<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;MacBook Pro&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/MacBook_Pro/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;MacBook Pro&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 28 Aug 2026 11:21:11 -0700</pubDate>
<item>
<title><![CDATA[MacBook Pro 13" Unibody: MacBook Pro turning off but when I hold a key it stays on]]></title>
<description><![CDATA[<p>What the question title says, If I change the battery will it stop doing so?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/970041/MacBook+Pro+turning+off+but+when+I+hold+a+key+it+stays+on</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/970041</guid>
<pubDate>Fri, 28 Aug 2026 00:10:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 13" Unibody Mid 2012: Battery not detected, powering off while booting]]></title>
<description><![CDATA[<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Question" class="header">Question</h3></div>
<p>Hi, I have a 2012 Unibody MacBook Pro that I'm having a really weird issue with.</p>
<p>It wasn't used for around 6 months, but before that it was working perfectly fine. The battery was also working normally before I stopped using it.</p>
<p>Now, when I try to turn it on normally, it starts booting for about 1% and then suddenly turns off. But here's the weird part: if I hold down <strong>any key on the keyboard</strong>, it stays on and works like a normal laptop. As soon as I let go of the key, it immediately turns off.</p>
<p>The battery also isn't detected at all, and the battery indicator lights on the side don't work either.</p>
<p>I'm not really sure what's causing this. Could this be a battery or SMC issue, or could something on the logic board be causing it?</p>
<p>Is there anything I can test or try myself before taking it to a repair shop?<br /><br />Also, diagnostics show reference code :PPT001, PFM001.</p>
<p>Thanks!</p>
<p>⟐ Commented August 27, 2026 at 21:01 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969766/Battery+not+detected,+powering+off+while+booting</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969766</guid>
<pubDate>Thu, 27 Aug 2026 21:01:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 13" Retina Display Late 2013: Replacement uk querty key set]]></title>
<description><![CDATA[<p>Unfortunately ifixit inly have an US querty set, can anyone point me to where I can purchase a replacement UK querty keycaps set compatible with a <strong>MacBook Pro 13&quot; Retina Late 2013 (A1502, EMC 2678). Many thanks</strong></p>
<p>⟐ Answer edited August 27, 2026 at 15:57 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969922/Replacement+uk+querty+key+set</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969922</guid>
<pubDate>Thu, 27 Aug 2026 15:57:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 13" Function Keys 2017: MacBook Pro 2017 battery board data cable socket near fan has no locking tab]]></title>
<description><![CDATA[<p>I am replacing the battery on a MacBook Pro 13&quot; 2017 (Function Keys, A1708). On the battery board data cable, the socket closest to the fan does not have any locking tab or hinged bar at all, unlike the other end. I cannot get the cable to seat fully into this socket. How does this specific connector secure the ribbon cable?</p>
<p>⟐ Commented August 27, 2026 at 13:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969955/MacBook+Pro+2017+battery+board+data+cable+socket+near+fan+has+no+locking+tab</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969955</guid>
<pubDate>Thu, 27 Aug 2026 13:43:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 13" Retina Display Early 2015: bleeding on corners and stiff hinges]]></title>
<description><![CDATA[<p>hi, i got this 2015 pro since January, And right now, i just repaired it by replacing the gasket, rubber feet, and the battery. one thing i'm getting worried is they there's this weird yellowish backlight bleed on my corner when i choose a black wallpaper.<br /><br /></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/XqifVpfMmkUTlSMk.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/XqifVpfMmkUTlSMk.huge&quot;, '', 'width=900,height=1200')" /></div>
<p><br /><br />And also, The hinge is getting tight overtime. i kept opening it gently because the screen might crack. I still have 3 more years to graduate with this laptop.</p>
<p>⟐ Commented August 27, 2026 at 5:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969686/bleeding+on+corners+and+stiff+hinges</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969686</guid>
<pubDate>Thu, 27 Aug 2026 05:51:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 13" Unibody Mid 2009: MacBook Pro screen fading out]]></title>
<description><![CDATA[<p>Hi there!</p>
<p>I found some similar questions, but none specific enough to make sure they were the same problem, and none with detailed solutions.</p>
<p>A video of the symptoms before I explain with words:</p>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="taKGJYlJbFRT1png" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/F53EqvGe6wTISmAV.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/taKGJYlJbFRT1png_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<p>My Macbook's screen sometimes starts fading out. First the pixels get wider, meaning the image seems pixelated. Then the colors start changing, until it gets inverted, then it fades to completely dark grey.</p>
<p>There's no correlation of when it does that and when it doesn't. Sometimes I am just working while everything is normal, and all of a sudden it starts. Sometimes it’s in the morning, I am just waking it from sleep, without even touching the screen, and it’s in that state.</p>
<p><strong>If I then try to bend a little bit the upper left corner of the screen</strong>, it goes back to normal. Sometimes it’s enough to keep it working without my pressure. Sometimes as soon as I let go, it starts fading again, and I have to push the whole computer against something to exert that pressure while I work.</p>
<p>Sometimes the problem will remain for weeks and months, and at some point go away for weeks and months.</p>
<p>Sometimes I have to press very hard for the screen to come back to normal, sometimes a very gentle touch will suffice.</p>
<p>It’s mostly on the upper left corner that I have to bend. Sometimes it’s on the upper right corner, but rarely.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_What_I_tried" class="header">What I tried</h3></div>
<p><strong>When I plug an external display, it works fine</strong>.</p>
<p>I tried opening up the Macbook and disconnecting the screen, vacuuming the cable, socket, and everything.</p>
<p>Sometimes after I put everything back together, the problem goes away for a few weeks. Sometimes it doesn’t change anything.</p>
<p>I also tried opening the case while the laptop is on, and moving a little bit the display cable, to see if it changes anything. It didn’t.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Other_things_I_noticed" class="header">Other things I noticed</h3></div>
