<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Apple Watch SE (Second Generation)&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Apple_Watch_SE_%28Second_Generation%29?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Apple Watch SE (Second Generation)&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 16 Aug 2026 20:40:50 -0700</pubDate>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): Is Apple Watch SE replacement display compatible with Apple Watch SE 2]]></title>
<description><![CDATA[<p>I have an Apple Watch SE 2 40mm and the display was damaged during an accidental drop.  The display cracked around the perimeter and has popped out (leaving shards still adhered to the body).</p>
<p>I found the in-depth guide for replacing a damaged display for the Apple Watch SE, but nothing for the SE 2.  It seems like removing the display is essentially the same process, but before I purchase the replacement part from ifixit I am curious if the display for sale on this website (Apple Watch SE 40mm) would be compatible with my SE 2?   Does ifixit sell a replacement display specifically for the SE 2?</p>
<p>⟐ Commented January 11, 2024 at 7:27 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/814982/Is+Apple+Watch+SE+replacement+display+compatible+with+Apple+Watch+SE+2</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/814982</guid>
<pubDate>Thu, 11 Jan 2024 07:27:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): How to replace cracked screen.]]></title>
<description><![CDATA[<p>Is there any guide to replace the apple watch SE second generation screen? And where to buy this screen?</p>
<p>Only glass is cracked, everything else is working</p>
<p>⟐ Commented February 18, 2023 at 18:10 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/769746/How+to+replace+cracked+screen.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/769746</guid>
<pubDate>Sat, 18 Feb 2023 18:10:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): What adhesive to buy when my screen suddenly came of?]]></title>
<description><![CDATA[<p>My apple watch se 2 screen just came off and I noticed the adhesive just no longer glued the screen.</p>
<p>⟐ Answer edited July 28, 2024 at 7:03 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/861600/What+adhesive+to+buy+when+my+screen+suddenly+came+of</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/861600</guid>
<pubDate>Sun, 28 Jul 2024 07:03:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): 1st gen se and 2nd gen se battery the same?]]></title>
<description><![CDATA[<p>I have a apple watch se 2nd gen 40mm (a2722) that I need to replace the battery in. IFixIt sells the battery for the series 5 and 1st gen se but I don't see anything for the series 6 or 2nd gen se. Are they interchangeable or are they different batteries?</p>
<p>⟐ Answered April 29, 2024 at 17:43 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/847535/1st+gen+se+and+2nd+gen+se+battery+the+same</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/847535</guid>
<pubDate>Mon, 29 Apr 2024 17:43:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): How to replace battery]]></title>
<description><![CDATA[<p>How do I replace the battery in my iwatch se 2?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/881533/How+to+replace+battery</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/881533</guid>
<pubDate>Thu, 26 Dec 2024 12:39:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): What is this connector for?]]></title>
<description><![CDATA[<p>Following fixit's guide for a battery replacement for Apple's Smart Watch, doing so on my 44mm SE 2 watch worked, mostly.  The guide warns about the right side of the watch around the stem to be very careful because of the connections.  Well on my 44mm watch those connections are on the bottom.  I cut through the bottom left connector; what is its function?  The watch still had residual power and would show the time (bottom right) and I could not fully discharge the battery.  It was off for 2 weeks before I started to work on it.</p>
<p>Like I mentioned above it's the lower left connector that has a screw holding it down.  I think it is a ground point but am not positive.  Thanks in advance to anyone who can identify this for me.</p>
<p>Ken</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/TfsnWhOWqFIvk1SF.standard" width="282" height="211" class="hasMenu hasLarge" alt="Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/TfsnWhOWqFIvk1SF.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Answer accepted May 20, 2026 at 16:26 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/955412/What+is+this+connector+for</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/955412</guid>
