<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Frigidaire Combo Washer Dryer&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Frigidaire_Combo_Washer_Dryer?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Frigidaire Combo Washer Dryer&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 19 Aug 2026 00:34:57 -0700</pubDate>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Electrolux/Frigidaire combo beeps 3 times randomly constantly]]></title>
<description><![CDATA[<p>Just curious if anyone would know why my Frigidaire stackable Washer/Dryer model FFLE3911Qw0</p>
<p>Beeps 3 times randomly and it does it all the time. everything seems to work just fine</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/wqxOsdOLCtfeEiYq.standard" width="174" height="225" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/wqxOsdOLCtfeEiYq.huge&quot;, '', 'width=926,height=1200')" /></div>
<p>⟐ Commented June 15, 2026 at 19:34 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/660328/Electrolux-Frigidaire+combo+beeps+3+times+randomly+constantly</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/660328</guid>
<pubDate>Mon, 15 Jun 2026 19:34:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: frigidaire works ok, bout only fills with cold water]]></title>
<description><![CDATA[<p>model number ffle1011mw2 frigidaire stackable washer and dryer. All settings work ok; fills with water after selecting either hot or cold, but water in tub is always cold. All cycles run to completion. Checked water hoses: not kinked, hot water getting to washer ok.</p>
<p>⟐ Edited January 27, 2026 at 12:57 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/176109/frigidaire+works+ok,+bout+only+fills+with+cold+water</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/176109</guid>
<pubDate>Tue, 27 Jan 2026 12:57:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Frigidair combo dryer starts and stops after a few seconds.]]></title>
<description><![CDATA[<p>Model FLCE7522AW frigidair combo dryer starts and stops after a few seconds without any sounds or beeps. What can it be? Washer works perfectly fine.</p>
<p>⟐ Commented March 01, 2026 at 23:23 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/823529/Frigidair+combo+dryer+starts+and+stops+after+a+few+seconds.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/823529</guid>
<pubDate>Sun, 01 Mar 2026 23:23:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: frigidaire FLCE752CAW works ok, bout only fills with cold water]]></title>
<description><![CDATA[<p>Just noticed my Frigidaire Laundry Center Model FLCE752CAW had cold water in the tub after I had selected a hot water wash in the Normal cycle. I put it into Diagnostic Mode (how-to instructions are in the user manual) and confirmed hot water was dispensing in the Hot Water Fill test selection. Back in regular mode I selected a hot water fill (Normal Cycle) and monitored it. It starts the fill with cold water for about 75% of the time, stops, and then delivers hot water for about 25% of the time. How can you get a hot water fill/wash from that? Especially in Vancouver BC where the City delivered water temperature here is 6-10 degrees Celsius for 8 months of the year. Electrolux, the manufacturer of these, sent a local repair technician. He spoke to an Electrolux service dept Technician and their response was that the water temperature is too cold in the locale. With programming like this these units should not be sold into moderate climate regions, only hot one's. Unit does not monitor the water temp inlet.</p>
<link>https://www.ifixit.com/Answers/View/842980/frigidaire+FLCE752CAW+works+ok,+bout+only+fills+with+cold+water</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/842980</guid>
<pubDate>Tue, 27 Jan 2026 12:57:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Drain pump receiving strange voltage in 2 of same model frigidaire]]></title>
<description><![CDATA[<p>I am working on a problem on 2 Frigidaire <strong>GLET1031FS4 's</strong> at a condo complex (they have many more of this same model working fine)</p>
<p>These are oldschool washer+dryer combo towers that function on timers and possess no circuitboards.</p>
<p>Both machines are working perfectly apart from that <strong>the drain pumps are receiving strange voltage in all cycles</strong>. I have connected both pumps directly to 120v power and both are fine.</p>
<p>One machine I have tested more extensively than the other, here are the results;</p>
<ul><li>when the drain pump is not engaged in a drain cycle (either the timer is not pulled out, or it is a part of the cycle that does not use the drain pump) the hot line to drain pump is receiving 120v, and the neutral line is receiving some 50v</li><li>when the washer timer is pulled out and the washer is attempting to engage the drain pump, depending on the cycle, the hot line is receiving 0v and the neutral line jumps up to some 70v</li></ul>
<p>I have a spare timer on hand at the complex which I have swapped out for the original, but got exactly the same results.</p>
<p>On the second machine I got similar readings, with voltage coming through the neutral line, and voltage coming through the hot line when it should not be (e.g. when the washer timer is not engaged at all), with the only difference being that the hot line is not actually ever receiving 120v, and the readings on the neutral were somewhat different numbers than the first.</p>
<p>One theory is that there is some kind of partial short somewhere in the wires.</p>
<p>But that seems to random of an issue to have found on <strong>both</strong> of 2 different machines?</p>