<p>I noticed that <strong>some kind of shield on the motherboard’s socket is out of position</strong>. But it seems unlikely to me to cause the problem:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/J1AAoykN1YvK22TE.standard" width="282" height="211" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/J1AAoykN1YvK22TE.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>I also noticed a <strong>visual irregularity on the display cable’s outer wrapping</strong>, but I don’t know whether that’s damage or not:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/wV4YE6og2qPuuWsV.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/wV4YE6og2qPuuWsV.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/XLNeFXqdviFEZCAc.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/XLNeFXqdviFEZCAc.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>I very recently noticed that <strong>the top part of my LCD is unglued from its shell</strong>. But I don’t know whether it was there before, and thus could be a cause, or whether it’s the consequence of my bending the top left corner of the screen so many times.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_How_I_see_things" class="header">How I see things</h3></div>
<p>It seems to me the screen itself is fine.</p>
<p>So I feel like it could be either the socket on the motherboard, or the cable, or the socket on the LCD. Right?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Questions" class="header">Questions</h3></div>
<p>Does anyone know whether there is a quick fix to this, or how to narrow down the cause?</p>
<p>My partner’s laptop is a 2010 macbook pro, so the same but one year younger. Do you know if I could plug her screen onto my laptop? If so I could rule out the motherboard socket, or conversely incriminate it.</p>
<p>Thanks a lot in advance for the help!</p>
<p>⟐ Commented August 26, 2026 at 19:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969348/MacBook+Pro+screen+fading+out</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969348</guid>
<pubDate>Wed, 26 Aug 2026 19:05:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Retina Display Mid 2015: MacBook CPU constantly throttled to 0.8GHZ after iFixit battery swap]]></title>
<description><![CDATA[<p>Hello everyone,</p>
<p>I have recently gotten my hands on a Mid 2015 15” MBP that was running slow, hoping I could get it fixed back up for personal use.</p>
<p>The previous owner had apparently swapped the old battery out with a new iFixit replacement one and then immediately sold the device as it has been running slow ever since. Using IntelPowerGadget on OSX or Task-Manager on Windows shows the CPU constantly being clocked down to 0.8ghz. This is definitely not thermal throttling as the chipset never exceeds 50C, there are also no faulty sensors when checking with HWMonitor.</p>
<p>The original battery had been discarded so I cannot check whether this issue is actually caused by the battery at all, however inspecting the battery visually and using CoconutBattery I can see that it is not an OEM battery since there is no battery serial number being displayed.  Running the hardware diagnosis (holding the “D” key at startup) reveals that the battery might have problems but it says I should still be able to use the device without any noticable changes, showing the error code PPT004.</p>
<p>I then went ahead and bought <a href="https://www.ebay.com/itm/Genuine-Apple-MacBook-Pro-15-A1398-Mid-2015-Battery-A1618-80-Capacity-/324220003431?_trksid=p2349526.m4383.l10137.c10&amp;nordt=true&amp;rt=nc&amp;orig_cvip=true" rel="nofollow noopener noreferrer">this</a> used original A1398 battery, thinking it was salvaged from another Macbook, however it ended up being some sort of refurbished third party battery causing the same issues again so I will have to return it anyway. The values shown on CoconutBattery are similar for both batteries (both less than 10 charge cycles, etc.) so I have just attached an image of the iFixit one below.</p>
<p>The machine itself is in mint condition, I have made sure to look for any water damage on the logic board but it seems perfectly clean, after all the device can be used flawlessly with the exception of it running at 1/4 the supposed speed.</p>
<p>I did come across similar threads however they were usually regarding older macbooks or were only having this issue intermittently when plugging in an external monitor, etc.</p>
<p>Others proposed just deleting the IOPlatformFamily.kext from OSX to get rid of the Intel Speedstepping feature, however this method is somewhat outdated and seems like a stupid idea anyway. A similar solution was being shared <a href="https://github.com/bernardowilson/NoBatteryNoProblem.kext" rel="nofollow noopener noreferrer">here</a>, however that is again  just circumventing the issue instead of fixing it, and even then Im not sure that would at all.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/FLSXI3SykwkZfAAG.standard" width="282" height="150" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/FLSXI3SykwkZfAAG.full&quot;, '', 'width=796,height=424')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/5eqMjRooZfJSIDwK.standard" width="247" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/5eqMjRooZfJSIDwK.full&quot;, '', 'width=1084,height=990')" /></div>
<p>Essentially I just want to know two things:</p>
<ol><li>Is this throttling behaviour really linked to a 3rd party battery instead of a logic board fault, and if so, why would anyone buy or manufacture such batteries if they make the device useless? If this is the case there should have been plenty of others with this exact issue, yet I have only found a few threads discussing a similar issue</li><li>With the iFixit as well as the other “genuine” battery not working as intended, where would I even begin looking for an actual OEM battery within Europe without having to get it replaced at an Apple store?</li></ol>
<p>I never had any issues replacing the battery on a 2012 MBP, so Its fair to say this behaviour could just be another one of Apples shenanigans to get peoples devices fixed at Apple only and nowhere else, but I just couldnt find a definitive answer especially since I dont have the original battery to compare against.</p>
<p>I wouldn’t know where to ask otherwise, so any reply would be very appreciated!</p>
<p><strong>Update:</strong></p>
<p>I have tried using ThrottleStop on BootCamp Windows according to <a href="https://apple.stackexchange.com/questions/380493/cpu-throttling-on-macbook-with-bad-battery-and-catalina" rel="nofollow noopener noreferrer">this</a> thread, this does however also not work. Deleting the IOPlatformPluginFamily.kext as mentioned in the same thread is not an option since it does not even exist on my OS X Catalina installation.</p>
<p><strong>Final Update (Found a solution):</strong></p>
<p>So it turned out not to be a battery related issue . The person I bought the device from stated the issue appeared after swapping it for an iFixit replacement battery, but after buying yet another OEM battery the problem still persisted.</p>
