<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Honda Lawn Mower&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Honda_Lawn_Mower?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Honda Lawn Mower&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 17 Aug 2026 06:11:07 -0700</pubDate>
<item>
<title><![CDATA[Honda Lawn Mower: My lawn mower won’t start on first pull and runs rough]]></title>
<description><![CDATA[<p>i have a Honda Lawn Mower Hrr2169VKA. i had issues with it running so i decided to replace the Carburator, gas hoses, fuel shut off, the governor springs rods return linkage, fuel filter, all the gaskets on the card, spark plug, new gas 93 octane and 10-30 oil. it still runs rough and doesn’t like to start without carb cleaner in card to kick it on.</p>
<p>⟐ Commented August 07, 2023 at 9:44 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/804909/My+lawn+mower+won%E2%80%99t+start+on+first+pull+and+runs+rough</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/804909</guid>
<pubDate>Mon, 07 Aug 2023 09:44:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: HR214 SX 1985 No change in the idling speed from HI to LO position.]]></title>
<description><![CDATA[<p>Hi<br /><br />I had to change the carburetor because the mower would only work on choke and would die on HI or LO positions. I didn't change anything else. When I pull the lever out of choke down to the Hi position the choke plate opens fully (as per the swivel on the carb) the rpm is pretty much the same but when I put it on the LO position there is no change in engine speed. The motor is GVX120 4.4HP 1 cylinder.<br /><br />The governor arm is free to move but doesn't not move the idle plate back and forth while idling. There are no restrictions either on the idle arm where the 2 governor rods attach on the carb.<br /><br />Any Idea?<br /><br />Thanks</p>
<p>⟐ Commented October 14, 2022 at 21:25 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/751413/HR214+SX+1985+No+change+in+the+idling+speed+from+HI+to+LO+position.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/751413</guid>
<pubDate>Fri, 14 Oct 2022 21:25:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: Honda HRC216k1SXA trans mission quit working any ideas]]></title>
<description><![CDATA[<p>I was mowing with it and shut off to empty grass catcher. When I restarted it there was no self propelled any ideas on what my problem is?</p>
<p>⟐ Answered June 19, 2019 at 8:18 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/573812/Honda+HRC216k1SXA+trans+mission+quit+working+any+ideas</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/573812</guid>
<pubDate>Wed, 19 Jun 2019 08:18:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: I have never changed the oil and cnd not find the oll plg om a Honda e]]></title>
<description><![CDATA[<p>I have a Honda easy start 6cv 150 mower and I can;t find the drain plug.  I have never change one before</p>
<p>⟐ Answer accepted March 23, 2018 at 13:45 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/471490/I+have+never+changed+the+oil+and+cnd+not+find+the+oll+plg+om+a+Honda+e</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/471490</guid>
<pubDate>Fri, 23 Mar 2018 13:45:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawnmower HRN216VKA: How do you replace the transmission belt?]]></title>
<description><![CDATA[<p>The transmission belt is worn and I need to replace the belt. Do I have to remove any parts to replace the belt?</p>
<p>⟐ Comment deleted September 02, 2020 at 6:20 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/654014/How+do+you+replace+the+transmission+belt</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/654014</guid>
<pubDate>Wed, 02 Sep 2020 06:20:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda lawn mower: Engine Sluggish until blades engaged]]></title>
<description><![CDATA[<p>The engine runs sluggish until I engage the blade then it runs fine ,  once i disengage the blade it runs poorly again</p>
<p>⟐ Answered May 23, 2020 at 15:16 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/327746/Engine+Sluggish+until+blades+engaged</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/327746</guid>
<pubDate>Sat, 23 May 2020 15:16:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: What is the difference between models?]]></title>
<description><![CDATA[<p>I'm in the market for self-propel walk-behind lawn mowers, and see that Honda models HRX217VKA and HRX217K5VKA are both rated highly.  Some vendors appear to sell one model but not the other, and the list price for the latter is ~$80 more .  What's the difference between the two models?</p>
<p>⟐ Answer accepted May 14, 2018 at 6:52 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/485402/What+is+the+difference+between+models</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/485402</guid>
<pubDate>Mon, 14 May 2018 06:52:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: How to determine why I'm not getting a spark]]></title>
<description><![CDATA[<p>There is no spark on my Honda lawnmower motor.  I replaced the coil, sanded the magnets on flywheel, and disconnected the kill switch wire.  Any suggestions?</p>
<p>⟐ Answered March 14, 2018 at 12:30 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/469318/How+to+determine+why+I&#039;m+not+getting+a+spark</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/469318</guid>
<pubDate>Wed, 14 Mar 2018 12:30:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: How to replace piston rings]]></title>
<description><![CDATA[<p>How do I replace my piston rings</p>
<p>⟐ Answer accepted November 27, 2017 at 5:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/411847/How+to+replace+piston+rings</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/411847</guid>
<pubDate>Mon, 27 Nov 2017 05:51:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawnmower HRR216K9: Why my lawnmower is having black smoke]]></title>
<description><![CDATA[<p>Why My lawn mower is having black after cleaning oil filter tip it to reduce the oil</p>]]></description>
<link>https://www.ifixit.com/Answers/View/951924/Why+my+lawnmower+is+having+black+smoke</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/951924</guid>
<pubDate>Sat, 25 Apr 2026 02:09:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower HRS216K5 PKAA: 2 stroke added to oil on mower help]]></title>
<description><![CDATA[<p>Briggs and Stratton 675exi engine on a masport 800 series</p>
