<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Dyson AM07 Tower Fan&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Dyson_AM07_Tower_Fan/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Dyson AM07 Tower Fan&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 04 Jul 2026 09:28:31 -0700</pubDate>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: faulty fan now board dead]]></title>
<description><![CDATA[<p>So i have just replaced the oscillating motor and the x2 cap to fix the side to side movement and stop it happening when it's off!  the main fan motor was a bit noisy, so i decided to take the impeller off the motor and clean and lube the bearings...bad idea!  the impeller ended up breaking the locating lugs off the bottom of it, and after all the messing around, when i turned it all back on, the motor was really unhappy, causing surges and then cutting out completely.  tested the fan from a known good machine and it worked for half an hour continuously at 10 without any issue...</p>
<p>I managed to source a second hand unit from a dyson repair shop nearby, and it arrived today - plugged it in, the display came on, motor did nothing...seconds later the screen went dark and nothing worked since.  i've since tested the motor, and it seems to have a short/very low resistance between the case and W1 phase wire - obviously it's sent 300v upstream and done some damage!</p>
<p>I've checked the fuse, all the 0ohm resistors i can find, and run through a load of testing with the help of AI to prove the buck regulator, the mosfets and the driver ICs all seem to be behaving as expected.  however, after tracing U2 (5v regulator), it seems to have a direct short to ground on 2 pins.  from what i can find, it appears pin 1 is output (apart from anywhere else, it supplied voltage to the screen), pin 2 gnd and ping 3 input - which appears to have a direct connection to the buck regulator IC output.  thinking the 5v regulator had gone short, i pulled it.....and still have the short.  then i removed cap c7 to make sure that wasn't shorting....it wasn't either.</p>
<p>Literally tearing my hair out now (shop said they wouldn't replace the damaged board, but have agreed a 50/50 split on a new board if i have to; but I would rather fix this.</p>
<p>Can anyone offer any advice? any common failures when the motors go short?</p>
<p>Thanks all!</p>
<p>⟐ Commented July 02, 2026 at 3:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/961359/faulty+fan+now+board+dead</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/961359</guid>
<pubDate>Thu, 02 Jul 2026 03:51:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Replace fuse: where is it and how?]]></title>
<description><![CDATA[<p>Where is the fuse? How can it be checked and/or replaced?</p>
<p>⟐ Commented October 14, 2024 at 19:33 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/873375/Replace+fuse:+where+is+it+and+how</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/873375</guid>
<pubDate>Mon, 14 Oct 2024 19:33:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Error code F2 on Dyson AM07 tower fan]]></title>
<description><![CDATA[<p>Fan showing error code F2 , not blowing air but will still oscillate .</p>
<p>⟐ Answered September 27, 2024 at 21:58 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/470231/Error+code+F2+on+Dyson+AM07+tower+fan</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/470231</guid>
<pubDate>Fri, 27 Sep 2024 21:58:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Dyson fan developed a low whining sound from the lower section (motor]]></title>
<description><![CDATA[<p>low whining sound from the lower, motor area of our otherwise wonderful fan. Please give info as to what we should do here. open and repair ourselves or send somewhere to have it fixed.</p>
<p>⟐ Commented July 19, 2024 at 10:57 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/578975/Dyson+fan+developed+a+low+whining+sound+from+the+lower+section+(motor</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/578975</guid>
<pubDate>Fri, 19 Jul 2024 10:57:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Why does the tower of my AM07 Dyson fan rotate even when turned off?]]></title>
<description><![CDATA[<p>The tower of my AM07 Dyson fan has recently started rotating continuously, even when the fan is turned off and no air is blowing. Is this a problem with the motor, and is it fixable?</p>
<p>I’ve found a multiple posts with people commenting about similar issues with the Dyson TP02.</p>
<p>⟐ Answer accepted March 19, 2024 at 21:53 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/772265/Why+does+the+tower+of+my+AM07+Dyson+fan+rotate+even+when+turned+off</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/772265</guid>
<pubDate>Tue, 19 Mar 2024 21:53:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: How to Fix the Clicking Noise While Oscillating]]></title>
<description><![CDATA[<p>A lot of the Dyson fans nowadays have the ability to oscillate. Throughout multiple versions, there have been some reports of a clicking noise developing at different amounts of use time. Unfortunately at this time, there doesn't seem to be a clear solution to the problem.</p>
<p>⟐ Commented January 04, 2024 at 14:52 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/318955/How+to+Fix+the+Clicking+Noise+While+Oscillating</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/318955</guid>
<pubDate>Thu, 04 Jan 2024 14:52:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: fan not oscillating back and forth]]></title>
<description><![CDATA[<p>What's wrong and how do I fix it?</p>
<p>⟐ Answered December 27, 2023 at 5:44 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/391028/fan+not+oscillating+back+and+forth</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/391028</guid>
<pubDate>Wed, 27 Dec 2023 05:44:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: What does code f3 mean]]></title>