<p>Instead, the issue was related to the CPU current sensing circuitry. I didnt manage to find accurate boardview and schematics for my specific model (820-00138) so I had to use this XinZhiZao (similar to ZXW tool) maintenance program which had the correct board layout to find the problem.</p>
<p>The issue was caused by the &quot;SMC_CPU_IMON_ISENSE&quot; line which is produced by the U7200 power management IC. This chip is responsible for measuring the CPU power usage among other things, and sends the signal through R5530 directly to the SMC.  This line was permanently stuck at 1.8V which made the SMC read a high CPU power draw, so it throttled the CPU to 0.8ghz clock for safety reasons.</p>
<p>I ended up running a jumper (blue) from this line to ground, thus forcing the line to 0V.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/PwmOQhcfWEB1Xgud.standard" width="242" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/PwmOQhcfWEB1Xgud.full&quot;, '', 'width=406,height=378')" /></div>
<p>This way the system now reads CPU current as 0W and I can finally use the machine with its intended performance. No lags, everything finally runs smoothly. It also no longer gets stuck in sleep mode after closing the lid.</p>
<p>Obviously this fix is only a workaround as I still dont know what was pulling the line to 1.8V, so I assume it was either the SMC or U7200 which shorted the line to a neighboring power line somewhere. I didnt want to risk ruining the SMC by reballing it so shorting the pad for C5530 to ground seemed easier to do. However this means there is a constant 1.8V short to ground so I might want to replace the jumper wire with a resistor to avoid losing much battery power being wasted into the short in the future.</p>
<p>In conclusion, the built-in Apple Diagnostics (Holding down Cmd + D on startup) did find an issue, however it was not related to the battery but rather the SMC or U7200. My assumption of having to use a OEM battery was wrong, as it also now works just fine with the replacement iFixit battery. I used HWmonitor on OSX to check the “CPU Package Total” readings, which were at 100 watts and above.  After the fix it is reading -W, so the remaining battery time estimations might be inaccurate, but it technicallly isnt necessary.</p>
<p>Im not exactly sure how a simple battery swap could have caused this issue, but since I didnt find much information regarding Macbooks being throttled to 800mhz CPU performance, make sure to check all temperature and current readings using some sort of monitoring tool like mentioned above. A faulty temperature sensor might possibly cause a similar issue.</p>
<p>Hope this helps</p>
<p>⟐ Answered August 25, 2026 at 17:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/646298/MacBook+CPU+constantly+throttled+to+0.8GHZ+after+iFixit+battery+swap</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/646298</guid>
<pubDate>Tue, 25 Aug 2026 17:05:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" Late 2023 (M3 Pro and M3 Max): Is it possible to fix a misaligned screen on a MacBook Pro?]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/avtXUVFcRURNaAa4.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/avtXUVFcRURNaAa4.full&quot;, '', 'width=1080,height=1440')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/h2nNInVQ6XQhATCZ.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/h2nNInVQ6XQhATCZ.huge&quot;, '', 'width=901,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/2GQBgjDqJwJJOIVl.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/2GQBgjDqJwJJOIVl.full&quot;, '', 'width=1080,height=1440')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/eQI6P2bMTRV5FjDe.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/eQI6P2bMTRV5FjDe.full&quot;, '', 'width=480,height=640')" /></div>
<p><br />Hi everyone,</p>
<p>I have a Late 2023 MacBook Pro 14&quot; (M3 Pro), and I've noticed that the display lid is slightly misaligned to the right. When the laptop is closed and I run my fingers along the side edges, I can clearly feel that the top lid is slightly off-center compared to the bottom case.</p>
<p>I've seen other people reporting this exact same issue online, so I'm attaching a few more photos of misaligned screens for reference.</p>
<p>I would like to know: Is it possible to open the bottom case and adjust the hinge screws to realign the display perfectly?</p>
<p>Thanks in advance for the help!</p>
<p>⟐ Answer edited August 25, 2026 at 13:16 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969669/Is+it+possible+to+fix+a+misaligned+screen+on+a+MacBook+Pro</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969669</guid>
<pubDate>Tue, 25 Aug 2026 13:16:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 13" Unibody Mid 2010: made a really weird noise last night]]></title>
<description><![CDATA[<p>For mw I dont know how to sumbit my name My name is Mina Hanna im 15 years old and my mac has the same problem. I watch youtube alot. My MBP Was fine till it made a really weird noise last night. Then all my games starting lagging. The day before everything was fine. Now i would log in to something like WoW(World of Warcraft) and it would lag like crazy. I need help with this problem please. I dont wanna buy a new comp putting into consideration that a macbook pro is one solid mechanism so you cant open it to get the hard drive, mother board, battery, etc.</p>
<p>⟐ Answered August 24, 2026 at 8:06 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/184488/made+a+really+weird+noise+last+night</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/184488</guid>
<pubDate>Mon, 24 Aug 2026 08:06:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" Late 2023 (M3 Pro and M3 Max): Apple air intake module removal bit]]></title>
<description><![CDATA[<p>For the removal of the antenna screws of MacBook Pro m3 pro the p2 bit is recommended by ifixit but the apple in the manual recommends the Torx safety 1IPR screws bit</p>
<p>⟐ Commented August 24, 2026 at 7:52 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/969489/Apple+air+intake+module+removal+bit</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/969489</guid>
<pubDate>Mon, 24 Aug 2026 07:52:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 13" Unibody Late 2011: Magsafe L connector disassemble. Replace the connector.]]></title>
<description><![CDATA[<p>I have three 60w magsafe 1 power adapters. Two of them are fully original (including the cables) and one has a non original wire wit L connector replaced. It’s a well known fact that those replacement cables with L connectors do not work properly, the charging indicator is always green (even when the battery is being charged) and the overcharge protection doesn’t work. But on the other hand, the quality of the unoriginal replacement wire is a hundred times better than the Apple original, because apple’s wires crack very fast. Mine actually cracked like a year after I bought it new from one of those apple shops.</p>