<p>Not mower above in title as they didn't offer masports.</p>
<p>We've had a team put 2 stroke oil in the oil hole on the mower above.</p>
<p>They've used it all week and now it's stopped starting and they have finally told me about it..</p>
<p>Never had the problem before and I have checked for compression and no damage in terms of cracks or splits in the mower engine block</p>
<p>Tried new spark and the spark is there, obviously completed emptied and refilled the mower with genuine oil.</p>
<p>Any other ideas would be amazing.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/861781/2+stroke+added+to+oil+on+mower+help</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/861781</guid>
<pubDate>Mon, 29 Jul 2024 08:18:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: Do I need a new air filter?]]></title>
<description><![CDATA[<p>Do i need a new air filter? Images in the link since it kept crashing when i uploaded the pics to ifixit.</p>
<p>Also, my wheel broke off ( the bolt did). Does this happen a lot? <br /></p>
<p>Also (again) the rear wheel seems to get stuck while backing up. How do i fix it for cheap? (havent tried with 2 real wheels yet as my bolt is still shipping.</p>
<p><a href="https://photos.app.goo.gl/T9DuM9PTuDF7H6vR6" rel="nofollow noopener noreferrer" title="https://photos.app.goo.gl/T9DuM9PTuDF7H6vR6">https://photos.app.goo.gl/T9DuM9PTuDF7H6...</a></p>
<p>also i do have a new dust cover plastic part, found it on a scrap mower. This mower that has a missing wheel was free to take.</p>
<p>⟐ Commented August 19, 2020 at 7:48 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/651623/Do+I+need+a+new+air+filter</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/651623</guid>
<pubDate>Wed, 19 Aug 2020 07:48:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: Hi people? My law star if I keep my fingers the hole of the c]]></title>
<description><![CDATA[<p>Hi please help my lawnmower don’t star in order to star i use star fuel but don’t keep running by itself ,i have to  pit my finger on the hole of the carburetor, how i make to star and keep it going thank very much for help</p>
<p>⟐ Commented March 23, 2020 at 12:37 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/623638/Hi+people+My+law+star+if+I+keep+my+fingers+the+hole+of+the+c</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/623638</guid>
<pubDate>Mon, 23 Mar 2020 12:37:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: Why does my mower sound like a hot rod and blowing smoke?]]></title>
<description><![CDATA[<p>When starting my mower up it sounds like a hot rod engine and it’ll start blowing smoke. It’s not cutting grass either. Could it be that the engine is about to blow?</p>
<p>⟐ Commented May 22, 2019 at 7:56 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/568873/Why+does+my+mower+sound+like+a+hot+rod+and+blowing+smoke</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/568873</guid>
<pubDate>Wed, 22 May 2019 07:56:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: How to hook up cutting blade brake cable .how it looks up at the handl]]></title>
<description><![CDATA[<p>How to hook up cutting blade brake cable to the handle bars</p>
<p>⟐ Commented March 25, 2019 at 16:40 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/557443/How+to+hook+up+cutting+blade+brake+cable+.how+it+looks+up+at+the+handl</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/557443</guid>
<pubDate>Mon, 25 Mar 2019 16:40:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: Poor idle on Honda mower model HRR2168VKA]]></title>
<description><![CDATA[<p>I recently decided to sharpen the blade on my mower. I shut off the fuel valve before tipping to its side, only later to find oil would poor out of the air cleaner causing a failure to start. I began to clean off the oil by removing saturated air filter. After initial cleaning, it wouldn’t start. At this point, I decided to further clean the spark plug. Second attempt to start momentarily with a lot off smoke.  I figured further cleaning was need so, removed carburetor to clean out the float valve, main nozzle and float in carburetor.  After carburetor cleaning and filling up to proper level of oil, it had a rough start but, but, got it to idle after several attempts. The Idle is rough and  goes up and down non-stop. I checked for air leaks but, couldn’t find any. I don’t see any adjustments for carburetor control. Anyone have any ideas what can be causing poor idle?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/552122/Poor+idle+on+Honda+mower+model+HRR2168VKA</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/552122</guid>
<pubDate>Thu, 28 Feb 2019 09:47:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: Craftsman 37299 21" 132cc Push Mower won't start.]]></title>
<description><![CDATA[<p>Craftsman 37299 21&quot; 132cc Push Mower won’t start.  I’ve only mowed the lawn 3 times.  I would guess it had some stale gas in it    I’ve drained the gas, changed oil, changed spark plug.  No luck.  Added seafoam to gas.  Sprayed starter fluid in carb.  No luck.  Will start for a few seconds then dies.  Gas drains out of the carb ok, so fuel is flowing.  Fuel filter looks ok.  Any ideas?</p>
<p>⟐ Reopened January 04, 2019 at 12:46 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/537728/Craftsman+37299+21%22+132cc+Push+Mower+won&#039;t+start.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/537728</guid>
<pubDate>Fri, 04 Jan 2019 12:46:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: Recoil Starter Assembly substitute]]></title>
<description><![CDATA[<p>They want more the stater assembly than I gave for the mower. Will a different Honda starter assembly work?</p>
<p>⟐ Edited April 12, 2017 at 14:55 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/243447/Recoil+Starter+Assembly+substitute</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/243447</guid>
<pubDate>Wed, 12 Apr 2017 14:55:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda Lawn Mower: pull rope resistance with clutch assembly on]]></title>
<description><![CDATA[<p>With clutch assembly mower starts fine. With clutch assembly on the pull rope has resistance and won't turn ovet.</p>
<p>⟐ Edited April 12, 2017 at 14:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/238922/pull+rope+resistance+with+clutch+assembly+on</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/238922</guid>
<pubDate>Wed, 12 Apr 2017 14:51:22 -0700</pubDate>
</item>
</channel>
</rss>