<pubDate>Wed, 20 May 2026 16:26:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): What battery does the Apple Watch SE 2 40mm use?]]></title>
<description><![CDATA[<p>I have the Apple Watch SE 2 40mm. Not the 44mm. What battery is compatible with the 40mm variant? I can only find batteries for 38mm or 44mm but nothing that says it is compatible with the 40mm. Can anyone help?</p>
<p>⟐ Commented February 16, 2026 at 13:24 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/869593/What+battery+does+the+Apple+Watch+SE+2+40mm+use</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/869593</guid>
<pubDate>Mon, 16 Feb 2026 13:24:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): I need the adhesive to put my screen back in caseo]]></title>
<description><![CDATA[<p><em>I dropped my watch it came apart now I need the adhesive to put it together. What kind do I get</em></p>
<p>⟐ Commented September 03, 2023 at 19:56 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/811339/I+need+the+adhesive+to+put+my+screen+back+in+caseo</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/811339</guid>
<pubDate>Sun, 03 Sep 2023 19:56:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): NFC replacement Apple Watch SE 2 - Sostituzione NFC Apple Watch SE 2]]></title>
<description><![CDATA[<p>Hi guys,</p>
<p>I tried to replace the screen of an Apple Watch SE 2 and it works fine, after it I tried to pair a card to Apple Pay but it didn’t work. So I thought that the NFC module was broken. I bought a new one for Apple Watch SE 2 from AliExpress and I noticed it still doesn’t work. After couple of days I find out that the reason was because the NFC module has to be linked to the motherboard.</p>
<p>So my question is: is there an iCopy or something else that can help me to make it work?</p>
<p>Thanks</p>
<p>—————————-</p>
<p>Ciao ragazzi,</p>
<p>Ho provato a sostituire lo schermo di un Apple Watch SE 2 ed ha funzionato. Dopodiché, ho provato ad associare una carta ad Apple Pay, ma non ha funzionato. Quindi ho pensato che il modulo NFC fosse rotto.</p>
<p>Ho comprato un nuovo modulo NFC per Apple Watch SE 2 su AliExpress, ma non è valsa la pena, dato che appunto non funzionava lo stesso il pairing della carta.</p>
<p>Dopo un paio di giorni, ho scoperto che il motivo era dovuto al fatto che il modulo NFC deve essere sincronizzato con la scheda madre. Avranno un ID unico come funziona per il Touch ID o per lo schermo o la batteria di un iPhone.</p>
<p>Quindi la mia domanda è: esiste un iCopy o qualcosa di simile che possa aiutarmi a farlo funzionare?</p>
<p>Grazie</p>
<p>⟐ Commented September 03, 2024 at 14:08 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/867714/NFC+replacement+Apple+Watch+SE+2+-+Sostituzione+NFC+Apple+Watch+SE+2</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/867714</guid>
<pubDate>Tue, 03 Sep 2024 14:08:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): Cracked screen and won’t power on]]></title>
<description><![CDATA[<p>My Apple Watch was damaged when I was involved in a car accident, before the accident I saw the time and functioned as usual ,had no damage prior whatsoever, after the accident the screen is cracked with even the glass coming off a little bit as well as it won’t turn on no matter what. Even if I’ve had it on the charger for up to 24 hours; so how would I fix the screen as well as see if the battery is damaged or just needs to be replaced entirely?</p>
<p>⟐ Answered July 02, 2025 at 8:53 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/905743/Cracked+screen+and+won%E2%80%99t+power+on</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/905743</guid>
<pubDate>Wed, 02 Jul 2025 08:53:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): So the SE 5 battery replacement kit will work on the SE 2 watch?]]></title>
<description><![CDATA[<p>Need to verify before buying the replacement kit for the SE2 I have.</p>
<p>⟐ Commented March 21, 2025 at 13:54 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/892310/So+the+SE+5+battery+replacement+kit+will+work+on+the+SE+2+watch</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/892310</guid>
<pubDate>Fri, 21 Mar 2025 13:54:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): Unresponsive Touch Screen for Apple Watch SE 2]]></title>
<description><![CDATA[<p>Anyone here experienced the touch screen being unable to respond to touch input? I use my apple watch almost daily for workouts and maybe sweat has probably gotten into. Could this cause the unresponsive touch screen? Thanks.</p>
<p>⟐ Answered August 01, 2024 at 4:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/862342/Unresponsive+Touch+Screen+for+Apple+Watch+SE+2</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/862342</guid>