<p>So I want to disassemble the original Apple L connector and solder it to the unoriginal cable. I don’t mind cutting off the replacement L connector, as it is of no use for me, because when I use it with my Macbook pro 13” late 2011, the battery gets hot, and when I used it with my Macbook white mid 2009, the battery swelled and now when I use that MB 2009 with the unoriginal cable, with no battery, it won’t even turn on (it does turn on when used with fully original power adapter).</p>
<p>So… disassemble an original magsafe L connectror and solder it to another wire. How do I do that? In fact the problem is more about disassembling the L connector, because I do know how to solder things.</p>
<p>⟐ Commented August 22, 2026 at 15:22 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/606146/Magsafe+L+connector+disassemble.+Replace+the+connector.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/606146</guid>
<pubDate>Sat, 22 Aug 2026 15:22:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Unibody Mid 2010: MacBook Pro Mid 2010 A1286 won't run on battery (0 Amps) after bulging battery replacement]]></title>
<description><![CDATA[<p>I am troubleshooting a MacBook Pro 15&quot; Unibody Mid 2010 (A1286) running OS X 10.13.6. I recently installed a new iFixit A1321 battery because the original battery was bulging and labeled &quot;Replace Now.&quot;</p>
<p>The issue:</p>
<p>1. With the new battery, the MagSafe light stays green. System Information sees the battery at 33% (2308mAh) but shows 0 Amperage and &quot;Not Charging.&quot;</p>
<p>2. If I unplug the MagSafe, the laptop immediately shuts off.</p>
<p>3. I reinstalled the old (bulging) battery to test. It shows 100% (4322mAh) and &quot;Fully Charged,&quot; but the laptop still shuts off immediately if the power cord is disconnected.</p>
<p>4. CRITICAL FINDING: The battery indicator button (on the left side) ONLY works when the MagSafe is plugged in. When plugged in, it shows 3 LEDs (consistent with 33%). When unplugged, the indicator button does nothing.</p>
<p>5. I have already:</p>
<p>- Reset the SMC and NVRAM/PRAM multiple times.</p>
<p>- Verified I am using an 85W MagSafe adapter.</p>
<p>- Reseated the battery connector and inspected the logic board pins.</p>
<p>- Ran Disk Utility First Aid.</p>
<p>Is it possible the original bulging battery blew a current-sensing resistor or a MOSFET on the logic board? What specific components should I test with a multimeter to diagnose why the battery rail is not being energized?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_14_Num_26" class="header">Update (06/14/26)</h3></div>
<p>Here is an image (maybe) of the coconut app and the system report.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Cw2uIwWc2KoChHiZ.standard" width="192" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Cw2uIwWc2KoChHiZ.full&quot;, '', 'width=719,height=846')" /></div>
<p>Here is an image of the system report with the bad battery</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/cojhFKbkybk1B3iF.standard" width="217" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/cojhFKbkybk1B3iF.full&quot;, '', 'width=509,height=528')" /></div>
<p>===  ===</p>
<p>⟐ Commented August 21, 2026 at 11:54 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/959544/MacBook+Pro+Mid+2010+A1286+won&#039;t+run+on+battery+(0+Amps)+after+bulging+battery+replacement</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/959544</guid>
<pubDate>Fri, 21 Aug 2026 11:54:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Retina Display Mid 2014: How to remove anti-glare coating effectively?]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/wf5m3uboUyoNCySv.standard" width="127" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/wf5m3uboUyoNCySv.huge&quot;, '', 'width=675,height=1200')" /></div>
<p>This is my progress on removing the anti-glare coating after 2 hours. I tried Listerine, 90% alcohol, Peek Metal Polish, anti-bacterial wipes, bleach, and nail polish remover w/ acetone (before I read that someone else damaged the glass itself because of acetone). Luckily, my glass is still fine. Unfortunately, I haven't made much progress as you can see from the picture. I'm confused to why none of the solutions isn't working for me. Some said that Listerine alone worked well along with a microfiber cloth. I tried that but since it didn't work I moved on to try all the other solutions I mentioned. Is anyone else having this issue dispite of trying all kinds of solutions? And is there any other alternatives that would make it simple to remove w/o much time being spent?</p>
<p>⟐ Commented August 20, 2026 at 13:25 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/582699/How+to+remove+anti-glare+coating+effectively</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/582699</guid>
<pubDate>Thu, 20 Aug 2026 13:25:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Models A1151 A1212 A1229 and A1261: Would it, in theory, be possible to complete upgrade the logic board?]]></title>
<description><![CDATA[<p>I think that the external design of this series of MacBook Pro was just wonderful, the black keyboards and bezels on the models which came after it just don't look as good.</p>
<p>I know that the CPU and GPU are soldered onto the logic board, so therefore, my question would be; is there any much more modern logic board that would in theory fit inside the chassis of a 17 inch A1229? I know that the connectors would be completely different, but would there be anything stopping you if you did find a logic board that fits in and you could swap out the connectors etc.</p>
<p>Clearly this doesn't make sense if you were just trying to get value out of an old machine thinking it would be cheaper, but is it even possible in theory for someone who had an abundance of time and money?</p>
<p>⟐ Answered August 19, 2026 at 16:42 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/850461/Would+it,+in+theory,+be+possible+to+complete+upgrade+the+logic+board</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/850461</guid>
<pubDate>Wed, 19 Aug 2026 16:42:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Macbook Pro 14" 2023: Battery Charge limit not working after battery replacement?]]></title>
<description><![CDATA[<p>I replaced my MacBook battery with what I believe was a replacement part from iFixit. A few days later, I noticed the battery always charges to 100%, even though I set an 80% limit in macOS. I tried several terminal commands to reset to default settings, but had no luck. Now I’m worried it might be a hardware problem. Is this a common issue?</p>
<p>I’ve reinstalled the OS and restored from Time Machine, but the problem persists. Here’s a screenshot of the battery reading.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/hTpAFoR1BWWJPTCd.standard" width="192" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/hTpAFoR1BWWJPTCd.full&quot;, '', 'width=1104,height=1294')" /></div>