<p>Any additional ideas appreciated, I have not yet had the time to completely dismantle and rebuild the washer so as to fully inspect the length of the wires. A full day job.</p>
<p>⟐ Edited January 27, 2026 at 13:01 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/886020/Drain+pump+receiving+strange+voltage+in+2+of+same+model+frigidaire</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/886020</guid>
<pubDate>Tue, 27 Jan 2026 13:01:25 -0700</pubDate>
</item>
<item>
<description><![CDATA[<p>Mine does the same thing.  Is there a picture or diagram of where to find the thermostat and fuses?  Model FLCE7522AW3</p>
<link>https://www.ifixit.com/Answers/View/883672/Frigidair+combo+dryer+starts+and+stops+after+a+few+seconds.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/883672</guid>
<pubDate>Tue, 27 Jan 2026 13:01:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Dryer begins to spin but slowly stops]]></title>
<description><![CDATA[<p>Frigidaire EGZ831AS1</p>
<p>Drying just started acting up.</p>
<p>Drying currently empty, Start attempt. Will turn approximately 1/4 rotation, Can hear motor trying but stops. <br /></p>
<p>Try again, Unit maybe turns 1/8 to same result. Then eventually will not turn at all but I can hear motor trying.</p>
<p>Tub (sorry for not exact terminology) has some give it in it currently on the front. Feel like it might be off balance. Not sure how I would take apart to check as I cannot find a manual for this old girl.</p>
<p>After about 10 minutes I can try again and it starts the same scenario (only reason I did this is I needed to prove to the misses that I wasn’t being lazy it actually didn’t work :-D) Don’t want to burn out motor (anymore then it potentially is) Let me know what you guys think.</p>
<p>Thanks</p>
<p>Jared</p>
<p>⟐ Edited January 27, 2026 at 15:06 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/660116/Dryer+begins+to+spin+but+slowly+stops</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/660116</guid>
<pubDate>Tue, 27 Jan 2026 15:06:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Dryer rumbling shakes violently after a few minutes.]]></title>
<description><![CDATA[<p>Frigidaire model flsg72gcs9.</p>
<p>The dryer would not start so I took the front panel off and saw that the drum glide felts were damaged and coming loose. I replaced the top and bottom felts. I stretched the bottom felt too much when installing and snipped off about a 1/4” extra. After reinstalling, the dry went for about 15 minutes before a low rumbling could be heard which got louder as it went on.</p>
<p>I took the machine apart and noticed the pulley wheel had a crack so I ordered a new one along with a new belt. Replaced them and got the same result. (the belt leaves shaving or rubber dust underneath the pulley)</p>
<p>I ordered a new drum bearing even though the old one looked good and replaced it. Same result.</p>
<p>At this point the motor would not turn without assistance so I thought it was bad bearings and installed a new motor (and blower housing it comes with). Same rumbling, maybe even worse.</p>
<p>I noticed when I pushed on the back of the dryer the rumbling would stop and noticed on one of the corners it was missing a screw. I had to drill through the hole to get to where it secures the intake to the back round plate. Still continued to rumble.</p>
<p>The rumbling did not start until after I installed the new felts. They have had to be replaced a few times over the years. The left side of the felt has rubbing marks because the drum leans to one side creating a gap on one side and rubbing against the other. But I think it has always done this. I have leveled the dryer but the drum still leans that way.</p>
<p>Whenever I reinstall the drum it runs fine for 15 min to 45 min</p>
<p>The only thing I have not replaced is the blower fan but the dryer runs fine with the belt off and starts rumbling as soon as I put the belt back on.</p>
<p>Any ideas?</p>
<p>Link to noise</p>
<p><a href="https://www.youtube.com/watch?v=UBEpPDqODpE" title="https://www.youtube.com/watch?v=UBEpPDqODpE">https://www.youtube.com/watch?v=UBEpPDqO...</a></p>
<p>⟐ Edited January 27, 2026 at 15:07 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/652021/Dryer+rumbling+shakes+violently+after+a+few+minutes.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/652021</guid>
<pubDate>Tue, 27 Jan 2026 15:07:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Frigidaire combo beeps 3 long time during washing cycle then stop.]]></title>
<description><![CDATA[<p>The problem was intermitent at the begining but is now permanent. The unit is filling water washing and stop during its cycle randomly with three (3) long beeps. unit stay full of water. After few power resets or Start/stop, the unit finish its cycle.</p>
<link>https://www.ifixit.com/Answers/View/781064/Frigidaire+combo+beeps+3+long+time+during+washing+cycle+then+stop.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/781064</guid>
<pubDate>Tue, 27 Jan 2026 15:07:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Washer beeps 3 times before the rinse cycle.]]></title>
<description><![CDATA[<p>Washer beeps 3 times before rinse cycle. When I push the control button the washer starts and finishes the cycle….?</p>
<p>Frigidaire model #FFLE39CIQW0</p>
<p>⟐ Edited January 27, 2026 at 15:08 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/798009/Washer+beeps+3+times+before+the+rinse+cycle.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/798009</guid>
<pubDate>Tue, 27 Jan 2026 15:08:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Wont drain all water from spin cycle]]></title>
