<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;DJI Mavic Air 2&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/DJI_Mavic_Air_2?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;DJI Mavic Air 2&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Tue, 21 Jul 2026 02:34:11 -0700</pubDate>
<item>
<title><![CDATA[DJI Mavic Air 2: DJI Assist 2 Not Recognizing My Drone, but Recognizing the Controller.]]></title>
<description><![CDATA[<p>I was wondering if anyone has ran into a problem with the DJI Assist 2 Software not recognizing the Mavic Air 2 Drone, but it recognizes the controller. I tried using multiple different cables and different computers. As I was inspecting the Drone's Type C port some of the pins appear to be slightly discolored, Has anyone replaced just the Type C Port or do you have to replace the entire motherboard? Any help will me much appreciated.</p>
<p>⟐ Answered October 29, 2025 at 21:57 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/921858/DJI+Assist+2+Not+Recognizing+My+Drone,+but+Recognizing+the+Controller.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/921858</guid>
<pubDate>Wed, 29 Oct 2025 21:57:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[DJI Mavic Air 2: Jello/gimbal motor overloaded/off center camera]]></title>
<description><![CDATA[<p>I have a Mavic air 2 with a few issues after a crash, all related to the camera gimbal.</p>
<p>Before repair:</p>
<ul><li>Jello (tried new OEM props, no effect)</li><li>After flying away for a couple minutes, error 40003 (gimbal motor overloaded) would appear</li><li>Footage looked fine besides the jello, but previous owner reported the gimbal would sometimes tilt as well</li><li>Gimbal looked slightly damaged, but everything was intact and all axes rotated freely, both manually and when stabilising the camera</li></ul>
<p>Repair:</p>
<ul><li>Replaced gimbal (including mounting board and dampers), but kept the original camera module and cables which did not look damaged</li><li>Recalibrated gimbal using python</li></ul>
<p>Issues after repair:</p>
<ul><li>Jello (even before arming, which I didn't know was possible)</li><li>Error 40003 soon after powering on, much sooner and more consistently than before</li><li>Gimbal is tilted and not centered</li><li>DJI fly gimbal calibration stops at 10%</li><li>Error 40011 (gimbal calibration failure) (I believe this is normal after using the python method to calibrate the gimbal, but it should still be fully functional)</li></ul>]]></description>
<link>https://www.ifixit.com/Answers/View/956407/Jello-gimbal+motor+overloaded-off+center+camera</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/956407</guid>
<pubDate>Sat, 23 May 2026 15:48:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[DJI Mavic Air 2: How to separate air 2s lens module from CCD board?]]></title>
<description><![CDATA[<p>I've got an air 2s camera whose autofocus motor is not functioning properly. Everything else about the camera (and of the gimbal) works fine - calibration is good, everything. Just that the autofocus motor click-click-clicks upon startup and it is most of the time is unable to focus on anything.<br /><br />I have sourced a new lens component (the thing with the optics and the autofocus motor and related electronics). The thing is, I cannot figure out how to separate the CCD board (which contains the sensor) from the old/bad lens component. I've tried prying in different ways but I really don't want to break the CCD board. I was wondering if anyone on the forum knows how these two parts are attached and how I can separate them. It may be that we're just talking about some glue that I need to heat up to separate, but I'd like to consult with those in the know before giving it a go.</p>
<p>Can anyone who has experience describe how the CCD board on the back of the camera module attaches and can be separated from the lens and lens housing?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/764979/How+to+separate+air+2s+lens+module+from+CCD+board</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/764979</guid>
<pubDate>Wed, 18 Jan 2023 20:38:09 -0700</pubDate>
</item>
</channel>
</rss>