<p>I really hope this can be fixed, as I’d hate to keep the Mac connected to a dock with this issue. Thanks in advance.</p>
<p>⟐ Commented August 19, 2026 at 4:22 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/968140/Battery+Charge+limit+not+working+after+battery+replacement</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/968140</guid>
<pubDate>Wed, 19 Aug 2026 04:22:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 13" Retina Display Early 2015: Screen flickering only on MacOS]]></title>
<description><![CDATA[<p>Hi, I have a 2015 13 inch Retina MacBook Pro that has a display issue, when booted to macOS (I tried several macOS versions), the display just flickers continuously. Sometimes it's just flickering, other times the display would show corruptions, but:<br />- The display does not flicker in recovery mode, or in Safe Boot<br />- The display does not flicker in any other OS like Windows 10, Windows 11, and Ubuntu Linux<br />- The display stops flickering on macOS the moment I connect to an external display<br />- The flickering does not change/improve when adjusting the lid angle<br /><br />In the other OS scenarios I just described or when I use macOS with an external display, the display works PERFECTLY. No flickering, no hanging, brightness control works, it's just in macOS proper it starts acting broken, even went as far as to use it daily on Windows 11 and yeah, the display works perfectly.<br /><br />Things that I have tried:<br />- PRAM/NVRAM reset<br />- SMC reset<br />- Cleaning the connector on both the screen and motherboard<br />- Different power adapter <br />- Different macOS versions (tried El Capitan, Catalina, and Monterey)<br /><br />Note: the device has no battery. It runs from adapter only.</p>
<p>⟐ Commented August 18, 2026 at 7:56 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/968629/Screen+flickering+only+on+MacOS</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/968629</guid>
<pubDate>Tue, 18 Aug 2026 07:56:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 13" Unibody Mid 2012: Changing logic board to change graphic card]]></title>
<description><![CDATA[<p>Hey guys !</p>
<p>I have a mid-2012 13&quot; MacBook pro (2.5 Ghz, the cheaper model).</p>
<p>So, my main focus is to change my Graphic Card (i have the Intel HD Graphic 4000) and my RAM (from 4 GB to 8 GB), however I found out i had to change my motherboard (logic board) to be able to change my graphic card.</p>
<p>Therefore would it be possible to get the motherboard of the other mid-2012 Macbook Pro 13&quot; (2.9 Ghz), put it in my laptop and change the graphic Card to an NVIDIA ?</p>
<p>And the best question of all: would it be cheaper to buy a laptop just for Gaming ? Thats somethiin i dont want to do, having two laptops, thats too much.</p>
<p>And also because my mac works really well, he is just to shi**y to play games like Titanfall or BF4. I am stuck with Star wars and LoL right now. Feel my pain.</p>
<p>Just like Jon Snow, i know nothing. So please speak to me as if i was a toddler smashing  a star shaped block into the circle shaped hole.</p>
<p>⟐ Commented August 17, 2026 at 23:04 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/165719/Changing+logic+board+to+change+graphic+card</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/165719</guid>
<pubDate>Mon, 17 Aug 2026 23:04:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Why does my MacBook hard crash after opening lid?]]></title>
<description><![CDATA[<p>I have a M1 Macbook Pro 14&quot; (2021) that I have been using for 4 years.  For a long time, I simply used the OS it came out of the box with (macOS 12.1). It never gave any issues and I was too lazy to update it. One day I simply opened the lid of my macbook and tried to use Touch ID to open lock screen. After several attempts of trying to use Touch ID (it has a tendency to not work first time), I realized my mac froze and then a hard crash occurred (apple logo flashed).<br /><br />I tried to force restart which led me to the black screen with exclamation mark. There was no trackpad haptic, power button was unresponsive, MagSafe LED did not work. Since I didn't have a secondary mac for a DFU restore, I simply kept my mac in isolation for a while and didn't touch it. 2 days later I plugged my mac in using Magsafe and the LED lit up. <br /><br />After a full charge, I opened my macbook which showed how it restarted due to a problem. The logs said it was a kernel panic. After digging, i decided to update my OS to the latest version (macOS Tahoe 26.5.2). I thought it would fix every problem. However a few days later, the same thing happened. I opened the lid, spammed Touch ID for it to register, and then it simply hard crashed and I had to wait another 2 days for it to boot up again (same symptoms). This time there was no kernel log reports and my mac thinks absolutely nothing went wrong (I checked console and there was no crash logs or anything)<br /><br />The only thing I found using the command <br />pmset -g log | grep -E &quot;Failure|Sleep|Wake&quot;<br /><br />was:<br />2026-07-15 13:38:56 +0600 Assertions          PID 1914(AddressBookSourceSync) Released PreventUserIdleSystemSleep &quot;Address Book Source Sync&quot; 00:00:30  id:0x0x10000856f [System: No Assertions]</p>
<p>2026-07-15 13:52:11 +0600 Assertions          PID 348(powerd) Created InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd00008591 [System: SRPrevSleep kCPU]</p>
<p>2026-07-15 13:52:11 +0600 Assertions          PID 348(powerd) Released InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd00008591 [System: No Assertions]</p>
<p>2026-07-15 14:37:35 +0600 Assertions          PID 1967(AddressBookSourceSync) Released PreventUserIdleSystemSleep &quot;Address Book Source Sync&quot; 00:00:30  id:0x0x1000085d7 [System: No Assertions]</p>
<p>2026-07-15 14:52:11 +0600 Assertions          PID 348(powerd) Created InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd000085f8 [System: SRPrevSleep kCPU]</p>
<p>2026-07-15 14:52:11 +0600 Assertions          PID 348(powerd) Released InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd000085f8 [System: No Assertions]</p>
<p>2026-07-15 15:37:26 +0600 Assertions          PID 1993(AddressBookSourceSync) Released PreventUserIdleSystemSleep &quot;Address Book Source Sync&quot; 00:00:30  id:0x0x100008645 [System: No Assertions]</p>
<p>2026-07-15 15:52:11 +0600 Assertions          PID 348(powerd) Created InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd00008668 [System: SRPrevSleep kCPU]</p>
<p>2026-07-15 15:52:11 +0600 Assertions          PID 348(powerd) Released InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd00008668 [System: No Assertions]</p>
<p>2026-07-15 16:37:26 +0600 Assertions          PID 2020(AddressBookSourceSync) Released PreventUserIdleSystemSleep &quot;Address Book Source Sync&quot; 00:00:30  id:0x0x1000086bf [System: No Assertions]</p>
<p>2026-07-15 16:52:11 +0600 Assertions          PID 348(powerd) Created InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd000086e0 [System: SRPrevSleep kCPU]</p>