<pubDate>Thu, 01 Aug 2024 04:05:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): Sensor Glass broke. What to do?]]></title>
<description><![CDATA[<p>My Apple Watch SE 2 sensor glass broke. It still charges fine but the heartrate sensor and the wrist detection sensor functions do not work. They do work once every 2-3 months randomly but they stop after a while.</p>
<p>Is there a replacement part for this and is there any guide on how to change it?</p>
<p>Thanks</p>
<p>⟐ Commented July 31, 2024 at 8:21 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/837024/Sensor+Glass+broke.+What+to+do</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/837024</guid>
<pubDate>Wed, 31 Jul 2024 08:21:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): Is it still safe]]></title>
<description><![CDATA[<p>My Apple Watch has 2 tiny cracks in the screen if I would put a protective case over the screen would it still be safe to swim with it?</p>
<p>⟐ Commented August 20, 2023 at 20:57 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/808960/Is+it+still+safe</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/808960</guid>
<pubDate>Sun, 20 Aug 2023 20:57:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): ペアリング前のアップデートが出来ない]]></title>
<description><![CDATA[<p>When I try to pair my Apple Watch SE (2nd generation) with my iPhone,<br /><br />the update screen appears, and if I skip it, the pairing resets.<br /><br />If I proceed with the update,<br /><br />&quot;Update cannot be completed successfully.<br /><br />Could not check for software updates because you are not connected to the Internet.&quot;<br /><br />An error message appears on the iPhone screen, and clicking &quot;Try Again&quot; simply repeats this message and does not proceed.<br /><br />Please let me know if there is a solution.</p>
<p>iPhoneでAppleWatch SE(第2世代)ペアリングをしようとした時に</p>
<p>アップデート画面が出て、スキップするとペアリングがリセットしてしまう</p>
<p>アップデートを進めてみた場合には</p>
<p>「アップデートを確実できません、</p>
<p>インターネットに接続されていないため、</p>
<p>ソウウェア・アップデートを確認できませんでした」</p>
<p>というエラーメッセージがiPhone画面に表示され、やり直すをクリックしても、このメッセージが繰り返させるだけで先に進みません。</p>
<p>解決策が有れば御教授願います。</p>
<p>⟐ Edited November 27, 2025 at 3:06 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/928099/%E3%83%9A%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E5%89%8D%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%8C%E5%87%BA%E6%9D%A5%E3%81%AA%E3%81%84</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/928099</guid>
<pubDate>Thu, 27 Nov 2025 03:06:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): Looking for Apple Watch SE 2 display adhesive]]></title>
<description><![CDATA[<p>Hey everyone! I am looking to purchase new adhesive for my Apple Watch SE 2's display, but noticed there is <a href="https://www.ifixit.com/Parts/Apple_Watch_SE_%28Second_Generation%29" target="_blank">no adhesive available</a> for this model (though perhaps I'm mistaken). However, there <em>is</em> adhesive available for the flagship Apple Watch lineup which, to my knowledge, has a similar housing to the SE 2. Could someone provide a recommendation on which to purchase? Thank you!</p>]]></description>
<link>https://www.ifixit.com/Answers/View/907602/Looking+for+Apple+Watch+SE+2+display+adhesive</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/907602</guid>
<pubDate>Tue, 15 Jul 2025 17:04:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): What battery do these use?]]></title>
<description><![CDATA[<p>Do these take the same batteries as the Series 5/ the first SE?</p>]]></description>
<link>https://www.ifixit.com/Answers/View/827220/What+battery+do+these+use</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/827220</guid>
<pubDate>Wed, 06 Dec 2023 12:52:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple Watch SE (Second Generation): Find microphone spare part]]></title>
<description><![CDATA[<p>I have an Apple Watch SE 2 (model 2022 40mm, device ID A2725) which has a dead microphone (test with voice memo app and one can barely hear something). The price of a fix as quoted by Apple is basically the same as brand new one, so not worth it.</p>
<p>I dig the internet, iFixit first, Aliexpress and all the like and it seems that the part that contains is a Microphone Flex Cable . It is however impossible to find the one specific to this model.</p>
<p>Any help confirming the part and / or providing a part number and / or a place to buy it would be very much appreciated.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/821255/Find+microphone+spare+part</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/821255</guid>
<pubDate>Thu, 26 Oct 2023 23:23:09 -0700</pubDate>
</item>
</channel>
</rss>
