swap out. Can anybody detail that process?</p>
<p>Also, can anyone verify that serial number (in other words the specific model)? I’m not finding it on any of my usual resources, due to its recent release.</p>
<p>Thank you.</p>
<p>⟐ Answer unaccepted December 20, 2023 at 17:55 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/826287/What+about+chip+swap+for+Screen+Replacement</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/826287</guid>
<pubDate>Wed, 20 Dec 2023 17:55:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: Do Apple screen display panels have a serial number?]]></title>
<description><![CDATA[<p>I sold an Apple LCD panel from a 16-inch MacBook Pro on eBay and now the guy's sending me pictures claiming that it has &quot;burn marks&quot;</p>
<p>As will all items over $500, I marked it near the cables and filmed the entire procedure from removing the screen, testing it, then packaging it.</p>
<p>THERE'S NO WAY I sent him a screen with burn marks... He either &amp;&amp;^&amp;@@ it up (in which I can do nothing about) or he's trying to pull a fast one on me.</p>
<p>I need to make sure that he returns MY PRODUCT and not his own old broken screen, so I'm wondering if the screens are serialized and how to get the number off of it.</p>
<p><strong>About 10 years ago...</strong>, I swapped a genuine Apple screen for another on a 2011 15&quot; MacBook and when the logic board crashed, I took it to get replaced under the &quot;Extended Warranty Program&quot; only to be DENIED by the genius. What was his justification? He claimed that someone's installed an &quot;aftermarket screen&quot;. Now, this was a genuine screen, but that's besides the point. He KNEW it wasn't the original screen, and had been replaced. MY QUESTION IS: <strong>If I reinstall this panel back into the computer, how can I tell if it's the original screen?</strong></p>
<p>⟐ Answer edited June 18, 2023 at 14:52 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/797585/Do+Apple+screen+display+panels+have+a+serial+number</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/797585</guid>
<pubDate>Sun, 18 Jun 2023 14:52:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 16" 2023: I just bought this it wont turn on!?!]]></title>
<description><![CDATA[<p>After someone helped me eject my disk drive I could finally sell it to my cousin so then I bought this new MacBook pro and when I tried turning it on nothing happened did I just waste 4k on this broken laptop? I bought this from a apple store btw</p>
<p>⟐ Commented April 15, 2023 at 13:38 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/780640/I+just+bought+this+it+wont+turn+on!!</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/780640</guid>
<pubDate>Sat, 15 Apr 2023 13:38:46 -0700</pubDate>
</item>
</channel>
</rss>