<description><![CDATA[<p>code f3 is on machine</p>
<p>⟐ Answered December 05, 2023 at 21:30 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/502602/What+does+code+f3+mean</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/502602</guid>
<pubDate>Tue, 05 Dec 2023 21:30:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Fan is not turning on - have tried different outlets, no luck.]]></title>
<description><![CDATA[<p>Have plugged fan into different outlets, changed remote battery - nothing. Is there a fuse that can be replaced and if so where do I purchase and how do I replace it?</p>
<p>⟐ Answered May 24, 2023 at 7:47 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/319012/Fan+is+not+turning+on+-+have+tried+different+outlets,+no+luck.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/319012</guid>
<pubDate>Wed, 24 May 2023 07:47:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Error H2 - fan goes onto high power cold mode]]></title>
<description><![CDATA[<p>Fan is on medium heat for about 20 mins, and then shows H2 error code flashing, then blows cold air at full temp.  I'm guessing it's an overheating error.  Also, the hot air only blows out one side of the tower, cold air out the other side.</p>
<p>There was a lot of dust around the base of the tower in all the little holes which I vacuumed out, but the problem persists.</p>
<p>Guessing one of the fan heaters has burnt out?  About to try taking it apart, but wanting some guidance first!</p>]]></description>
<link>https://www.ifixit.com/Answers/View/756014/Error+H2+-+fan+goes+onto+high+power+cold+mode</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/756014</guid>
<pubDate>Thu, 17 Nov 2022 03:25:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Why is it not blowing cold air]]></title>
<description><![CDATA[<p>My fan works but doesn't seem to be blowing out much cold air anymore</p>
<p>⟐ Commented July 19, 2022 at 2:42 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/382359/Why+is+it+not+blowing+cold+air</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/382359</guid>
<pubDate>Tue, 19 Jul 2022 02:42:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Air intake on base totally clogged how to clean]]></title>
<description><![CDATA[<p>On the base of the fan the intake totally clogged with dirt how do I take it apart to clean</p>
<p>⟐ Commented February 06, 2021 at 4:35 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/519903/Air+intake+on+base+totally+clogged+how+to+clean</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/519903</guid>
<pubDate>Sat, 06 Feb 2021 04:35:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: My fan just suddenly stopped working - whether hot or cold]]></title>
<description><![CDATA[<p>the fan just suddenly stopped working. I've replaced the fuse in the plug but can't get into the fan to check anything else.</p>
<p>Was too expensive to just get rid of it.</p>
<p>Can you help?</p>
<p>⟐ Commented December 12, 2020 at 3:08 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/497364/My+fan+just+suddenly+stopped+working+-+whether+hot+or+cold</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/497364</guid>
<pubDate>Sat, 12 Dec 2020 03:08:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: low whining, vibrating sound]]></title>
<description><![CDATA[<p>when the fan is on i get this low, loud, vibrating sound. The higher the fan (1-10) the louder the sound is. I cleaned the base of all dirt but still have the sound</p>]]></description>
<link>https://www.ifixit.com/Answers/View/643081/low+whining,+vibrating+sound</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/643081</guid>
<pubDate>Fri, 26 Jun 2020 13:46:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: How to disassemble for storage]]></title>
<description><![CDATA[<p>How do you disassemble for storage</p>]]></description>
<link>https://www.ifixit.com/Answers/View/603198/How+to+disassemble+for+storage</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/603198</guid>
<pubDate>Sat, 23 Nov 2019 11:31:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Why is my Dyson AM07 Tower Fan smell like it's overheating?]]></title>
<description><![CDATA[<p>My Dyson AM07 Tower Fan  smells like it’s overheating. Where can I have it checked out?</p>
<p>⟐ Answered August 02, 2019 at 0:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/514377/Why+is+my+Dyson+AM07+Tower+Fan+smell+like+it&#039;s+overheating</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/514377</guid>
<pubDate>Fri, 02 Aug 2019 00:43:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Fan Noise AM 107 Mini]]></title>
<description><![CDATA[<p>How do I reduce the noise my fan makes?  Used to be whisper quiet, now sounds like normal fan</p>]]></description>
<link>https://www.ifixit.com/Answers/View/501347/Fan+Noise+AM+107+Mini</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/501347</guid>
<pubDate>Tue, 17 Jul 2018 18:27:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Fan not working . nothing happens not even turn on with remote]]></title>
<description><![CDATA[<p>I had new battery put in remote but fan will not work . . .</p>
<p>⟐ Commented June 17, 2018 at 15:25 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/494011/Fan+not+working+.+nothing+happens+not+even+turn+on+with+remote</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/494011</guid>
<pubDate>Sun, 17 Jun 2018 15:25:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson AM07 Tower Fan: Where can I buy a replacement base plate]]></title>
<description><![CDATA[<p>My AM07 is missing the base plate.  It can still stand but not very stable.  Where can I buy a replacement base plate?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/322773/Where+can+I+buy+a+replacement+base+plate</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/322773</guid>
<pubDate>Sat, 09 Jul 2016 09:39:38 -0700</pubDate>
</item>
</channel>
</rss>