<p>2026-07-15 16:52:11 +0600 Assertions          PID 348(powerd) Released InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd000086e0 [System: No Assertions]</p>
<p>2026-07-15 17:39:26 +0600 Assertions          PID 2074(AddressBookSourceSync) Released PreventUserIdleSystemSleep &quot;Address Book Source Sync&quot; 00:00:30  id:0x0x10000872a [System: No Assertions]</p>
<p>2026-07-15 17:52:11 +0600 Assertions          PID 348(powerd) Created InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd00008753 [System: SRPrevSleep kCPU]</p>
<p>2026-07-15 17:52:11 +0600 Assertions          PID 348(powerd) Released InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd00008753 [System: No Assertions]</p>
<p>2026-07-15 18:38:20 +0600 Assertions          PID 2136(AddressBookSourceSync) Summary PreventUserIdleSystemSleep &quot;Address Book Source Sync&quot; 00:00:24  id:0x0x10000879f [System: PrevIdle]</p>
<p>2026-07-15 18:38:26 +0600 Assertions          PID 2136(AddressBookSourceSync) Released PreventUserIdleSystemSleep &quot;Address Book Source Sync&quot; 00:00:30  id:0x0x10000879f [System: No Assertions]</p>
<p>2026-07-15 18:28:41 +0600 Assertions          PID 359(powerd) Created InternalPreventSleep &quot;com.apple.powermanagement.wakeschedule&quot; 00:00:00  id:0x0xd00008002 [System: PrevIdle SRPrevSleep kCPU]</p>
<p>2026-07-15 18:28:41 +0600 Assertions          PID 359(powerd) Created InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd00008003 [System: PrevIdle SRPrevSleep kCPU]</p>
<p>2026-07-15 18:28:41 +0600 Assertions          PID 359(powerd) Released InternalPreventSleep &quot;Holding in darkwake for up to 20 seconds to query model for inactivity prediction&quot; 00:00:00  id:0x0xd00008003 [System: PrevIdle SRPrevSleep kCPU]</p>
<p>Sleep/Wakes since boot at 2026-07-15 10:06:39 +0600 :0   Dark Wake Count in this sleep cycle:1</p>
<p>2026-07-15 18:28:41 +0600 Assertions          PID 359(powerd) Created UserIsActive &quot;com.apple.powerd.ws.initialize&quot; 00:00:00  id:0x0x900008007 [System: PrevIdle DeclUser SRPrevSleep kCPU kDisp]</p>
<p>2026-07-15 18:28:42 +0600 Assertions          Summary- [System: PrevIdle DeclUser SRPrevSleep kCPU kDisp] Using AC(Charge: 100)</p>
<p>2026-07-15 18:28:44 +0600 Assertions          PID 419(WindowServer) Created UserIsActive &quot;com.apple.iohideventsystem.queue.tickle.nxevent service:IOHIDSystem pid:660 process:Dock&quot; 00:00:00  id:0x0x900008038 [System: PrevIdle DeclUser SRPrevSleep kCPU kDisp]</p>
<p>2026-07-15 18:28:46 +0600 Assertions          PID 359(powerd) TimedOut InternalPreventSleep &quot;com.apple.powermanagement.wakeschedule&quot; 00:00:05  id:0x0xd00008002 [System: PrevIdle DeclUser SRPrevSleep kCPU kDisp]<br /><br />What is wrong with my macbook? Is it a Touch ID issue or some other hardware/ software related problem?</p>
<p>Things to keep in mind:</p>
<p>1. I installed battery toolkit and used it in this month. I never had any issues with battery but decided to use it since my capacity was 85%. Cycle count is at 483. Condition is normal</p>
<p>2. I did not perform a full wipe when updating my OS from 12.1 to 26.5.2</p>
<p>3. After my macbook booted up, there were no other problems and it worked as intended.</p>
<p>4. Apple diagnostics says there is nothing wrong with any of my hardware (including Touch ID and Battery)</p>
<p>Update 1: Did a workaround by disabling lock screen entirely and removing touch ID as they were usually the causes of hard crash. After leaving my mac overnight with lid closed (not shutdown), it was simply dead right off the bat. I digged up some logs using the same command as before:</p>
<p>2026-07-18 10:11:47 +0600 com.apple.sleepservices.sessionTerminated SleepService: window has terminated.</p>
<p>2026-07-18 10:11:47 +0600 Sleep               Entering Sleep state due to 'Sleep Service Back to Sleep':TCPKeepAlive=active Using Batt (Charge:75%)</p>
<p>2026-07-18 10:11:50 +0600 Wake Requests       [*process=dasd request=SleepService deltaSecs=995 wakeAt=2026-07-18 10:28:25 info=&quot;com.apple.dasd:501:com.apple.chronod.nextScheduledTimelineRefresh&quot;] [process=mDNSResponder request=Maintenance deltaSecs=7200 wakeAt=2026-07-18 12:11:50 info=&quot;upkeep wake&quot;] [process=powerd request=TCPKATurnOff deltaSecs=312730 wakeAt=2026-07-22 01:04:00] [process=powerd request=CSPNEvaluation deltaSecs=3125 wakeAt=2026-07-18 11:03:55] [process=powerd request=UserWake deltaSecs=10775 wakeAt=2026-07-18 13:11:26 info=&quot;com.apple.alarm.user-invisible-com.apple.calaccessd.travelEngine.periodicRefreshTimer,617&quot;]</p>
<p>2026-07-18 10:11:50 +0600 PM Client Acks      Delays to Sleep notifications: [com.apple.bluetooth.sleep is slow(1543 ms)] [mDNSResponder is slow(2877 ms)]</p>
<p>Sleep/Wakes since boot at 2026-07-17 20:45:23 +0600 :65   Dark Wake Count in this sleep cycle:4</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 359(powerd) Created InternalPreventSleep &quot;com.apple.powermanagement.darkwakelinger&quot; 00:00:00  id:0x0xd0000817c [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>Sleep/Wakes since boot at 2026-07-18 13:25:14 +0600 :0   Dark Wake Count in this sleep cycle:4</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 359(powerd) Released PreventUserIdleSystemSleep &quot;Powerd - Prevent sleep while display is on&quot; 00:00:26  id:0x0x100008008 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 426(runningboardd) Summary PreventUserIdleSystemSleep &quot;osservice&lt;com.apple.itunescloudd(501)&gt;426-739-303:com.apple.CFNetwork.StorageDB&quot; 00:00:01  id:0x0x100008177 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 359(powerd) Summary UserIsActive &quot;com.apple.powerd.ws.initialize&quot; 00:00:26  id:0x0x900008009 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 418(WindowServer) Summary UserIsActive &quot;com.apple.iohideventsystem.queue.tickle serviceID:100000ab6 service:AppleMultitouchDevice product:Apple Internal Keyboard / Trackpad eventType:11&quot; 00:00:02  id:0x0x900008033 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 556(mds_stores) Summary BackgroundTask &quot;com.apple.metadata.mds_stores.power&quot; 00:00:19  id:0x0xb00008105 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 374(mds) Summary BackgroundTask &quot;com.apple.metadata.mds.power&quot; 00:00:23  id:0x0xb0000803f [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 647(cloudd) Summary SystemIsActive &quot;NSURLSessionTask B5FB9788-3BCE-44C8-9D99-D492F0F20E72&quot; 00:00:03  id:0x0xc00008172 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 647(cloudd) Summary SystemIsActive &quot;NSURLSessionTask A7F6768B-E0B3-4E2B-8783-17F66C8421B0&quot; 00:00:02  id:0x0xc00008173 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 647(cloudd) Summary SystemIsActive &quot;NSURLSessionTask BBF3B16C-FA61-4E7F-8A82-B1CFD051E55D&quot; 00:00:02  id:0x0xc00008175 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 647(cloudd) Summary SystemIsActive &quot;NSURLSessionTask A94CE808-2F83-4140-AE56-1C3AA62BB4A7&quot; 00:00:01  