<description><![CDATA[<p>My Frigidaire washer dryer stack unit will not drain all the water from the spin cycle? What could this be to fix it</p>
<p>⟐ Edited January 27, 2026 at 15:09 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/773706/Wont+drain+all+water+from+spin+cycle</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/773706</guid>
<pubDate>Tue, 27 Jan 2026 15:09:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: My Frigidaire stackable dryer will not stay running]]></title>
<description><![CDATA[<p>Frigidaire model # FFLE4033QT the dryer starts, but only runs for about 5 seconds, then stops and beeps 3 fast beeps or short beeps. Then it stops all together. Ideas pls.</p>
<p>⟐ Edited January 27, 2026 at 15:10 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/764898/My+Frigidaire+stackable+dryer+will+not+stay+running</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/764898</guid>
<pubDate>Tue, 27 Jan 2026 15:10:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: The dryer will not stay on.]]></title>
<description><![CDATA[<p>I have a fridgidair dryer model # FFLE4033QT, and the dryer tries to start it actually does for about 5 seconds then stops and beeps, 3 long beeps. Has anybody run across this problem. This unit is new, but has been in storage for years.</p>
<link>https://www.ifixit.com/Answers/View/764893/The+dryer+will+not+stay+on.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/764893</guid>
<pubDate>Tue, 27 Jan 2026 15:10:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Why is the dryer making a horrible noise]]></title>
<description><![CDATA[<p>I have a frigidaire combo washer dryer, that is a few years old but hasn't been used a lot.  The dryer developed a really bad sound metal on metal type scraping. When I looked inside the dryer I noticed there were two screws (out of 3) that had worked their way out of the center back (inside the dryer). Not sure if those screws were the cause of the noise or the result of it.   I haven't tried doing towards fixing it for fear of making it worse.</p>
<p>⟐ Edited January 27, 2026 at 15:11 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/341882/Why+is+the+dryer+making+a+horrible+noise</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/341882</guid>
<pubDate>Tue, 27 Jan 2026 15:11:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: My washer is filling, then not spinning but then draining]]></title>
<description><![CDATA[<p>My dryer/front loader washing machine is filling with water, the dial is moving but not spinning. It proceeds to drain and is finished in a matter of minutes. What could be wrong??</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_09_20_Num_2021" class="header">Update (09/20/2021)</h3></div>
<p>Frigidaire model GLGH1642FS2</p>
<p>⟐ Edited January 27, 2026 at 15:12 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/706291/My+washer+is+filling,+then+not+spinning+but+then+draining</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/706291</guid>
<pubDate>Tue, 27 Jan 2026 15:12:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Can u bypass lock switch]]></title>
<description><![CDATA[<p>Can I bypass the lack switch on my frigidare WSM2700HFWWW</p>
<link>https://www.ifixit.com/Answers/View/473333/Can+u+bypass+lock+switch</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/473333</guid>
<pubDate>Tue, 27 Jan 2026 15:12:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Light flashes to close lid that is closed]]></title>
<description><![CDATA[<p>light to close lid stays on even when closed</p>
<p>⟐ Commented April 30, 2026 at 0:04 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/952645/Light+flashes+to+close+lid+that+is+closed</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/952645</guid>
<pubDate>Thu, 30 Apr 2026 00:04:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: How to unlock my washer lid]]></title>
<description><![CDATA[<p>Unlock washer lid</p>
<p>⟐ Commented February 11, 2026 at 3:30 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/940181/How+to+unlock+my+washer+lid</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/940181</guid>
<pubDate>Wed, 11 Feb 2026 03:30:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: Can I run a cycle with the water off]]></title>
<description><![CDATA[<p>Frigidaire  FFLE3911QW . The winterizing instructions say turn the water off etc. Run rinse and spin cycle. Add RV antifreeze. When I turn the water off , I cannot run any cycles and get 3 beeps. Someone online says the machine wont run with the water off. Frigidaire tells me it should, call a tech. Does anyone know if it should drain with the water off?</p>
<p>⟐ Edited January 27, 2026 at 15:13 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/718792/Can+I+run+a+cycle+with+the+water+off</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/718792</guid>
<pubDate>Tue, 27 Jan 2026 15:13:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frigidaire Combo Washer Dryer: My combo beeps 3x but will not start]]></title>
<description><![CDATA[<p>had service 3x -replaced transmission did not fix. replaced controller still not working.</p>
<p>frigidaire laundry center model ffle3911qw0 -technician got an error code of 11 then 3 beeps therefore replaced controller board-53045000456.</p>
<p>original problem washing  section  stopped working and did not drain -dryer works fine</p>
<link>https://www.ifixit.com/Answers/View/705979/My+combo+beeps+3x+but+will+not+start</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/705979</guid>
<pubDate>Tue, 27 Jan 2026 15:13:53 -0700</pubDate>
</item>
</channel>
</rss>
