<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Ice Cream Machine&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Ice_Cream_Machine?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Ice Cream Machine&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 16 Aug 2026 06:05:19 -0700</pubDate>
<item>
<title><![CDATA[Taylor Model C602: My machine is on heat mode how do I stop it or how long is the heat pr]]></title>
<description><![CDATA[<p>My machine is on heat mode and how long is the process or how do I stop it</p>
<p>⟐ Commented June 11, 2025 at 20:06 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/879226/My+machine+is+on+heat+mode+how+do+I+stop+it+or+how+long+is+the+heat+pr</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/879226</guid>
<pubDate>Wed, 11 Jun 2025 20:06:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Creami: Need help identifying burnt components on Ninja Creami NC50X-PW board]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/r4DCGy6yMCUUYNT3.standard" width="225" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/r4DCGy6yMCUUYNT3.huge&quot;, '', 'width=1200,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/VxDfpXrDZurqvLF2.standard" width="225" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/VxDfpXrDZurqvLF2.huge&quot;, '', 'width=1200,height=1200')" /></div>
<p>Hello,</p>
<p>I’m repairing a Ninja Creami device (model NC50X-PW, revision V2.0) that was mistakenly connected to a 220V power source instead of 110V. Several components on the main PCB were damaged — one IC labeled U300 has a cracked case, and another labeled IC3 (likely a voltage regulator) is completely destroyed.</p>
<p>Unfortunately, I don’t have a schematic or BOM for this board. I’ve attached detailed photos of the board and the affected areas. If anyone has worked on this model or can help identify these components, I’d be very grateful.</p>
<p>Thank you in advance!</p>
<p>⟐ Answered March 28, 2026 at 21:52 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/912064/Need+help+identifying+burnt+components+on+Ninja+Creami+NC50X-PW+board</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/912064</guid>
<pubDate>Sat, 28 Mar 2026 21:52:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Creami: How to remagnatize the shaft Pin]]></title>
<description><![CDATA[<p>How do I remagnatize the shaft</p>
<p>⟐ Answered November 15, 2025 at 18:27 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/926333/How+to+remagnatize+the+shaft+Pin</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/926333</guid>
<pubDate>Sat, 15 Nov 2025 18:27:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Taylor C709: I have taylor C709 and it s making loud noise while running]]></title>
<description><![CDATA[<p>Hello,</p>
<p>my tayloe c709 is making loud noise while running and leaking only when its running in standby mode.</p>
<p>your suggestions will be appreciated.</p>
<p>⟐ Commented September 04, 2024 at 9:14 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/853014/I+have+taylor+C709+and+it+s+making+loud+noise+while+running</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/853014</guid>
<pubDate>Wed, 04 Sep 2024 09:14:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Creami: looking to identify a part on the motherboard for creami repair]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/kKbhPxZor312PlHY.standard" width="282" height="211" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/kKbhPxZor312PlHY.full&quot;, '', 'width=1280,height=960')" /></div>
<p>Hi everyone,</p>
<p>I'm trying to identify a blown optocoupler labeled <strong>T107</strong> on the motherboard of a <strong>Ninja Creami NC300XX</strong>. Unfortunately, the part is completely unreadable due to damage (see image below), and I can't find a schematic or detailed board view online.</p>
<p>Here's a close-up photo of the board:<br /></p>
<ul><li>The optocoupler is marked <strong>T107</strong> on the silkscreen.</li><li>It's located near components labeled <strong>T106</strong>, <strong>JP15</strong>, <strong>R1A/B</strong>, and <strong>T108</strong>.</li><li>There appears to be corrosion and possibly other heat damage nearby as well.</li><li>The unit stopped powering on after a surge, so I'm suspecting this component might be part of the power regulation or feedback loop.</li></ul>
<p>If anyone has a working NC300XX and can check the part number, or if you recognize this board layout from similar devices, I’d really appreciate the help. Thanks</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_04_14_Num_25" class="header">Update (04/14/25)</h3></div>
<p>⟐ Edited by author April 14, 2025 at 4:52 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/895964/looking+to+identify+a+part+on+the+motherboard+for+creami+repair</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/895964</guid>
<pubDate>Mon, 14 Apr 2025 04:52:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Taylor Model C602: Why is ice cream not freezing]]></title>
<description><![CDATA[<p>Soft serve side is not producing ice cream?</p>
<p>⟐ Answered December 30, 2025 at 22:55 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/932989/Why+is+ice+cream+not+freezing</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/932989</guid>
<pubDate>Tue, 30 Dec 2025 22:55:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Creami: Does anybody have the measurements of shafts used in NC501?]]></title>
<description><![CDATA[<p>I need the measurements of the shaft to look for possible replacement. It would be also nice if anybody has already found replacement for this shaft!</p>
<p>Thanks for any replies!</p>]]></description>
<link>https://www.ifixit.com/Answers/View/912730/Does+anybody+have+the+measurements+of+shafts+used+in+NC501</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/912730</guid>
<pubDate>Mon, 18 Aug 2025 14:00:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ice Cream Machine: repair and spare parts for Solis Gelateria Pro 850]]></title>
<description><![CDATA[<p>Can the bearings or motor of Solis Gelateria Pro 850 be repaired? Where can I buy the parts? Is there a technical manual for repair?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_07_14_Num_25" class="header">Update (07/14/25)</h3></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/rTbOY2uiUbfnd52X.standard" width="259" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/rTbOY2uiUbfnd52X.full&quot;, '', 'width=1005,height=874')" /></div>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_07_14_Num_25_1" class="header">Update (07/14/25)</h3></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ipWdxtOfqBm6vecJ.standard" width="282" height="209" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ipWdxtOfqBm6vecJ.full&quot;, '', 'width=1198,height=889')" /></div>
<p>⟐ Edited July 14, 2025 at 7:30 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/907377/repair+and+spare+parts+for+Solis+Gelateria+Pro+850</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/907377</guid>
<pubDate>Mon, 14 Jul 2025 07:30:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ice Cream Machine: Mengapa mesin es krim tdk mau dingin]]></title>
<description><![CDATA[<p>Mesin es krim tdk dingin</p>
<p>⟐ Commented August 17, 2024 at 0:35 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/865083/Mengapa+mesin+es+krim+tdk+mau+dingin</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/865083</guid>
<pubDate>Sat, 17 Aug 2024 00:35:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ice Cream Machine: SaniServ won't freeze ice cream completely]]></title>
<description><![CDATA[<p>Does refrigerant escape from machine overtime?  Does anyone know how to replace it?  Model A4611E  Anyone in Maine, NH or MA repair?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/849476/SaniServ+won&#039;t+freeze+ice+cream+completely</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/849476</guid>
<pubDate>Tue, 14 May 2024 08:18:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[Taylor Model C602: Out of Service Machines for purchase?]]></title>
<description><![CDATA[<p>Does anyone know where I can find an out of service one of these for purchase so I can perform an in depth review and analysis of it's functionality? I got the manual, now I want a cheap broken one to expose!</p>]]></description>
<link>https://www.ifixit.com/Answers/View/826142/Out+of+Service+Machines+for+purchase</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/826142</guid>
<pubDate>Tue, 28 Nov 2023 21:05:30 -0700</pubDate>
</item>
</channel>
</rss>