id:0x0xc00008176 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 647(cloudd) Summary SystemIsActive &quot;NSURLSessionTask 0441BFAA-CDB2-4F65-8FC6-9DC89EBAF7A9&quot; 00:00:01  id:0x0xc0000817b [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 359(powerd) Summary InternalPreventSleep &quot;com.apple.powermanagement.darkwakelinger&quot; 00:00:00  id:0x0xd0000817c [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 647(cloudd) Released SystemIsActive &quot;NSURLSessionTask B5FB9788-3BCE-44C8-9D99-D492F0F20E72&quot; 00:00:03  id:0x0xc00008172 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 418(WindowServer) TurnedOn UserIsActive &quot;com.apple.iohideventsystem.queue.tickle serviceID:1000002e0 service:AppleM68Buttons product:(null) eventType:3&quot; 00:00:00  id:0x0x900008033 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:42 +0600 Assertions          PID 359(powerd) Created UserIsActive &quot;com.apple.powermanagement.lidopen&quot; 00:00:00  id:0x0x900008184 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:43 +0600 Assertions          PID 647(cloudd) Released SystemIsActive &quot;NSURLSessionTask A7F6768B-E0B3-4E2B-8783-17F66C8421B0&quot; 00:00:03  id:0x0xc00008173 [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp]</p>
<p>2026-07-18 13:25:43 +0600 Assertions          Summary- [System: PrevIdle DeclUser SysAct SRPrevSleep kCPU kDisp] Using Batt(Charge: 69)</p>
<p>Somehow, my battery went from 75% in sleep state, hard crashed into a dead mode, and then suddenly became 69%</p>
<p>Update 2: Decided to shutdown mac and hopefully boot into diagnostics mode. Turns out mac simply restarted before i could even do anything and it said my mac restarted due to a problem. Logs are below:</p>
<p>panic(cpu 1 caller 0xfffffe003e8b4418): SEP Panic: :sars/sars: 0x100010858 0x000584bc 0x00050434 0x10000f880 0x100002388 0x10000be34 0x10000c568 0x10000d070 0x10000b014 0x100006180 0x00052870 0x10000ef0c 0x100005fe4 0x100008d20 0x100000d74 0x100000bc8 0x1000009f0 [hggghgolo]</p>
<p>Panic app vers: 3151.120.3</p>
<p>Panic app UUID: 68A9CDAF-552F-3BB1-B20A-76DA1F603737</p>
<p>Shared cache vers: 3151.120.3</p>
<p>Shared cache UUID: 3726CD1B-A290-308A-9AD8-69417B8D59B2</p>
<p>Root task tag:  (root@cm8qz.p1l.plx.sd.apple.com)</p>
<p>Root task build time: Jun  1 2026 20:50:54</p>
<p>Root task vers: AppleSEPOS-3151.120.3</p>
<p>Root task UUID: ECFAE211-028E-35A0-B492-D6BB5A16CADF</p>
<p>Diagnostics: 584c0100e934093989bd7c6a86a7da3f703d52f2332e065d39caf3f38874b447f0b42bf2efeb644800000000000000000000000000000000000000000000000000000000a2953b28c10ac912c87cda8ad9b66eb1555b8ea7f3c9501033c7ca6ba6448acd9dd63ca700000000000000000000000000000000000000000000000000000000000005</p>
<p>SEPO/BOOT</p>
<p>SEPO/EXCP 0xa684/0xab04/0x0000000000000013 er/EXCP</p>
<p>SEPD/SEPD 0x4c63c/0x4cdb4/0x1817181718171817 er/SEPD</p>
<p>SEPD/TIME 0x4c63c/0x4cb10/0x1417181314171813 er/TIME</p>
<p>SEPD/XPRT 0x4c63c/0x4cdb4/0x1817181718171817 er/XPRT</p>
<p>SEPD/PMGR 0x4c63c/0x4cdb4/0x1817181718171817 er/PMGR</p>
<p>SEPD/TRNG 0x4c63c/0x4cb10/0x1314101314131413 er/TRNG</p>
<p>SEPD/KEY  0x4c63c/0x4cb10/0x1718171817181013 er/KEY</p>
<p>SEPD/MONI 0x4c63c/0x4cdb4/0x1516171810151617 er/MONI</p>
<p>SEPD/AKF  0x4c63c/0x4cb10/0x1406101314061013 er/AKF</p>
<p>SEPD/EP0D 0x4c63c/0x4cb10/0x1813141314131413 er/EP0D</p>
<p>SEPD/AESH 0x4c63c/0x4cdb4/0x1516171810151617 er/AESH</p>
<p>SEPD/shnd 0x4c63c/0x4cdb4/0x1817181718171817 er/shnd</p>
<p>SEPD/ep0  0x4c63c/0x4cb10/0x1413141314131413 er/ep0</p>
<p>AESS/DAES 0x4c63c/0x4cdb4/0x1817181718171817 er/DAES</p>
<p>AESS/AESS 0x4c63c/0x4cdb4/0x1516171810151617 er/AESS</p>
<p>AESS/PKA  0x4c63c/0x4cdb4/0x1516171810151617 er/PKA</p>
<p>AESS/AEST 0x4c63c/0x4cdb4/0x1516171810151617 er/AEST</p>
<p>dxio/dxio 0x4c63c/0x4d0fc/0x1410131410131410 r/----</p>
<p>enti/enti 0x4c63c/0x4cdb4/0x1817181718171817 er/enti</p>
<p>enti/vers 0x4c63c/0x4cdb4/0x0000000000131417 er/vers</p>
<p>skg /skg  0x4c63c/0x4cdb4/0x1817181718171817 er/skg</p>
<p>skg /skgs 0x4c63c/0x4cdb4/0x1817181718171817 er/skgs</p>
<p>skg /crow 0x4c63c/0x4cb10/0x0000000000000013 er/crow</p>
<p>skg /cro2 0x4c63c/0x4cb10/0x0000000000000013 er/cro2</p>
<p>sars/sars 0x4c63c/0x4c368/0x1112111211121112 ert/BOOT</p>
<p>ARTM/ARTM 0x4c63c/0x4cb10/0x0000000000000013 er/ARTM</p>
<p>xART/xART 0x4c63c/0x4c368/0x1314171817181718 ert/sars</p>
<p>hibe/hibe 0x4c63c/0x4cb10/0x0000000000131413 er/hibe</p>
<p>scrd/scrd 0x4c63c/0x4c368/0x1718171813141314 ec/xART</p>
<p>pass/pass 0x4c63c/0x4cb10/0x1013141013141013 er/pass</p>
<p>sks /sks  0x4c63c/0x4c368/0x1314131413141314 ert/xART</p>
<p>sks /sksa 0x4c63c/0x4cb10/0x0000000013141013 er/sksa</p>
<p>hdcp/hdcp 0x4c63c/0x4cb10/0x1413141314131413 er/hdcp</p>
<p>stac/stac 0x4c63c/0x4cdb4/0x1417181718171817 er/stac</p>
<p>sbio/sbio 0x4c63c/0x4cb10/0x1413141314131413 er/sbio</p>
<p>sbio/blcx 0x4c63c/0x4d2a0/0x0000000000000f11 wn/----</p>
<p>sbio/---- 0x4c63c/0x4d2a0/0x0000000000000f11 wn/----</p>
<p>sse /sse  0x4c63c/0x4cb10/0x1413141314131413 er/sse</p>
<p>boop/boop 0x4c63c/0x4cb10/0x1413141314131413 er/boop</p>
<p>skdl/skdl 0x4c63c/0x4cb10/0x1413141314131413 er/skdl</p>
<p>Firmware type: UNKNOWN SEPOS</p>
<p>SEP state: 8</p>
<p>PM state: 2</p>
<p>Boot state: 32</p>
<p>Mailbox status:</p>
<p>IDLE_STATUS: 0x00000028</p>
<p>INBOX0_CTRL: 0x00026601</p>
<p>OUTBOX0_CTRL: 0x00029901</p>
<p>Mailbox entries:</p>
<p>Unavailable</p>
<p>Mailbox queue pointers: 28/28 -1/-1 -1/-1 -1/-1 -1/-1 -1/-1 -1/-1 -1/-1 23/23 -1/-1 15/15 -1/-1 2/2 -1/-1 11/11 -1/-1 0/0 -1/-1 26/26 9/9 0/0 24/24 -1/-1 5/5 2/2 -1/-1 -1/-1 -1/-1 -1/-1 -1/-1 -1/-1 -1/-1</p>
<p>TZ0 explicitly set 1 size 0x1c08000</p>
<p>TZ1 explicitly set 0 size 0x8000</p>
<p>Debugger message: panic</p>
<p>Memory ID: 0x1</p>
<p>OS release type: User</p>
<p>OS version: 25F84</p>
<p>Kernel version: Darwin Kernel Version 25.5.0: Tue Jun  9 22:18:58 PDT 2026; root:xnu-12377.121.10~1/RELEASE_ARM64_T6000</p>
<p>Fileset Kernelcache UUID: 32F4D28271521AC511D4722B289D8363</p>
<p>Kernel UUID: E977B940-FDD2-35CD-81B3-EC65AAB8BF5C</p>
<p>Boot session UUID: 7B3BB323-7201-44C9-B421-5D407834F08F</p>
<p>iBoot version: mBoot-18000.121.3</p>
<p>iBoot Stage 2 version: mBoot-18000.121.3</p>
<p>secure boot?: YES</p>
<p>roots installed: 0</p>
<p>Paniclog version: 15</p>
<p>Debug Header address: 0xfffffe001bfdd000</p>
<p>Debug Header entry count: 3</p>
<p>TXM load address: 0xfffffe002bf38000</p>
<p>TXM UUID: F0C1A57F-CE44-3DF4-9E86-0CFF02D7C00D</p>
<p>Debug Header kernelcache load address: 0xfffffe003bf38000</p>
<p>Debug Header kernelcache UUID: 32F4D282-7152-1AC5-11D4-722B289D8363</p>
<p>SPTM load address: 0xfffffe001bf38000</p>
<p>SPTM UUID: D249E718-9C0B-36F5-9F6B-24D58BED4606</p>
<p>KernelCache slide: 0x0000000034f34000</p>
<p>KernelCache base:  0xfffffe003bf38000</p>
<p>Kernel slide:      0x0000000034f3c000</p>
<p>Kernel text base:  0xfffffe003bf40000</p>
<p>Kernel text exec slide: 0x0000000039608000</p>
<p>Kernel text exec base:  0xfffffe004060c000</p>
<p>mach_absolute_time: 0x135ef1b987</p>
<p>Epoch Time:        sec       usec</p>
<p>Boot    : 0x6a5b2a3d 0x0007708e</p>
<p>Sleep   : 0x00000000 0x00000000</p>
<p>Wake    : 0x00000000 0x00000000</p>
<p>Calendar: 0x6a5b37c1 0x0009de5d</p>
<p>Zone info:</p>
<p>Zone map: 0xfffffe121a000000 - 0xfffffe381a000000</p>
<p>. VM    : 0xfffffe121a000000 - 0xfffffe17e6000000</p>
<p>. RO    : 0xfffffe17e6000000 - 0xfffffe1a80000000</p>
<p>. GEN0  : 0xfffffe1a80000000 - 0xfffffe204c000000</p>
<p>. GEN1  : 0xfffffe204c000000 - 0xfffffe2618000000</p>
<p>. GEN2  : 0xfffffe2618000000 - 0xfffffe2be4000000</p>
<p>. GEN3  : 0xfffffe2be4000000 - 0xfffffe31b0000000</p>
<p>. DATA  : 0xfffffe31b0000000 - 0xfffffe381a000000</p>
<p>Metadata: 0xfffffe1008010000 - 0xfffffe1011810000</p>
<p>Bitmaps : 0xfffffe1011810000 - 0xfffffe1014520000</p>
<p>Extra   : 0 - 0</p>
<p>TPIDRx_ELy = {1: 0xfffffe2be6b2aba0  0: 0x0001000000000001  0ro: 0x0000000000000000 }</p>
<p>CORE 0: PC=0xfffffe00406a51b8, LR=0xfffffe00406a51b8, FP=0xfffffe950f00bee0</p>
<p>CORE 1 is the one that panicked. Check the full backtrace for details.</p>
<p>CORE 2: PC=0xfffffe00406a51b8, LR=0xfffffe00406a51b8, FP=0xfffffe950f0ebee0</p>
<p>CORE 3: PC=0xfffffe00406a51b8, LR=0xfffffe00406a51b8, FP=0xfffffe950ecebee0</p>
<p>CORE 4: PC=0xfffffe00406a51b8, LR=0xfffffe00406a51b8, FP=0xfffffe950f5bbee0</p>
<p>CORE 5: PC=0xfffffe00406a51b8, LR=0xfffffe00406a51b8, FP=0xfffffe950f56bee0</p>
<p>CORE 6: PC=0xfffffe00406a51b8, LR=0xfffffe00406a51b8, FP=0xfffffe950e91bee0</p>
<p>CORE 7: PC=0xfffffe00406a51b8, LR=0xfffffe00406a51b8, FP=0xfffffe950e9bbee0</p>
<p>CORE 8: PC=0xfffffe00406a51b8, LR=0xfffffe00406a51b8, FP=0xfffffe950ebbbee0</p>
<p>CORE 9: PC=0xfffffe00406a51b8, LR=0xfffffe00406a51b8, FP=0xfffffe950eafbee0</p>
<p>Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space</p>
<p>Panicked task 0xfffffe2517f8eb58: 0 pages, 595 threads: pid 0: kernel_task</p>
<p>Panicked thread: 0xfffffe2be6b2aba0, backtrace: 0xfffffe950edeb610, tid: 2176</p>
<p>lr: 0xfffffe004066457c  fp: 0xfffffe950edeb6b0</p>
<p>lr: 0xfffffe00407e84ec  fp: 0xfffffe950edeb720</p>
<p>lr: 0xfffffe00407e6464  fp: 0xfffffe950edeb7e0</p>
<p>lr: 0xfffffe0040611c40  fp: 0xfffffe950edeb7f0</p>
<p>lr: 0xfffffe0040664888  fp: 0xfffffe950edebd10</p>
<p>lr: 0xfffffe0040f68a78  fp: 0xfffffe950edebd30</p>
<p>lr: 0xfffffe003e8b4418  fp: 0xfffffe950edebd60</p>
<p>lr: 0xfffffe003e896af0  fp: 0xfffffe950edebd80</p>
<p>Note that I never even touched the Touch ID this time. I simply shut it down and before I even got the chance to do anything, it started right back up.</p>
<p>⟐ Answered August 16, 2026 at 6:36 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/964244/Why+does+my+MacBook+hard+crash+after+opening+lid</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/964244</guid>
<pubDate>Sun, 16 Aug 2026 06:36:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 16" 2019: Touch ID does not work after battery replacement]]></title>
<description><![CDATA[<p>A few days ago I have replaced the battery in my Macbook following the guide on ifixit, which involved taking out the logic board.</p>
<p>Anyway, I assembled everything according to the guide and everything works well, the battery is also great. However, I have just noticed, that even though the power button works, the touch id does not:</p>
<p>Whenever I log into the account after starting the mac, I enter the password, and after some time whenever it goes to sleep I cannot open it with touch id. Additionally, touch ID stopped working with saved passwords in Safari.</p>
<p>Also, whenever I try to add a new fingerprint, I get following error, right after I click add fingerprint and enter the password:</p>
<blockquote class="featured"><p>Failed</p>
<p>Unable to complete Touch ID enrollment.</p></blockquote>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/j6APaoaVXAP3ZJxh.standard" width="282" height="164" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/j6APaoaVXAP3ZJxh.full&quot;, '', 'width=1378,height=802')" /></div>
<p>So it does not even allow to put a finger on it. Anyone knows how I can solve this issue? Because power button works.</p>
<p>What I did so far:</p>
<ul><li>Tried to reset NVRAM and SMC</li><li>Tried to add new fingerprint in Safe Mode</li><li>Visually inspected if the ribbon for touch id and power button is damaged (it is not)</li><li>Tried creating a new user and adding a fingerprint</li><li>Tried running Apple Diagnostics (Control+D on startup) - no hardware failures.</li></ul>
<p>Anyone encountered it and knows about any possible solutions I can try?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_01_03_Num_24" class="header">Update (01/03/24)</h3></div>
<p>Finally found some time to disassemble it, I reconnected everything, as you can see in the images (even though low quality but hopefully good enough), the touch ID does not work and touch id enrolment fails :(</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/46PdXXTqUexqC6Kj.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/46PdXXTqUexqC6Kj.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/yIWaAN55mgQXCiJb.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/yIWaAN55mgQXCiJb.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/rF4bn6u5G3leeAFP.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/rF4bn6u5G3leeAFP.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/xgTUmrR6HwGjEBEf.standard" width="169" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/xgTUmrR6HwGjEBEf.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Answered August 16, 2026 at 4:28 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/829880/Touch+ID+does+not+work+after+battery+replacement</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/829880</guid>
<pubDate>Sun, 16 Aug 2026 04:28:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 16" 2019: MacBook Pro A2141 black screen and unresponsive keyboard/trackpad after upgrade]]></title>
<description><![CDATA[<p>My MacBook Pro 16&quot; 2019 (Model A2141) experienced a black screen with backlight only, along with completely unresponsive internal keyboard and trackpad, immediately following a software/firmware upgrade. The device is lightly used with zero liquid damage.</p>
<p>Current status/troubleshooting performed:</p>
<p>- Draws 20V and ~3.45A on USB-C (power delivery is negotiating normally).</p>
<p>- External monitor / peripherals show no output.</p>
<p>- Performed DFU mode revive and restore using Apple Configurator 2, but it did not resolve the issue.</p>
<p>- Internal connections and cables checked; no physical or liquid damage found.</p>
<p>Since standard DFU restore and basic troubleshooting haven't fixed a post-upgrade failure like this, what component level or firmware issue (such as T2 ROM corruption or specific power rails) could cause this behavior?</p>
<p>⟐ Commented August 15, 2026 at 21:01 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/968228/MacBook+Pro+A2141+black+screen+and+unresponsive+keyboard-trackpad+after+upgrade</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/968228</guid>
<pubDate>Sat, 15 Aug 2026 21:01:49 -0700</pubDate>
</item>
</channel>
</rss>
